My Roland KR 650 digital piano, amplifier has a load hum and will not play.
Are all smd defective?
Posted on Mar 30, 2012
  • gaspbut Mar 30, 2012
    I have the same problem
    Problem Solver:
  • 5 Answers
Smd elkos on the mainboard is defective 10uF16V and 3,3uF types
Posted on Sep 03, 2010
    I have the same problem. Are all smd defective?
My Roland KR-03 Piano has bad static sound on the left speaker. It is also in the headphones.
seems to me this will need more than most people can do. tracking down the problem will require a lot of testing of transistors and such... but just maybe it's nothing more than a loose ground wire on the circuit that powers that side. Good luck.
Jan 08, 2018 | Roland Music
How do I fix a Roland Digital Piano FP-8 that has refused to play sounds despite the fact that it displays lights?
If everything lights up and responds to button pushes like normal, and you've done a hard reset as described in the manual, check to see if you have sound out of the headphone jack. It's most likely not a user serviceable problem and will need to go to the shop, but it will probably be the output amp rather than the main board.
Mar 07, 2015 | Roland Fp-8 Digital Piano Email Us For A...
I have a Technics PR-305 Digital Piano. I was playing a couple of songs on it., then about 5 days later. around the beginning of November I went to turn it on it made a loud humming sound from the sp
Yes it can.....but you will need the schematics and some test gear in order to do it.....and a soldering iron....what do you mean by no surround on the speaker?? Can you post a pic??
Nov 25, 2014 | Music
How do I connect my roland piano 5500 to an amp
On the rear of the piano there will be two 1/4" jacks labeled Output Left and Right. One will be labled Mono as well. If you are using a stereo amp, use both, and if a mono amp use just the mono output. If your amp is a guitar type, connect a shielded cable with 1/4" phone jacks such as you'd use with an electric guitar from these jacks to your amplifier. If you are useing a home stereo amp, you will need a cable with 1/4" phone jacks from the piano to RCA phono jacks on the amp end.
Oct 08, 2014 | Roland HPI-7F 88-Key Digital Piano -...
I have a Roland KR 4500 Digital Piano and I brought it to the local authorized Roland Service Center here in the Detroit area. Apparently the capacitors on the motherboard leaked and the board is tot
You can sometimes clean up the board with a cotton swab and some alcohol. Trace the lines for continuity with a multimeter making sure there are no breaks. Get the information on the capacitors and buy them at an electronic parts store. Replace them or have a professional do it. If all fails, sell it for parts.
Jan 14, 2012 | Yamaha Music
I have a Roland FP 1 digital piano, serial #AL21141N. It has gradually quit putting out sound through the speakers. At the onset of the problem, I could fit it by jiggling the 1/4" speaker plugs,...
I first would suspect the switches on the eadphone jack. Normally these cut off the speakers when headphones are plugged in. These jacks and the switches are really weak, poorly made, and easily broken, especially if headphone cord gets yanked.
Jan 14, 2011 | Roland Digital Piano FP4 Black With Stand...
How to remove piano keys from Roland KR 4700
You probably need to just clean the circuit board and the conductive rubber contacts. There are two per key to facilitate reading the key velocity.
Use 99% isoprophyl alcohol and Q-Tips to clean both the board and the rubber contacts.
A rod is inserted lengthwise to hold the hammer weights while removing the boards. Use dowels from each end inserted about halfway back between the keys and the weight rods. Use a 1/4 inch dowel rod.
You have to take out a few screws to remove the boards from the key assembly. Be careful of the cables.
Mar 17, 2010 | Yamaha NP 30 76 Key Lightweight Digital...
I have a Roland HP 2e digital piano - Foot pedal problem
The ROLAND pianos USUALLY require that you use a normally closed sustain pedal.
MANY pedals are the opposite and close when pressed. SOMETIMES you can open the pedal and reverse the way the switch works.
Oct 05, 2009 | Roland Music
Need a manual
To download manuals Roland requires you to register. Go to:
http://backstage.rolandus.com/login.php
Create a new profile, then login to download the manual you need.
Thanks for using Fixya.
Apr 16, 2009 | Computers & Internet
905 people viewed this question
 Grubhead
Grubhead
