Question about Logitech X-530 Computer Speakers
Logitech X-530 Speakers System
Only do work, but the rear and center do not, I have all connections in place and right, any help?
  • 1 more comment
  • eloziom Aug 16, 2008
  • anettta Aug 29, 2008
    it is not the speakers (I shifted them around) and I doubt it is the connection. My sound card (Asus) is VERY clearly marked as to color and it is the same color as the logitech cables, orange, green, black, etc. and the instalation comes with specific instructions. Just in case, I did try all other plugging combinations. I do not get sound from the center (red on subwoofer) or back speakers. Only front right and left work.
  • kate_doornbo Dec 30, 2008
    Hi, I just got a refurbished set of logitech x-530 speakers too and i'm having a hard time connecting them to my dell e 1505 inspiron notebook. Does anyone know if a usb 5.1 exeternal audio card like this one
    http://www.buy.com/prod/usb-5-1-channel-...
    would help at all?
    President:
  • 2,712 Answers
There are several reasons why there is no sound coming from the rear speakers.
  • Improper connection of the signal cable is a possible reason why there is no sound coming from the rear speakers.
Logitech X-530 Speakers System - 7949.jpg Green connector is for the front left and right channel. Black connector is for the rear left and right channel. Orange connector is for the LFE (Low Frequency Effects) subwoofer and the center channel.
The connectors for the Logitech products are color coded as explained. The connectors on the sound card may not be color coded or a different color coding maybe used depending on the manufacturer of the sound card. Check the manual for the sound card to make sure the correct connector is connected from the Logitech speaker to the sound card.
  • After verifying that the connections are made correctly, the sound card needs to be checked to make sure it is setup correctly. There are many sound card manufacturers so we cannot possibly cover every make and model. We recommend contacting the manufacturer of the sound card to make sure the sound card is setup correctly for use with analog 5.1 speaker systems.
  • When a software DVD player is being used to watch a DVD, the audio output needs to be set to surround sound mode. Please refer to the user manual for the software DVD player to check the settings.
Many DVDs have more than 1 sound format available. Just as the sound card and the software DVD player, the DVD itself has to be set to the correct sound format.
  • Finally you can test to see if the speakers are working correctly by plugging the front channel cable coming from the sound card to the rear channel connector on the subwoofer. If sound comes out of the rear speakers, then there is no problem with the speakers. The problem could be with the software DVD player, or the audio setting on the DVD.
THIS article can be used to test if your speakers are indeed working.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
Hi .. i have just bought a logitech x 530 speaker and only 2 of the speaker parts work .. can you please give me some solution advice?
Hi names Rui i like to help you by giving you step by step instruction in propely hocking up your logitech speakers:
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
Jul 18, 2011 | Logitech X-530 Computer Speakers
I have all speakers hooked up but i only hear sound out of the left and right frond speakers. The center and both right and left rear speakers i hear no sound
You`ve connected only the green jack from the system,you need to connect all the tree of them using the adapter you got in the package
Jul 12, 2010 | Logitech X-530 Computer Speakers
I just installed an azuntech 7.1 sound card and i only have front speakers working.I'm using logitech X-530 5.1
You need to connect the Green wire, the black wire and the orange wire. The Green is front speakers the black is rear speakers and the orange is for a center channel. After you have done that you need to go into sound settings for your sound card and make them that way.
Apr 06, 2010 | Logitech X-530 Computer Speakers
Could you tell me what plug in ports i need for X540 or 530- on my desktop
You need three ports in order to use all the speakers 5.1 sound. They are all headphone jacks but they are front speakers, rear speakers, and sub/center
http://www.newegg.com/Product/ImageGallery.aspx?CurImage=36-121-006-S04&SCList=36-121-006-S01%2c36-121-006-S02%2c36-121-006-S03%2c36-121-006-S04%2c36-121-006-S05%2c36-121-006-S06%2c36-121-006-S07%2c36-121-006-S08%2c36-121-006-S09%2c36-121-006-S10%2c36-121-006-S11&S7ImageFlag=2&Item=N82E16836121006&Depa=0&WaterMark=1&Description=Logitech%20X-540%2070%20watts%205.1%20Speakers
8th pic
X-530 logitech surround speakers how do I install please
coming from the speaker with volume control, there is a cable with 3 jacks, connect them while your computer is running, yellow to pink, green to green, black to blue. a window should open asking what you connected. green is front, yellow is center/sub, black is rear
Dec 27, 2009 | Logitech X-530 Computer Speakers
One speaker is musch louder X-530
On the TV sound options see if there is a balance option. Adjust according to taste if there is that option. Hope this helps.
Dec 24, 2008 | Logitech X-530 Computer Speakers
Logitech x-530 rear speakers and Center speaker not working
you have to go to your audio output setup (try to look for an audio-related icon on your taskbar - next to time display)
setup your audio output for 6 channel or 5.1channel output (depending on software)
follow on-screen description of where to plug in your speaker jacks - green, peach and black.
enjoy...
Dec 02, 2008 | Logitech X-530 Computer Speakers
Speakers not working correctly
pls swap the spk pin in to your sound card jack socket . bye
Sep 22, 2007 | Logitech X-530 Computer Speakers
Sound not coming out of the rear or center speakers
Sort of confused a bit I understand you buying a new system you say the sound does not come out the rear and centre speakers does the sound come out of any spearkers other than the two you mention if it is then your wirings are wrong if the sound is not coming out of any speakers then its the sound card BUT you will know this immediately you disconnect that system. The sound would be coming out of the laptop ordinaryly? which is it?
Sep 04, 2007 | Logitech X-530 Computer Speakers
Logitech X-530 Computer Speakers Logo
539 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
