Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Whenever i try to transfer files from my desktop to my system i m find an error .. " the destination you specified doesnt exist , it may an offline device ....." what to do ... :( :(
    Sergeant:
  • 203 Answers
Maybe your External HardDrive has failed, you maybe able to re-use the HardDrive inside if you can't retrieve files from your HardDrive to your P.C.
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismatle of your External HDD.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues'
Posted on Aug 23, 2010
I cannot scan my documents. I got a message from Scansnap: La destination specifiee (dossier d'enregistrement des images) est incorrecte. Specifiez une nouvelle fois la destination.
Go to the settings of Scansnap and look for save folder or destination folder. The error message usually appears when the destination folder has been deleted.
Mar 28, 2017 | The Computers & Internet
Tip
Copy files even with errors and many more
You might encounter something like "Access Denied", "The file has beentransferred to another location or deleted" or some other errors whilecopying your files.
This is a typical problem to those Windows XP users. So what they do isjust recopy all the files again but they will exclude the one with theerror.
What if you have virus that you are in random folders that can't be moved/copied?
What if your old files that you don't need have random access denied files?
What if and what if?
How to continue copying files and exclude the files with error?
Here's how you do it.
What is xcopy?
Copies files and directory trees.
How to use xcopy?
XCOPY source [destination] [/A | /M] [/D[:date]] [/P] [/S [/E]] [/V] [/W]
[/C] [/I] [/Q] [/F] [/L] [/G] [/H] [/R] [/T] [/U]
[/K] [/N] [/O] [/X] [/Y] [/-Y] [/Z] [/B]
[/EXCLUDE:file1[+file2][+file3]...]
See the REFERENCE below for the detailed meaning
Step 1.
Click Start then click Run...(Or Simply Press Windows key+R)
Step 2.
type "xcopy [source] [destination]"
Sample 1: (For single File ONLY)
xcopy C:/Windows/System32/userint.exe E:/Backup
Sample 2: (For folder including their sub folders)
xcopy C:/Windows E:/BackupWIndows /S
or
xcopy C:/Windows E:/BackupWIndows /E
Sample 3: (For Continue Copying even Error Occurs)
xcopy C:/Windows E:/BackupWIndows /S /C
Sample 4: (For allowing copying encrypted files)
xcopy C:/Windows E:/BackupWIndows /S /G
Note: You can combine the rules/options that you like.
That's it! you now have a way to copy files that are protected, accessdenied, or even those that are encrypted. Hope This tip helps you. ^^
REFERENCE:
What are the use of the options?
source Specifies the file(s) to copy.
destination Specifies the location and/or name of new files.
/A Copies only files with the archive attribute set,
doesn't change the attribute.
/M Copies only files with the archive attribute set,
turns off the archive attribute.
/D:m-d-y Copies files changed on or after the specified date.
If no date is given, copies only those files whose
source time is newer than the destination time.
Specifies a list of files containing strings. Each string
should be in a separate line in the files. When any of the
strings match any part of the absolute path of the file to be
copied, that file will be excluded from being copied. For
example, specifying a string like obj or .obj will exclude
all files underneath the directory obj or all files with the
.obj extension respectively.
/P Prompts you before creating each destination file.
/S Copies directories and subdirectories except empty ones.
/E Copies directories and subdirectories, including empty ones.
Same as /S /E. May be used to modify /T.
/V Verifies the size of each new file.
/W Prompts you to press a key before copying.
/C Continues copying even if errors occur.
/I If destination does not exist and copying more than one file,
assumes that destination must be a directory.
/Q Does not display file names while copying.
/F Displays full source and destination file names while copying.
/L Displays files that would be copied.
/G Allows the copying of encrypted files to destination that does
not support encryption.
/H Copies hidden and system files also.
/R Overwrites read-only files.
/T Creates directory structure, but does not copy files. Does not
include empty directories or subdirectories. /T /E includes
empty directories and subdirectories.
/U Copies only files that already exist in destination.
/K Copies attributes. Normal Xcopy will reset read-only attributes.
