Question about Konica Minolta Bizhub c203 Copier
How do i replace the image transfer belt on my bizhub c203? where is it located?
    New Friend:
  • Konica Minolta Expert
  • 118 Answers
It is behind the right door but i doesnt need to be replaced you need a pico fuse about
$2 and it can be reset. if yoiu need more help in this and where the fuse is just ask
Posted on Oct 16, 2011
KM bizhub c 203 prints blank on yellow, I have tried replacing the y imaging unit, y laser unit, image transfer belt, all to no avail. How could it be fixed?
Have you tried the High Voltage board that supply the voltage to the print heads and ITB. could be the print head is fine biut not getting any power to fire the laser and write to the drum
Mar 20, 2017 | Konica Minolta Bizhub c203 Copier
My printer fuser and transfer belt did not open with error code c2152 i tried to reset the printer but not still working pls what can i do
PROBABLE CAUSES:
1. Detecting Plate not positioned properly.
Shape of the detecting plate has been modified. Install the modified Detecting Plate (p/n A02E 5033 01). Please refer to the attached procedure for
instructions on how to install the modified bracket.
Note :The following are the serial number cut-inswith themodified Detecting Plate installed:
bizhub C353 - A02E010005899 and onward
bizhub C203 - A02E012005777 and onward
bizhub C253 - A02E011005566 and onward
bizhub C353P - A02E013000060 and onward
magicolor 8650 - no cut-in available
2. Transfer Belt Retraction Sensor (PS31) mounting bracket (p/n A02E 1121 00) is fixed with a screw and it can be tilted while assembling. If the bracket is
tilted, the sensor cannot detect the Transfer Belt position properly. In order to avoid tilting the bracket, the shape of the bracket has been changed.The shape of the sensor actuator has also been changed because the actuator could touch the other parts.
PARTS
A02E 1121 00 -current Bracket
A02E 1121 11 - modified Bracket
A02E 1122 01 - current Actuator
A02E 1122 12 - modified Actuator
Notes :
a.When at the machine, please check the condition of Sensor Bracket and change the Sensor Bracket and Actuator if necessary.
b. Please refer to details in attachedBulletin Number 6252 (applies tobizhub C203/C253/C353).
3. Somepacking material was not removed froma new Transfer belt before installation. Ensure that allpacking material has been removed before the Transfer belt is installed.
4. Failure of the Transfer Belt Retraction clutch (CL7).
Check for wiring being pinched from bypass door and replace the failed parts.
PARTS
CL7 (p/n A02E M200 00)
bizhub C353 Drive Wiring/1(p/n A02E N10F 02)
bizhub C253 Drive Wiring/2 (p/n A02E N117 02)
bizhub C203 Drive Wiring/3 (p/n A02E N10Y 02)
bizhub C353P Drive Wiring/4 (p/n A02E N11A 00)
magicolor 8650 Drive Wiring/6 (p/n A02E N11C 00)
Mar 16, 2015 | Konica Minolta Minolta Bizhub C353 Copier
I have a problem with a bizhub C203 what can i do?
Verify the problem is in the imaging units or the transfer belt units.Remove the transfer unit and clean on vacuum cleaner the transfer belt cleaning blade.If you see the stripes on transfer belt after cleaning is work normally.If not observ stripes on transfer belt the problem is located in imaging unit.Enter in service mode :Press Utility key-Meter count- Details-Stop 00-Stop01 Select Test mode-select Gradation test pattern and select the Cyan press Start,after select Magenta Press Start,Yellow +Start,Black4+Start.If any color test pattern is not graduate the problem located to image unit when is not graduaTE.
Jul 28, 2014 | Konica Minolta bizhub Office Equipment &...
Cual es la cinta de transferencia que tengo que quitar para limpiar los sensores de control de densidad de una bizhub 203
replace the black image unit and clean the transfer belt sensors located under the transfer belt
Nov 23, 2013 | Konica Minolta Bizhub c203 Copier
C13c8
C13C8 A new installation is not detected when a new Transfer Cleaner Unit (Image Transfer Belt Unit) is installed.
When a new transfer belt unit is installed in a machine an internal component on the transfer belt unit changes state; this now indicates that the transfer belt unit is used
http://kmcopierservice.blogspot.com/2011/02/how-to-reset-transfer-belt-bizhub-c203.html
Apr 10, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
I have a Bizhub c203 stating it need the transfer image belt replaced. Is this just as simple as replacing a fuse? If so, where do I buy it and how do I replace it? Thank you
Yes!! it is just a small fuse. It can be bought at www.partsnow.com or precision roller. SUPER cheep. then release the the belt and its on the left side under the cover by the spring held on the shaft
Oct 28, 2011 | Konica Minolta Bizhub c203 Copier
I have bought a image transfer belt. I need to know how to access area where belt is located. Do I need to be careful in handling new belt
open right door (the door used to remove jam. there are 2 silver levers that have screws holding them down just under the fuser unit. remove the screws and that will release the belt. it wil slide out easily . then replace it. unfortuneatley you did not have to replace it unless it was dammaged... there is a small pico fuse in it that you can replace for like 2 dollars that will reset the counter... if you have more questions drop me a line
Aug 02, 2011 | Konica Minolta Bizhub c203 Copier
Code error p9 p21 p16 c203 what can i do?
The p error codes you have are due to the test pattern being put on to the transfer belt to check the image density control
The first thig to do is to check and see the condition of the transfer belt and if it has reached life or looks bad replace it also on taking out the transfer belt directly where it goes in there is a cover slide the cover and clean out the idc sensors imgae density control sensors
Also there is firmware to correct the issue do this last the above will get rid of your issuesAlso add toner to all the units manually add the toner as well
Feb 11, 2011 | Konica Minolta Bizhub c203 Copier
Error 2451
Sir did you remove all of the tape from the transfer belt. when you installed it the the code has to do with new belt. Pull it out and check for any thing odd.
Apr 21, 2010 | Konica Minolta Bizhub c203 Copier
Konica Minolta Bizhub c203 Copier Logo
784 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
