Question about Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer
PP335 Trimmer Pull start cord won't retract. How might I go about fixing this problem?
5 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: I have a poulanpro gas
Hi btimms3...
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indetion in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jul 17, 2011
rycgl
  • 1545 Answers
SOURCE: on my 17" straight gas trimmer the pull cord will
Remove the tube that holds the flex drive from the end of the crankshaft. Lossen and remove the front cover. Remove the throttle cable from the carb. Remove the kill switch wire from the coil module. Remove clutch housing. Remove clutch, Remove flywheel. The recoil unit mates with the bottom of the flywheel and all the aforementioned parts are on the front side of the engine's crankshaft. Once you get the recoil unit off, you remove the old cord and turn the unit several times to "preload" tension on it. Insert the new cord into the guide holes and tie knots to lock it in place. The pull handle must be attatched too or when you let the recoil draw in the new rope, it will keep going and all tension will be lost. Reassemble all the above and good luck!
Please vote on this solution.
Posted on Aug 31, 2010
#1 Taper
  • 1040 Answers
SOURCE: I have a poulan pp335 trimmer. It starts but when
Try a couple of my Tips out. They will solve your problem:
www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
Good Luck!
Jim
Posted on Aug 04, 2011
Testimonial: "I really appreciate your help--Your suggestionswere very helpful. "
dave_gold
  • 37 Answers
SOURCE: Describe your Poulan/Weed Eater No.
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Posted on Aug 12, 2011
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
I have a Ryobi Expand-It 2 Cycle 26cc Trimmer , and when i attacthed the pole trimmer and tried to start it the pull cord won't retract.. do you know how to fix this? i can't get the cover off
the ryobi expand-it is just a power head ( motor ) that you can attach any ryobi or like attachment to
There is no reason why attaching a pole trimmer would affect the recoil of the starter rope as it just slides onto the drive at the end of the shaft
the fix will require the removal of the cover and the tool will be in a selection of bits that you can get from a good tool shop or auto parts shop
from memory it is a 6 point star around 3mm in size
the failure to recoil is normally a broken coil spring
Oct 30, 2017 | Garden
Pull cord will not retract
This takes some mechanical skill and knowledge to fix...definitely would take it back..I would have thought these manufacturers could have fixed these idiotic quality control problems by now....it goes on and on and....I know, folks would say..ya get what ya pay for....so in this case, you paid for a useless machine that you never even were able to use...that is NOT what you were SUPPOSED to get now was it!
Jul 14, 2010 | Husqvarna 28cc Gas Line Trimmer
Pull cord stays out, won't retract. I took apart
the end of the spring may be broking you can fix it by taking it out and heat it with a small fire until it is red hot and bend it
Jun 26, 2009 | Homelite Mighty Lite Lawn Trimmer
Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer Logo
340 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
