Question about Lorex L154-81
I have a Lorex L19LD800 Series secutrity system. The problem is when I turn the monitor on, it stays on for just a few seconds before it turns off. I checked all cables.
2 Suggested Answers
kingrattus
SOURCE: I turn my monitor off and it comes back on??
I would hook it up to a different Monitor to see if your monitor is broken.
If you mean you set the screensaver in the software and it keeps turning your monitor back on, then yes, its becuase you have it set to motion detection. Thats usually called an event & systems usually come out of screensaver mode & to display the event.
Posted on Mar 04, 2009
Need Owners manual 4 Lorex LNC201
About 75,300 results (0.48 seconds) Search Results
    [PDF]LNC200 Series LIVE Ping Wireless Network Camera ... - Lorex
    https://www.lorextechnology.com/.../LNC200_SERIES_MANUAL_EN_...
    Oct 16, 2012 - If you require further installation assistance, please visit ... Thank youfor purchasing this Lorex wireless network camera. This user's guide refers to the following models: • LNC201. • LNC204. Contents. Before you start, make ...
    Lorex Support - product manuals and remote video monitoring
    https://www.lorextechnology.com/support/
    Lorex Support - Get online help for your setup problems using lorex self-serve and access your lorex information, products manuals and documentation. ... Find out all the ways you can get support and service for your Lorex products. ... Some products may have the Model Number located inside the battery compartment.
Jan 25, 2016 | Lorex Home Security
Wires cut on my lorex mc7520 color camera how do I wire
http://www.lorextechnology.com/downloads/security-dvr/SG19LD-SG17LD-Series/SG17LD800&SG19LD800_SERIES_MANUAL_EN_R3.pdf
I hope you have the rest of the system since the monitor powers the camera. If you have the end of the cable with the connector on it then just splice the wires color for color. If not then you're out of luck.
Oct 01, 2014 | Lorex Home Security
I have a Lorex security system and the monitor will not turn on properly.
ARE ALL YOUR FIELD CAMERA'S POWERED UP (1ST) , OLDER SYSTEMS POWERED THERE FIELD CAMMERA S FROM EXTERNAL POINTS (UNLIKE MODERN UNITS THAT ALL POWER COMES FROM BASE FOR FIELD UNITS)
Jan 27, 2013 | Lorex 4 Channel Business & Home Security...
When I turn on the monitor for the two cameras I have set up It says that the frequency is out of range? What is the problem with this?
This is a simple fix
You simply need to turn down the resolution of the monitor
It is set too high to handle the picture and is a common issue.
You may also be able to turn it down from the settings option on the monitor or via the system itself
Mar 15, 2011 | Lorex New Lorex Lw2100 Digital Wireless...
My monitor goes blank after a few seconds of turning my computer on. I turn off the monitor & turn it back on again and it only stays on for a few seconds thanks
It basically goes to Power Save Mode. Check for the same error in System Setup screen, if the Monitor goes off in System Setup then you better need a replacement. Else you would need to reseat the Video Card(If any) and the Memory Modules. Please keep posting for any further issues / improvements.
Dec 30, 2009 | Dell Computers & Internet
Feb 20, 2009 | Lorex Dxr4280uq-a 4 Channel Digital Video...
Envision Series / AOC 22 hdtv monitor
Probably blown capacitors, the 19" widescreen uses 6 16V 1000uF
Do you have a soldering gun? Its not that hard to fix, get the capacitors on ebay for $6-$8 with shipping.
Oct 31, 2008 | Envision 19" Widescreen Flat Panel LCD...
The picture disapears, though the monitors stays on - every few seconds
Check the cable connections on the back of the monitor and the PC it sounds like the connection isn't made properly make sure they are tight.
Oct 28, 2006 | BenQ FP71E+ (Black, Silver) (Silver,...
Lorex L154-81 Logo
233 people viewed this question
Top Lorex Televison & Video Experts
Jim London
Jim London
Colin Stickland
Colin Stickland
Are you a Lorex Televison and Video Expert? Answer questions, earn points and help others
