Question about U-Line Icemaker
I inherited a Uline SP-18 icemaker with our RV. Was purchased in 1998 but looks to be in great condition. The compressor kicked in one time but no water would go in unit. Got real cold and I manually added water to tray. It froze and dumped the ice but then compressor kicked out and will not come back on. Is it the water valve the cause of no water in unit. What about the compressor not kicking in? Would like manual to unit.
  • 19,396 Answers
Re:The compressor kicked in one time but no water would go in unit.
As first operation defrost completely the unit. If unit had water in lines when it was connected , then water may have frozen inside the lines.
The compressor not kicking back in can be result of a bad compressor (starter capacitor gone), or simply a jammed temperature control. If defrosting does not fix the ice problem, check the inlet located at the back, there should also be a solenoid valve to open water into the icemaker.
Posted on Aug 23, 2010
HELLO I HAVE A ULINE WH95TP IN A BOAT WE HAVE IN FOR REPAIR AND THE ICEMAKER WONT GET COLD WAS WORKING BEFORE ANY THOUGHTS ON WHAT TO CHECK THERE ARE NO SCHAMADICS ON IT THANKS JOHN
Ice makers need refrigerant just like freezers and if it get too low it will quit working and probably burn itself out .call a refrigeration repair person and ask them to check it out .
Jul 30, 2015 | ULINE U Line Marine/rv Ice Makers Wh95tp...
Rv compressor trying to come but fan not, then compressor kicks off
Probley a low voltage condition in the RV park if that where your at.. does the indoor fan run with out the compressor?
Aug 07, 2011 | Heating & Cooling
Free standing uline icemaker in rv still freezes but does not make ice
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 24, 2010 | U-Line Icemaker
9/20/09 I just had the same problem with the same model
With rooftop air-conditioning units two issues are commons and that not clean unit that slow the fan and that effect the compressor, check the fan and see if the housing clean and no debris and as far as the compressor it is don and you need to replace it, I am sorry to tell you the news but on the other hand you can get used one now very cheep and they do work good. See if you contact local dealer that serves them and ask for used one or call campaign world and ask them to look for one for you…let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Sep 20, 2009 | Dometic Rooftop RV Air Conditioner
Compressor will not start but the fan runs on RV air condition unit Mod 7332B896 Coleman
If you can hear compressor try to start, then kick out, then I'd say capacitor needs replace, but if you don't hear anything (moan or groan) from compressor, then I'd be looking at a new relay, or at least testing it.
Jul 30, 2009 | Dometic Rooftop RV Air Conditioner
Uline icemaker compressor runs very hot - slow ice production
if the ice production is slow first try to set it on a warmer temperature. Now if its frosted up then you will need to defrost it. Also check the fan to see if its running. if yes is the condensor clean? If yes then check temperature in bucket. 10 to 15 degrees is ideal for this model.
Jul 04, 2009 | U-Line Icemaker
Uline icemaker must be manually prompted to rotate and drop cubes
If your looking for a icemaker it should be part 402. Call U-line with the serial or model number to be sure they made it.800-779-2547
Feb 24, 2009 | U-Line Icemaker
My ULine icemaker just started triping the GFCI plug.
Ground fault should not be used when you have a compressor plugged to it. The start amps can trip a ground fault. You can try to plug the unit on a regular outlet and if it doesnt trip the breaker then unit should be good. You can try to replace the ground fault if you need it (but make sure you have a higher amperage on the new one.)
Dec 23, 2008 | U-Line Icemaker
Ice maker (Uline) just stopped working, not freezing, no noise.
U-line does make compressors as long as its not a r12 system. As far as the icemachine turn breaker off for a couple of min then try it. If same results then it could be a board.
Uline icemaker for my 370 sea ray stopped working 100% of the time
http://www.u-lineservice.com is the mfg customer service site......there's a link to information and service numbers along with email based service requests.
The motor/gear/switch plate is available as a service part......
or you can use these links for tech help....
OnlineService@U-Line.com
1-800-779-2547
Jun 26, 2008 | U-Line Icemaker
U-Line Icemaker Logo
93 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
jasbo
jasbo
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
