Question about Toyota SE-06 Mechanical Sewing Machine
There seems to be a thread jam in the bobbin area, and machine wheel won't more back or forward, cannot get to the jam
  • 340 Answers
Have you tried to unscrew and remove the needle plate?
Posted on Aug 23, 2010
Singer 328K is jamming.
Most likely there are jamming threads at bobbin room under the machine stepping pedal, try to dismantle it to get rid of these threads.
Sep 22, 2017 | Singer Sewing Machines
How do I get the needle to move; it is frozen?
Hold the wheel and gently move back and forward, if it doesn't,t release you will have jammed threads in the bobbin and spool area , take apart and clear then you should be good to start agaian
Mar 06, 2015 | Sewing Machines
The needle wont move
You need to look into the bobbin case for rags and thread. Clean this carefully. Check for rags and thread that is stuck in the feed dogs. You may need to move the hand wheel backwards and forwards to get it going again. Once you get it moving check those areas you previously checked again. Before you put the bobbin case back in place a drop of oil on the race track.
Aug 23, 2014 | Simplicity Sewing Machines
Makes one stitch then abrupt stop with threads bunching up from bottom
Have you taken the bobbin out and made sure there is nothing caught in the bobbin race area. Maybe even unscrew the plate and take the whole bobbin race assembly apart and clean well. Once that is done put back together then re thread machine. Next I would start by hand turning the machine and doing some stitches slowly with the fly wheel make sure to to forwards only never turn the fly wheel back wards. If everything seems clear give it some power slowly and see how it goes.
Feb 11, 2014 | Singer 9960 Quantum Stylist Sewing Machine
Thread becomes jammed in reverse
Reverse can be tricky if the machine is not timed correctly. So try this. after you've stitched forward for a while, use the hand wheel to bring the needle all the way down into the fabric and let it come part way up. Then push your back button and take your back stitches. If that works for you then you know the machine should be checked for proper timing.
Oct 02, 2013 | Singer Sewing Machines
The needle is stuck in the Shark 612C model sewing machine, any solutions?
Try http://www.fixsewingmachine. com I also suggest that you clean bobbin case. Now, when needle is "stuck", this requires patience and care in "jiggling" the hand wheel to and fro until needle point begins to clear the jammed area. Carefully snip one thread that moves up under needle and jiggle hand wheel by carefully turning hand wheel toward you to see if you can move the take-up lever all the way up to the UP position. Look at bobbin case area and remove bobbin. Cut bobbin thread and remove bobbin case. Sweep gently with brush underneath case and carefully, gently sweep over the feed dogs, poking very ends of brush bristles into "teeth" area to remove lint, fuzz ball/s, and any loose thread/s. Raise presser foot, remove (possibly bent) needle. Insert new needle of appropriate size for fabric weight. Make sure needle pushed all the way up into needle bar groove, at side to back. Keep presser foot RAISED while rethreading. This allows thread to locate tension discs, and HOLD THREAD TAUT. Replace bobbin, making sure thread is EVENLY distributed on it. Imablanced bobbins cause jams, and bobbins with burrs and scratches can real havoc as well as the hook part of the shuttle where the bobbin fits. Smooth such areas with emery cloth carefully, ever so gently. Hope my suggestions are a solution for you. Jimmy
Apr 06, 2012 | Euro-Pro Shark 60 - 384
The thread hangs up inside the bobbin holder
A jammed machine is caused by thread being caught in the hook. Remove the upper thread and the bobbin case, turn the hand wheel towards you (counterclockwise) by hand and remove any thread in the bobbin case area. *Always turn the hand wheel towards you. Turning the hand wheel away from you (clockwise) can cause the machines timing to become unaligned and jam your machine. Also, always make sure the presser foot is in the down position before you start sewing. Sewing with the presser foot in the up position will jam your machine in the bobbin case.
Sep 26, 2010 | Singer 2517 Mechanical Sewing Machine
The bobbin thread will not pick up. The machine had jammed and I forced the wheel and can't get bobbin thread to pick up. When I thread manually, I only get holes, no stitches. Is it a timing belt?
check your needle to see if it's bent---roll on flat surface to see if it roll correctly
on some sewing machines when the thread comes off the thread take up lever it can cause the machine to jam
also if the bobbin thread becomes tangled it can jam
check the bobbin area for lint or loose threads
try having a top thread tail & bobbin thread tail of 3-4 inches
try holding the top thread tail & turn the handwheel on the right side on the machine manually & put the needle down into the bobbin area & see if the bobbin thread will pick up that way
Sep 24, 2010 | White Sewing 2037 Mechanical Sewing...
Sewing machine jammed wheel will not turn
Thread is caught in the hook...Remove the upper thread and bobbin case...turn the hand wheel backwards and forwards by hand and remove the thread remands. Good Luck
May 17, 2009 | Brother CS-8060 Computerized Sewing...
Toyota SE-06 Mechanical Sewing Machine Logo
103 people viewed this question
Top Toyota Sewing Machines Experts
Tally Girl
Tally Girl
xxxxxx xxx
Are you a Toyota Sewing Machine Expert? Answer questions, earn points and help others
