Question about Samsung Digimax A7 Digital Camera
My samsung digimax a7 says card error when i turn it on - it then goes to SET - format but doesn't respond to yes or no I'm worried about losing my photos off the memory card
  • jacksoncl66 Aug 23, 2010
    advice says to save photos before trying alcohol on the connectors but the card reader in my laptop doesn't recognise the card - does this mean my photos are lost?
  • 977 Answers
Hi!
Please try the following:
1) Take a look at the memory card; on it's left side there's a little switch. Make sure it's it the UPPER position.
2) If still the same, use a card reader/adapter to connect the card to a computer. Try copying it's contents and/or format it again.
If none of the above worked for you, I afraid it sounds like your card has gone... Some special store MAY be able to save your data/photos from it, but unfortunately, nothing is 100% guaranteed!
Best regards abd good luck,
Pelu.
Posted on Aug 23, 2010
  • Samsung Master
  • 4,924 Answers
First get the card from the camera and insert it in a card reader or in a laptop with card reader and get all the pictures from the card to save them ..
after that be sure that the card is not locked from the locking slide that it placed on the right side of the card ..than clean the contacts with some alcohol based solution ..(it might as well be a perfume or anything with an alcohol base..) and insert it again in the camera with care ..agin ..and again until will recognize it ...if it asks for format it ..it means that it has an error but the card is seen ..so if you saved the pictures you can try to format it ..if it do not want to in the camera ..try to format it in teh card reader ...by right click on the removable disk in the my computer folder..than choose format ..click on quick ...and select fat 32...and go for it ..
after that try again to see if you get rid of the files from the card that caused the error ..cause sometimes if you use the card and have files that the camera is not able to read this can also cause card errors..
  • Catalin Turcu
    Catalin Turcu Aug 24, 2010
    if the card reader in the laptop do not see the card either this means that the card itself it is damaged and if you will not be able to make it readable again the pictures are lost ...I suggested to clean the contacts cause sometime oxidation make them behave bizarre and this might be a case.....but what you need to do is see if you can fin a position in which to make the card seen and take at least the photos from it ..
    Anyway if after all these it still can not read it..it means the card is dead for some reason ..
  • Catalin Turcu
    Another thing ...try it in another laptop also ..cause it may be the case when the card reader in the laptop is not installed..-I mean the driver is missing for some reason ..
Hi how do i formatt my camera card
From page 63 in the manual.
Format
Internal memory format : Remove the SD memory card to format the internal memory.
SD memory card format : Insert the SD memory card to format the SD memory card.
All the files in the memory are deleted by the [FORMAT] function.
Before formatting the memory, it is advisable to copy important data onto other media as back-up
e.g. floppy disks, hard disks, CD etc.
1. Turn the camera power on.
2. Select the PLAY mode by rotating the mode dial.
3. Do not turn the LCD monitor off.
4. Press the MENU button to display the menu on the LCD
monitor.
5. Press the UP( )/ DOWN( ) button and select [DELETE].
6. Press the SET( ) button and the sub menu will display.
7. Select [FORMAT] by pressing the UP( )/DOWN( ) button
and press the SET( ) button
8. Select [NO] or [YES] and press the SET( ) button.
[Selecting NO] : The image will be displayed on the
LCD monitor.
[Selecting YES] : A [PLEASE WAIT!] message is
displayed and all of images are
deleted.
Link to manual:
http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=2702&prd_mdl_cd=EC-D201ZSBA/E1&prd_mdl_name=DIGIMAX%20201&srchword=digimax%20201
Jul 05, 2011 | Samsung Digimax 201 Digital Camera
My Samsung Digimax A7 camera will not load memory cards. I insert a card and then turn on the device, which prompts a format for the card then I hit yes, the camera thinks for awhile then just turns off. ...
The Digimax A7 may not be compatible with "High Capacity" SD Cards (SDHC). If this is the case you will need to locate an SD card that is 2GB or less in size as anything larger than this is a high capacity card.
SD card wikipedia page
Mar 01, 2011 | Samsung Digimax A7 Digital Camera
Comes up with format then check sd card
I've had this problem too.
Your Samsung Digimax L80 accepts SD Card cards.The largest SD Card card you can use in your Samsung Digimax L80 is 2GB anything larger and it doesn't work.
Jun 03, 2010 | Samsung Digimax L80 Digital Camera
Samsung digimax 4010 camera has error message.
tis logical that sumsung digimax 401 cannot procees a 2gb memory card, use 1 gb will format ok.
May 11, 2010 | Samsung Digimax 4010 Digital Camera
My samsung digimax A7 says 'memory full' even when the memory card has nothing on it
If you've downloaded all the pictures from the card, format it in the camera. This should solve the problem.
Oct 09, 2009 | Samsung Digimax A7 Digital Camera
My samsung a7 wont format 8gb card
The A7 uses SD cards, which max out at 2GB. It will not work with higher-capacity SDHC cards.
Jun 19, 2009 | Samsung Digimax A7 Digital Camera
Format error
The reason why is because that particular camera does not support memory cards that big.  Samsung only guarantees compatability up to 512MB, but the max I have ever heard working is 1GB.  If you do buy one, make sure it is a sandisk card as these have been tested and guaranteed to work in that camera.  Lexar may also work, but for sure 4GB is to big and is unsupported.  Hope it helps.  Please dont forget to rate!
Mar 03, 2009 | Samsung Digimax A40 Digital Camera
Card error samsung s730
I own a Samsung S730, i downloaded all the drivers on Vista Home, I tried formatting the SD Card but it says CARD LOCKED, and it isnt. Any solutions
Oct 25, 2007 | Samsung Digimax S730 Digital Camera
Samsung Digimax A7 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
