Question about Thermador RDDS30 Dual Fuel (Electric and Gas) Kitchen Range
My gas burners won't ignite. The gas is flowing but there is no clicking sound. Sometimes one of the burners does ignite, bu that is rare. Any idea what could be causing this?
  • Thermador Master
  • 43,501 Answers
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Posted on Aug 23, 2010
Stove burners won't light
sounds like the igniter is faulty try a local h/ware or plumbing shop for a new piezo ignition
Feb 02, 2013 | Hotpoint RGA524 Gas Kitchen Range
We have a Whirlpool Gas Range, model SF357PEKQ. When I start the bake feature, you can hear the gas flow, the ignitor click (about 4 times) yet there is no ignition of the gas (flame doesn't start)....
Whirlpool had some grounding issues with some of their electronic ignition ranges. Make sure your outlet is grounded first. Then you might need to make sure the bake burner itself is grounded very good against the range frame. I have put star washers between the burner and frame and tightened very tight, that sometimes helps. Also make sure the holes in the burner under the spark electrode are clear from debris. Sometimes the burning of gas leaves a residue that can stop up the holes and not let the gas flow out where the spark is hitting the burner. Hope that helps.
Aug 29, 2011 | Ovens
Frigidaire professional series gas stove does not light. When handle is turned the "clicking" sound happens, with the smell of gas but no flame. what could be problem? 3 other burners work...
A few months ago I lost one igniter on the left front burner. It clicks and gas flows but wont ignite.Now when I turn on the left back burner, the gas still flows but I hear clicking on the right side, not from that burner. It wont light either.
Dec 17, 2010 | Frigidaire FEF336BC Electric Kitchen Range
I have a magic chef oven model # 61S04PAW. the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 07, 2010 | Magic Chef 31000 Gas Kitchen Range
Dacor gas range. I'm trying to figure out why it
Jul 01, 2010 | Dacor Preference RSD30 Gas Kitchen Range
I have a tappan gas range all the burners but one works when i turn it on. You can hear the flow of gas, and the oven doesnt work. what could that possible be
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 25, 2010 | Tappan 24 in. Freestanding Gas Range...
I have a kenmore gas range with electric ignitors. My question is that my stove top doesnt ignite but lets gas by and I can use a lighter to lite them. However my oven doesn't do anything...no gas no...
Nov 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Burner not stayinyg lit
since burner is igniting, it probably is OK. next check is limit switch. this switch shuts the gas off if it senses excessive heat (blocked vent ... usually caused by lint) limit switches themselves MAY go bad ... bu rarely PS check to make sure the vent is blowing exhaust to outside of house (i've seen birdnests in the exhaust port cause your problem)
Apr 27, 2009 | Dryers
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool oven won't ignite
you do have a problem that needs to be attended to by a certified tech.you same to have a gas flow problem.maybe a valve problem.
Jun 03, 2007 | Whirlpool GS445LELS Gas Kitchen Range
Open Questions:
See all Thermador RDDS30 Dual Fuel (Electric and Gas) Questions
Thermador RDDS30 Dual Fuel (Electric and Gas) Kitchen Range Logo
414 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
