Question about Kohler Electrical Supplies
I have a 5K gas generator on our boat, its 8 years old runs great till today. It will only run with the start button pushed in. When I release it the engine stops.
    Scholar:
  • 97 Answers
Whats is the model and ser # i will check my diagrams
Posted on Aug 31, 2010
Starts runs great turn off the it won't start again
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Great video on low pressure warning switch removal and ...Pulled off the shroud over the sensor. ... It wouldn't start so I replaced the spark plug, gas, and oil - then it did as yours. ... 1200 Watt Generator Won't start - Duration: 14:49.
gasoline engine on portable generator won't start what do I ...
answers.angieslist.com/gasoline-engine-portable-generator-won-start-I-d...
Apr 16, 2014 - gasoline engine on portable generator won't start what do I need to do ... PULL, Take OUT the spark Plug , make certain it is clean and DRY and then start allover again. ... start then when talking pulling rope use electric starter - if won't ...several times till starts, moving choke to OFF or RUN position once it ...
How To Fix A Portable Generator That Won't Start ' My ...
blog.mygenerator.com.au/how-to-fix-a-portable-generator/
Jan 21, 2016 | Electrical Supplies
Old hotpoint gas dryer will not stay running starts when start button is pushed will stay running if button is held in but stops as soon as button is release
you have a bad push start button test it with a meter for continuity ohms should show ohms when pushed in and none when released
Oct 04, 2014 | Dryers
My bass boat sat for about 8 months. I had it on the water this weekend and it was not idling well and had trouble starting. Once started, the boat ran well when i was in the throttle. I ran the old gas...
SOUNDS LIKE THE CARB LOW SPEED JETS ARE CLOGGED , THANKS TO THIS PITIFUL GAS WE GET TODAY ,I USE A ADDITIVE CALLED SEA FOAM IT WORKS GREAT JUST ADD TO FUEL EVEN WORKS FOR WINTER SET UP TOO
HOPE THIS HELPS
Aug 10, 2010 | Light Outboard Motor Boat Bass Fishing...
Kolher magnum 25--worked great last year,now starts right up but runs full throttle...won't idle down ?????????
a stuck float in the carb can cause this as well as old gas do to schlack build up from gas evaperating the carb should be removed and cleaned with carb cleaner and old gaskets replaced a carb kit will run about $20.00 and avail from small engine shops.
the engine number will be needed for the right kit at the bottom of the engine where it mounts there is a flat boss with a number stamped that will be needed for parts.
when the engine is stored the best thing it to run the engine and shut off the gas and run till it stops this will get ride of the gas in the carb there will still be a small amount left in it but follow recommended long term storage prep from the manufacture. hope this helps
May 04, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Looking for a users manual for a gp1kw series gasoline generator ,having a hard time geting it to start.Already install new spark plug and gas.it a 1000 watt 2.4 hp 4-store engine,it about 2 .5 years...
There is a problem with fuel flow or carbueration. I would look for plugged fuel filter (sometimes within the gas tank, or a stuck float level, or possibly even plugged jets..
Apr 03, 2010 | Electrical Supplies
When I start my 10hp mercury outboard after priming it will run for a few seconds and then die. IF I push the throttle only button and rev it up before priming or set the low idle up higher and then prime...
Be sure to run the recommended fuel mix. most modern 2 stroke outboard engines run on 100 to 1, some times the mix is on a decal inside the cowl.
Cheers, Timo.
Feb 27, 2010 | Light Outboard Motor Boat Bass Fishing...
I cannot keep the pilot light going. It goes
First you want to look at the pilot nozzle. from the very end it should appear to be "8" shaped. If this is not the case than the nozzle must be replaced. This pinch in the center end of the nozzle is the restricter and allows for an even flame to the thermocouple. There are adjustments for the volume of gas to the nozzle but they should not be changed from the factory default settings. Thank you, Dana
Oct 18, 2009 | Cozy (VCR502A-BM) Heater
What is the correct fuel/oil mix for evinrude 4hp ?
the proper mix is 50 to 1 or 16 oz to every 6 gallons,in my little boat I put 4 quarts in the 48 gal tank and its been running for 22 years,your running way to rich and your plug is probaly fouled,take it out clean it up/dump your fuel and mix it right,thats a great motor you got,I hunted with it for years,oh yeah when you get started run it till all the smoke is gone or you will have carb problems ,if you dont have them all ready,a little carb cleaner wont hurt but get it running first,or all that trash will foul you out,have a great trip bartriley1
Jan 04, 2009 | Boating
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
143 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
