Question about AEG 18 in. Favorit 54750Vi Slim-Line Built-in Dishwasher
I have had, for several timdes, the same problem as Joan in 2008 Dishwasher öko Favorit 54750VI See her description What is the cause and does somebody have a soluton for this problem By joan211 on Jul 28, 2008" " The programme is set and machine starts, but then alarms 5 with flashing light. I switch off and restart and it then continues for a few minutes - same problem AL5 is flashing - this can then be switched off and then on again and it continues - but this happens about 6 times before it will complete the cycle. What is the cause of the problem
2 Suggested Answers
joe_lishman
  • 192 Answers
SOURCE: My AEG 18 in. Favorit 54750Vi has stopped working.
If for any reason (water leak)the anti flood device at the bottom of the washer is triggered it automatically stops the inlet of water via inlet solinoid and puts the washer in pump out mode. Check the float (polystireene plate with micro switch at the bottom of the washer). Dry any water and determine the reason for water and this should let water in again.
Posted on Jan 20, 2010
How do I fix problem F3 and spray arm faulty on my KO FAVORIT 8080
F3 - The anti-flood protection system has activated.
When in operation the fault message F3 appears in multi dispay:
  • First close the water tap.
  • Pull out the power plug.
  • In the case of hard-wiring: turn off the electricity supply, remove the fuse and disconnect.
  • Check float microswitch and float of styrofoam.
  • Find and remedy water lakeage in the bottom of dishwasher.
Dado
Jan 22, 2015 | AEG Dishwashers
Dado
No hot water
If there is no hot water it could be (a) the heating element has gone or (b) the switching system has failrd somewhere - probably a relay or (c) the circuit card has gone (expensive)
Mar 23, 2014 | AEG 18 in. Favorit 54750Vi Slim-Line...
AEG Favorit Integrated Dishwasher failing to heat the water. has the element gone? and how do you get at it?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Mar 23, 2011 | AEG 23 in. Favorit 50750Vi Built-in...
We dont know how 2 turn it on just moved house n no instructions aeg oko favorit dishwasher
Looks like what you need is available at
http://www.serviceforce.co.uk/pdfs/U20206.pdf
Good luck with the new house. Hope the dishwasher works well for you.
Try to run it with dishwasher cleaning kit (no utensils) to make sure everything is clean - that way you will get more life out of it. The cleaning kit (usually Finish) is sold in the supermarket in the detergent section.
Jan 31, 2010 | AEG 18 in. Favorit 54750Vi Slim-Line...
Hi our dishwasher goes through its cycle but does not dissolve the powder blocks and does not clean the dishes
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Nov 09, 2009 | AEG 18 in. Favorit 54750Vi Slim-Line...
My AEG 18 in. Favorit 54750Vi has stopped working. It sounds as though it's going to start normally then starts to beep. When I open it the 'Rinse and hold', 'Normal 65*',and 'Intensive 70' indicator...
Oct 12, 2009 | AEG 18 in. Favorit 54750Vi Slim-Line...
Having problems with AEG dishwasher-tablet not dissolving..
open the door when in cycle and check both spray arms are rotating. you will get a bit of water out but not a lot. if arms not rotating, then this is caused usually by rubbish in the spray arm jets so clean them. also check water is being heated
Aug 05, 2008 | AEG 18 in. Favorit 54750Vi Slim-Line...
Door latch in closed position
put two small screwdrivers in each side of the latch and lever upwards (best way) or otherwise take the door outer panel and fascia off so you can get at them
to stop it reoccuring, bend u catch on cabinet slightly downwards
Jul 20, 2008 | AEG 18 in. Favorit 54750Vi Slim-Line...
Open Questions:
See all AEG 18 in. Favorit 54750Vi Slim-Line Built-in Questions
AEG 18 in. Favorit 54750Vi Slim-Line Built-in Dishwasher Logo
Top AEG Dishwashers Experts
paul
paul
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