/N Copies using the generated short names.
/O Copies file ownership and ACL information.
/X Copies file audit settings (implies /O).
/Y Suppresses prompting to confirm you want to overwrite an
existing destination file.
/-Y Causes prompting to confirm you want to overwrite an
/Z Copies networked files in restartable mode.
/B Copies the Symbolic Link itself versus the target of the link.
/J Copies using unbuffered I/O. Recommended for very large files.
The switch /Y may be preset in the COPYCMD environment variable.
This may be overridden with /-Y on the command line.
Visit redbullet05.blogspot.com for more troubleshooting guides. ^^
on Jan 24, 2010 | Computers & Internet
Fax forword ricoh mp171
Print documents received and forward to a specified end receiver. This is useful if, for example, you are visiting another office and would like a copy of your documents to be sent to that office.
You can also specify a "folder" as the forwarding destination.
  • To use this function, set [Forwarding] under [Administrator Tools] to [On].
  • The Forwarding function does not forward documents received with Memory Lock.
  • You can select end receivers only from among destinations programmed in the Address Book. You cannot specify programmed transfer stations as end receivers.
A fax number, e-mail address, IP-Fax destination, and folder can be set as the forwarding destination.
When you wish to change the end receivers depending on the senders, specify the end receivers by the senders, at "Program Special Sender". Documents not received from specified senders are sent to the destination specified in this function. For details about programming special sender, see "Program Special Sender".
You can set whether or not to print the forwarded documents on this machine in "Parameter Setting" (switch 11, bit 6). See "Parameter Settings".
Deleting a destination specified as a forward destination from the destination list causes the settings of the forward destination to be deleted, so they must be registered again. When a destination is changed, a document is transmitted to the new destination. If there is no destination of the specified type, you can set which destination to be used as an alternative destination in "Parameter Setting" (switch 32, bit 0). See "Parameter Settings".
You can program one of the User Function keys with operations for this function. See "General Settings/Adjust".
If you have specified a folder for forwarding, you can specify the file format used for forwarding in "Parameter Setting" (switch 21, bit 3). See "Parameter Settings".
User Parameters (switch 37, bit 4) on the Fax Features menu allows you to include the sender's name in the names of files sent to folders. However, garbling of the file name and data loss can result if the receiver's operating system cannot accept certain characters in file names. To prevent this, use User Parameters (switch 37, bit 5) to limit the file names to plain characters only. If you limit file names to plain characters only but errors still occur, disable display of the sender's name in the file name of documents forwarded to folders. For details, see "Parameter Settings".
Using the parameter setting (switches 38 and 39), you can specify the maximum number of resends that the machine attempts if it fails to forward a fax (including faxes from special senders) to a folder destination, and the interval between the resend attempts.
or download the operations manual to guide you here ..http://support.ricoh.com/bb_v1oi/html/oi/re/model/mp171/mp171en.htm
Mar 24, 2013 | Ricoh Aficio Office Equipment & Supplies
How can i exchang data from hdd to anothe hdd
Open a reduced window for both source and destination on your desktop
LMB click on file icon folder you wish to transfer, keeping the LMB down all the time
drag the file to the destination folder.
or
LMB click on file icon folder you wish to transfer, go to top of window LMB click "EDIT" then sellect "COPY" then LMB in the destination window LMB click "EDIT" then sellect "paste".
Nov 28, 2010 | Dell OptiPlex GX620 PC Desktop
Unable to transfer files to sony 4gb pen drive
Restart your PC and try it again or try it on other PCs. If problem persists then pen drive is defective. Return to retailer and ask for a replacement.
Aug 14, 2009 | Computers & Internet
Cannot transfer files in to sony 4gb pen drive
try a different usb slot ..if that doesnt works then it sounds like your pen drive is damaged .. that can happen in several ways .. if you carry it around with you, make sure the cap is on ... it can get static zapped otherwise .. also the gold fingers inside can get dirty .. another way the drives are damaged is to remove them while data is still being written to the drive ... wait until the light is no longer flashing before removing .. if you are using win98 or winMe .. then make sure you turn off the device before removing ..
