My computer is connected to a 2700hg-b wirelessly,it says it is connected to the network but not to the internet.could you tell me what the problem could be.
  • 77 Answers
Hi there!
I have to ask you about these info:
1. What's your OS (Windows XP, etc.)?
2. Do you have other computers in your network that are working? If Yes, then are they wired or wireless computers?
Posted on May 04, 2008
The wireless computers on the network are working. The computer that is wired to the router keeps giving the message Cannot renew IP address. The icon shows limited or no connectivity
reset the router if not change the network cable. if it does not fix the problem you need to call your internet provides be cous my be need to configure the settings from router
Nov 22, 2010 | 2wire 2700HG-B Router (2700HGB)
Can't Reconnect to Secure Wireless Network
there is a problem with your WEP key, means the password which is used to enter your router or network. simply delete the network from the network list and connect to the network again and insert the correct shared key.
May 03, 2010 | 2wire 2700HG-B Router (2700HGB)
I have lost my wireless connection on my laptop
Delete the Existing wireless connections in the laptop and create another one
This should fix the issue
Jan 03, 2010 | 2wire 2700HG-B Router (2700HGB)
I hooked up wireless internet and my main coputers internet isnt
check the connection or from where u r connected the wireless connect just see that the problem will be solved ok
Aug 22, 2009 | 2wire 2700HG-B Router (2700HGB)
Wireless Internet stopped working. Can't reconnect.
If restarting the router and restarting computer did not work (unplug both power cables), then you need to log into the router and check network settings.
To log into router type the router IP on internet explore bar, then enter user id and password.
You find details on how to do this, IP and passwords listed on the owner manual.
If wireless security settings on router are fine, then you can reset router to factory default using the pinhole switch. You will need to enter all your broadband settings to have the router working afterward.
Apr 27, 2009 | 2wire 2700HG-B Router (2700HGB)
I would like to get my wireless modem light on....how do I do that (how do I get my wireless modem to go wireless).
Go into 192.168.1.254, then go to "Home network", then "Wireless settings" put your network name in the blank box.
Mar 07, 2009 | 2wire 2700HG-B Router (2700HGB)
Having trouble staying connected to the internet
Thank you.
First, make sure that the wireless switch on your computer is on.
Then try following these steps:
1) Go to Start and click on Connect to.
2) Connect to a network window will appear. This window will show all available connections, which are dial-up, VPN and wireless connections, but your focus is on wireless connections. Scroll down the list and select the wireless network that you wish to connect, finally click the Connect button.
Note: If the network you choose is security-enabled network, means require authentication. One of the following will occur:
- If the network key is automatically provided by your network or system administrator (that is, the network supports IEEE 802.1x), the connection will be made automatically.
- If the network key is not automatically provided, type in the key. The key can be WEP/WPA/WPA2 encryption key.
Note: If you see the network is tagged as unnamed network, that is non-broadcast network with hidden SSID. When you make connection to this type of network, you will be prompted to type the wireless network name (SSID).
3) Once you connected to wireless network, the connection will show connected.
Then, you can go online. :)
Apr 29, 2008 | 2wire 2700HG-B Router (2700HGB)
Home network with 2700hg-b and netgear wireless issues
You didn't say what operating system you have but check your Network and Sharing Center in Control panel and turn on the file and printer sharing feature in Windows.
Using Vista, click on Control Panel- Click on Network and Sharing Center-configure settings.
Hope this helps.
Mar 24, 2008 | 2wire 2700HG-B Router (2700HGB)
Wiring up 2700hg-b wireless router
Hi, you will need a ethernet card in the pc to connect up a wireless router, most dont work with usb,
otherwise you would need a wireless adapter.
once you do get it connected, go into internet explorer and type in the ip adress for the router, will then come up with a menu for you to programme in your broadband details, once you get the router up and going, go into the PS3 settings, network settings, it will pick up the router all you need to do is enter the network key and its all go from there.,
ethernet card should cost you about £10 from any shop
Happy New Year
John
Jan 01, 2008 | 2wire 2700HG-B Router (2700HGB)
Wiring up 2700hg-b
Just run an ethernet cable from the back of the PS3 to the back of the router
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
