Question about Acer Computers & Internet
My laptop wont go passed the setup page where the loading bar is
    Problem Solver:
  • 9 Answers
Your hard drive maybe corrupted. You may have to clean your hard drive and reload the operating system.
Hope this helps, Other wise holler
Posted on Aug 23, 2010
Lenovo stuck on loading page, and wont enter safe mode
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
Jul 14, 2012 | Computers & Internet
My laptop won't boot up properly. It gets to the screen with the dell logo and the loading bar but the bar only fills about 3/4 of the way. It also begins beeping as soon as I turn it on. I tried to push...
Your RAM may be bad the beep is a bios checksum error letting u know that the CPU or RAM did not pass its test. It will not allow you to to get past the preboot test until it passes all its test. Replace the ram and u should be ok again.
Sep 19, 2010 | Dell Studio 1537 Laptop
I have a Belkin Router Wireless N. I have a laptop that I am trying to add to router but i need Network Key /WEP/wpa key. I know my pass words but not these.. Please help
1.Look at the back of the router and connect your laptop to any one of the 4 grey slots
2.In your laptop open IE and in address bar type 192.168.2.1
3.It will open a belkin router setup
4.In the belkin Router page select SECURITY in the left hand side
5.It will ask u a login Pwd . its blank Click submit
6.In the next page u can see the Security Mode - If it is WEP - KEY 1 will be your PWD
7.If the PWD is WPA . The Pre shared key or password PSK will be the PWD . Uncheck Obscure PSK to view the PWD .
Aug 24, 2010 | Belkin (F5D7230-4) Router (587009)
My Acer Aspire 1500 laptop wont pass startup.
It seems that your laptop hardware is good and it seems that it is a software issue.
  1. Boot in safe mode: When your laptop start, press the F8 key. then it will ask you which boot device to boot from, browse using the arrow keys and chose something with HDD and press ENTER and then press the F8 key again. Then you will be given a boot option and choose SAFE MODE.
  2. While in SAFE MODE, try to uninstall your newly installed software that might be causing the laptop to hung up.
  3. Also, click Start => Run then type: msconfig.
  4. Go to the Startup Tab and uncheck the many programs that looks not necessary to load while windows is loading. The program like Yahoo Messenger, Skype can be opened manually so uncheck them if present.
  5. Click Apply then OK.
  6. Restart your laptop and see if it helps.
Feb 23, 2010 | Computers & Internet
My laptop wont turn on properly, or really at all. when i turn it on the page comes on which says dell.com, that blue bar at the bottom loads and thats it.. its stays on but nothing happens. what could be...
There could be damage to the Boot Sector files or a problem with the hard disk drive.
First run diagnostics on the hard drive (Fn Key plus the Power Button) see if the hard drive fails diagnostics. If it fails the diagnostic, then replace the hard drive. If it passes, boot to your Windows XP CD, enter recovery console by pressing R at the 1st prompt, then run the command: CHKDSK /R <enter>
Dec 18, 2009 | Dell Latitude D600 Notebook
Turns on but wont go pass the startup screen
Try to put an operating system boot disk in your drive then turn on laptop.
When the screen says press any key to boot from cd/dvd press a key.If it is vista when you do boot from cd it will give the option in the lower right corner to repair-click on this-select repair startup option.if that fails try a re-install of your op sys.
May 31, 2009 | Acer Aspire 5610 laptop vista combo with...
ROUTER SETUP F5D8232
connect ur router to the pc with ethernet cable and put the wire connector in one of the port on ur router back then
go to internet browser type 192.168.2.1 in address bar a page will open and on this admin page setup ur preferences as WEP security and other options for ur router setup when u are done save it then come out of it close the browser
now power cycle router and then connect ur internet source to the router back port marked INTERNET and then on ur pc or laptop switch ON the wireless lan and then try to connect if u have setup pass key it will ask for passkey enter the same as set by u and then go browse the internet once it says connected
i can provide more help on whatever issue u have i have understood this from ur question pls clarify ur problem if u want anything else i am expert in this category
Pls RATE ME WELL !
Regards
Zohail
May 20, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Acer Aspire5170. Vista. Was running fine, i uninstalled a few unwanted programms, cant remember which, it needed a restart inorder to complete the uninstalls, but i didnt. my sister then closed laptop, so...
U HAVE TO ENTER THE SETUP FUNCTION WHEN U FIRST TURN ON THE COMPUTER , PAY ATTENTION TO THE SCREEN AND IT WILL TELL U WHAT KEYS TO HIT IN ORDER TO ACCESS THESE MENUS. CHANGE THE BOOT ORDER TO BOOT FROM THE CD AND THEN PLACE UR DISK IN THE COMPUTER BEFORE EXITING THE SETUP SO WHEN U RESTART THE COMPUTER IT BOOTS FROM THE DISK INSTRUCTION
Aug 04, 2008 | Computers & Internet
Wont go to websites when Itype words- only accepts numbers
Open Internet Explorer, under the tools tab, select "Internet options". Once there, select the "Connections" tab. At the top you will see, "To setup and Internet connection, click "Setup", click on "Setup", once there, click "next", On the next page, make sure "connect to the internet" is selected and click next. On the next page click, "Setup my connection manually", click next. On the next page select(Make sure it reads exactly as follows), "Connect using a broadband connection that is always on", click next. On the next page, click "finish". That should do it.
Nov 19, 2007 | Acer Extensa 367D Notebook
Computers & Internet Logo
15 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
