Question about Garden
TORO WEEDEATER WONT RUN UNLESS FUEL TANK IS COMPLETELY FULL
  • 183 Answers
Sounds like your fuel lines have broken or hardened and aren't reaching the fuel when the level falls. Replace both (or 3) fuel lines (one at a time) and don't forget to put the pickup filter back on. You can get the lines at your local mower repair shop for less than $5 for the 2 foot of line that it takes to replace all lines.
Posted on Aug 23, 2010
Toro snowblower surges what could be wrong? Any help will be appreciated. Thanks
Try removing the needle from the carburetor and soaking it in brake fluid (and any other parts that may look suspicious) over night; clean and regap or replace spark plug; ...also, try using high test fuel.... this runs cleaner on my Toro826.
Jan 06, 2018 | Toro Garden
Toro Grandstand with Kawasaki FS541V engine runs in idle but dies when throttled up and will not run at full throttle.
lack of fuel is the problem
could be blocked main jet ( most likely)
in tank filter could be blocked (part of the tap if screwed directly into tank)
tap corroded inside preventing full fuel flow
needle and seat obstruction restricting fuel flow
Jul 18, 2016 | Toro Garden
Weedeater starts but won't run for more than 30 seconds
A lot of times the line that in the tank deteriorate so you mean may need to replace the line in the fuel tank
Aug 12, 2014 | Makita Em4251 24.5cc Gas Powered String...
Gas leak at grommet on gas tank where gas lines enter and leave tank
Yes you should be able to replace the rubber tank seal that the fuel line goes through. Be sure to replace the fuel line(s) when you do.
Apr 01, 2014 | Toro 2-Cycle 25.4 cc Straight Shaft Gas...
Toro weed eater starts but then stalls out
A few things to check, clean or replace:
  • fuel filter - located inside the fuel tank
  • Spark arrestor - located at muffler
  • Spark plug
  • Carburetor
Mar 08, 2014 | Garden
Engine keeps flooding out
Recommend completely draining the fuel system. Tank, lines, and carb. Make sure everything is clean and dry. Clean or replace fuel filter. Always try to store it with a full tank of fuel. It is common to get condensation when the weather goes from warm to cold and back.
Jan 31, 2009 | Toro Blowers Rake and Vac - Electric...
Gas weedeater wont start
assuming weedeater brand weed eater, the carb. has a filter screen, that blocks and does not allow the pump to push sufficient fuel. A phillips head screw on the side of the carburettor secures a square plate, remove the screw and plate and gently brush the screen clean, dirt collects on the visible side.
Dirty foam filters if fitted change the fuel mixture and make it too rich to run.
and the fuel mixture knob, although secured by a tension spring, moves and may need to be readjusted
Jul 30, 2008 | Electrical Supplies
Garden Logo
142 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
