Question about ASUS P4S533-MX Motherboard
Auto bios come - ASUS P4S533-MX Motherboard
  • 93 Answers
I am afraid that you will need to give a far clearer list of the particulars of your own computer for example make, model and what exactly are you trying to do.
Posted on Sep 08, 2010
Bios keeps booting, no hard drive found
AUTO search harddrive will not detect the harddrives in the bios list but loads by position priority by the used bus the first ide or sata set it to manual in the page where you see auto by double click or older machines by tab and + - or arrows its depending on the brand of the bios. ami or phoenix , dells bios building by separate companies or award or somewhere . first release the battery a minute and replace if its empty if you have no booting harddisk if you have only 1 ide harddisk the are sometimes neccesary by different jumper settings to set it for the single drive only instead of master or slave with the one jumper setting for master on the end of a ide cable and the slave on the second drive both on one cable in ide pos 0 the hoighest priority look on the drive self or on internet that your bios will see the brand in the bios and info of the used hard disk.
single drive only jumper setting Google zoeken
Jan 02, 2016 | Dell Computers & Internet
How I get BIOS Update to DA061/078l AM3?
google your motherboard and see if it takes you too gateway home site, and the find support downloads and they should have yor bios.
you mayalso have a motherboard which detects bios updates and you can boot into the bios and check for an auto update
Sep 04, 2014 | Computers & Internet
Bios crashed while flashing
Your board has the ASUS crash free bios recovery feature:
01.gif CrashFree BIOS 2
The CrashFree BIOS 2 feature now includes the BIOS auto-recovery function in a support CD. Users can reboot their system through the support CD when a bootable disk is not available and go through the simple BIOS auto-recovery process. ASUS motherboards now enable users to enjoy this protection feature without the need to pay for an optional ROM.
Your manual ought to give you the step by step instructions.
Oct 31, 2012 | ASUS P5N73-AM Motherboard
Mainboard GA-G31-ES2C Warning: Backup BIOS checksum error BIOS Auto-Recovering...
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen to press delete to enter setup
Jul 23, 2011 | Gigabyte GA-G31M-ES2L Motherboard
try to find a copy of the bios from the manufacture's website, and put it on a usb stick, then start the computer with the usb stick plugged in. if that doesn't work, you may have to replace the bios chip with a properly programmed one. if you can replace it, then you would have to replace your motherboard (unless I missing something here on how to recover the bios)
Jul 07, 2011 | Gigabyte GA-G31M-ES2L Motherboard
Save not cmos on mainboard asus p4p800s-x chek batry&clear cmos but not resolv save not cmose
ASUS CrashFree BIOS2
Users can reboot their system through the support CD when a bootable disk is not available, and go through the simple BIOS auto-recovery process. ASUS motherboards now enable users to enjoy this protection feature without the need to pay for an optional R
C.P.R.(CPU Parameter Recall)
When the system hangs due to overclocking failure, there is no need to open the case to clear CMOS data. Just simply restart the system, the BIOS would show the previous setting and then users can amend the CPU setting again.
ASUS EZ Flash
With ASUS EZ Flash, you can update BIOS before entering operating system. No more DOS-based flash utility and bootable diskette required.
hope this helps you
Mar 03, 2011 | ASUS P4P800S-X (610839118175) Motherboard
BIOS cant display(in BIOS option no data write there), and i cant chang my BIOS setting. now i cant formeting my leptop, & any operating system i cant install. at pesent o/system is win7...
to get into bios hit f-2 at start up go to bios and restore it to default setting
if you have a sata hard disk then disable it in bios setting
or RAID Auto/Ahci to RAID Auto/ATA
then reboot from installation disk hope this helps and remember to vote
Nov 29, 2010 | Computers & Internet
I remove the cmos batt. reinstall now my computer tells me that there is no bios values and I should enter it. I don't know what to do.
Enter the BIOS and select the item for Load optimal defaults or factory defaults, remember to set the date and time. You may also have to auto detect the hard drives by selecting the auto detect hard drives.
Nov 10, 2010 | Computers & Internet
I am going to install a new graphics card, do i need to disable my integrated card firts and then shut down and install the new one?
In your BIOS it should be set so as to auto detect integrated graphics or AGP.
This is the default setting for HP and Compaq machines.
Install the card and see what happens, if you have no video, shut down the machine and either remove the new card and then set the BIOS to auto detect or if you saw the BIOS splash screen with the new card installed but got no graphics, then again go into the BIOS and set it to auto detect.
Nov 03, 2009 | Computers & Internet
Require latest version of bios for Motherbd M2n-MX SE Plus
Motherboard : M2N-MX SE Plus
BIOS latest version: Version 0503
Description :
Fix when using AM2+ 9550 or 9650 CPU, there is incorrect information in "Revision" of "CPU Configuration" in BIOS Setup.Fix that PS2 mouse can not work without PS2 keyborad under VISTA HOME Basic Change the CNQ Function default to DISABLE.
Download:-
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=M2N-MX%20SE%20Plus
BIOS Recovery Step :
The CrashFree BIOS2 feature now includes the BIOS auto-recovery function in a support CD. Users can reboot their system through the support CD when a bootable disk is not available, and go through the simple BIOS auto-recovery process. ASUS motherboards now enable users to enjoy this protection feature without the need to pay for an optional ROM.
Thanks & Regards
Rajesh
Jul 14, 2008 | ASUS Computers & Internet
ASUS P4S533-MX Motherboard Logo
48 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