Aug 05, 2009 | Sony Computers & Internet
PhotoShop CS3 Droplet automation
Try the following steps
  1. Choose File => Automate => Create Droplet.
  2. Specify where to save the droplet. Click Choose in the Save Droplet In section of the dialog box and navigate to the location.
  3. Select the Action Set, and then designate which action you intend to use within the Set and Action menus. (Select the action in the Actions palette before you open the dialog box to preselect these menus.
  4. Set Play options for the droplet:
    a. Override Action “Open” Commands Open commands in the action refer to the batched files, rather than to the file names specified in the action. Deselect Override Action “Open” Commands if the action was recorded to operate on open files or if the action contains Open commands for specific files that are required by the action.
    b. Include All Subfolders Processes files in subdirectories.
    c. Suppress Color Profile Warnings Turns off display of color profile messages.
    d. Suppress File Open Options Dialogs Hides File Open Options dialog boxes. This is useful when batching actions on camera raw image files. The default or previously specified settings will be used.
  5. Choose a destination for the processed files from the Destination menu:
    a. None Leaves the files open without saving changes (unless the action includes a Save command).
    b. Save And Close Saves the files in their current location, overwriting the original files.
    c. Folder Saves the processed files to another location. Click Choose to specify the destination folder.
    Note: You can record an action that saves using a specified file name and folder. If you do this and deselect Override Action “Save As” Commands, the same file is overwritten each time. If you record your Save As step in the action without specifying a file name, the droplet saves it to the same folder each time but uses the file name of the document being saved.
  6. If the action includes a Save As command, choose Override Action “Save As” Commands to make sure files are saved to the folder you specified (or to their original folder if you chose Save And Close.) To use this option, the action must contain a Save As command, whether or not it specifies a save location or file name; otherwise, no files are saved.
    Some save options are not available in the Batch command (such as JPEG compression or TIFF options). To use these options, record them in the action, then use the Override Action “Save As” Commands option to make sure that your files are saved where you specify in the Batch command.
  7. If you chose Folder as the destination, specify a file-naming convention and select file compatibility options for the processed files:
    a. For File Naming, select elements from the pop‑up menus or enter text into the fields to be combined into the default names for all files. Elements include document name, serial number or letter, file creation date, and file extension. Starting Serial Number specifies the starting number for any serial number fields. Serial letter fields always start with the letter “A” for the first file.
    b. For Compatibility, choose Windows, Mac OS, and UNIX to make file names compatible with Windows, Mac OS, and UNIX operating systems.
  8. Select an option for error processing from the Errors pop‑up menu:
    a. Stop For Errors Suspends the process until you confirm the error message.
    b. Log Errors To File Records each error in a file without stopping the process. If errors are logged to a file, a message appears after processing. To review the error file, open it in a text editor after the Batch command runs.
Give it a try.........
Jul 30, 2009 | Computers & Internet
I cudnt download video file from my mail id r any website
This means that the source file(the file which u want to play) is moved or deleted from the location.
For solving the problem
try playing the file by doble Clicking on it .
or
either move it to the original loaction. and then play t from WMP
Hope It Solved Your Problem
Good Day
Apr 15, 2009 | Microsoft Windows Media Player
Cannot play audio CD's
try re-adding all audio cd songs in to you WMP11. Instead of playing what already in there.
Go to now playing and try adding all tracks into it.
Apr 27, 2008 | Gateway 500XL PC Desktop
About sound manager
It's probably some sort of virus. There's been no known existence in any system that creates .exe while moving or copying files unless its a virus loaded in memory monitoring file access. Virus is made to proliferate. Don't try to execute the .exe file and immediately scan your computers both desktop and mobile for possible additional existence of viruses by using dependable anti-virus software with latest updates - the anti-virus software will not be able to detect it if it's not on its latest virus database list & signatures.
Nov 24, 2006 | 4D IBM LENOVO PROCESSOR -2GHZ P4 D2...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
136 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
