Question about Panasonic PT-65WX51 65" Rear Projection Television
Samsung sp42w5hfx stanby light flashes and clicks wont start up
I have just had the 2 ics changed for a convergence prob stk392 -040 but i noticed on the old ics they both stated on them stk392-040 but had diff model numbers on them are there 2 or 3 ics to be changed as you have blue red and green it was only the red that was a pain but changed both use heatsink paste soldered perfectly but now when i turn tv on the standy clicks and makes a little squel noise then goes to click again like in a loop where did i go wrong i put all the wires back exactly as i disconnected them please help any ideas
    President:
  • 2,712 Answers
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other). The sound comes from the flyback unit. I guess it must be a high pitched squeal, and click noises.
Also check for cold solders.
You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.
If is better to change all the CRT's at the same time if one is replaced. Same with the IC's. Look for bad resistors, or bust capacitors, especially around the heat sinks. Once again, if you are changing one, might as well change all 4 (I think its 4-6) resistors. It will serve you well in the long run.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 04, 2008
  • 3,037 Answers
If the serial no of the set is earlier than 3KPW358179 you need to replace all 3 CRT's.
Also check RZ144 and RZ145 which I think may be 3R9ohms.
Let me know if you have any further questions, thanks
  • Benjamin Patri
    Benjamin Patri May 07, 2008
    Please don't forget to rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to help.
    Thank you
    Sergeant:
  • 395 Answers
First check for solder bridges on your work even the best solderers can bridge solder (even myself). if this is a seperate board. then unplug the power lead to the convergance board. if it is not a seperate board and is part of the main board then unplug just the convergance yolks turn the set on and set the convegance back to factory reset in the menu. unplug the set and return the wires back. then turn on the set you should be able to do a flash focus to return the convergance. if the set doesn't turn on after retuning the wires then check for open pico fuses or bad resistors in the convergance circuit.
The TV was working en shut him self off. Wont start now .
This may be caused by convergence IC's being defective and some resistors around them not being the proper values.
I have repaired another Hitachi model Rear Projection TV that would start up and click click click and flashing red light, then replaced the convergence IC's STK392 series and a few burned up resistors and good as new :)
You will have to be handy with a soldering iron to complete this task, and there is a kit you can buy also http://www.tvrepairkits.com/xcart/60sbx78b/ it comes with everything you need and even teach you how to solder if your not already good at it.
Hope that helps
Christopher
May 15, 2012 | Televison & Video
TV wont turn on but it does make the clicking noise as it is trying to do so, the power light flashes three times and extinguishes
The three blinks is an error code indicating that the convergence has failed. You can get the PT47WX49 convergence repair kit from www.tvrepairworld.com whih has the 2 Convergence ICs and The 6 low ohm resistors plus the CD with repair instructions.
Aug 31, 2011 | Panasonic PT-47WX49 47" Rear Projection...
My samsung sp42w5hfx the picture is like its in 3d can i fix it and how
This is a convergence problem and is quite involved to fix. I suggest you get a tech/ They have the right tools to generate a pattern to correct the problem as well as warranty on the replaced boards required to fix this problem. It's not a DIY for amateur
Please rate my help++++Thanks for using FIXYA
Feb 28, 2010 | Televison & Video
Samsung rear projection tv wont turn on.
Replace your STK ics both of them. STK392-040 go by number on parts
Nov 15, 2008 | RCA D52W19 52" Rear Projection Television
Won,t turn on.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. check the vertical deflection IC and circuit
Nov 05, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
caypianan@yahoo.com
Jul 18, 2008 | RCA HD52W58 52" TV
SAMSUNG REAR PROJECTION TV SP42W5HFX - WON'T TURN ON
common problem with these sets is the convergance ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
however with out troubleshooting it it's hard to tell you might want to contact pts see how much to fix the board.
http://www.ptscorp.com/
Dec 14, 2007 | Televison & Video
Convergence Problem...now won't turn on!
You most likely shorted one if not both new IC's and that will cause the set not to start. I would say that replacing the board is probably the best bet but, be careful of plug placement.
Nov 30, 2007 | Samsung HCM5525W 55" Rear Projection...
Convergence problem with samsung sp42w5hfx
Hi.
Post your email address & I will send convergence set up manual.
http://dysonmanuals.inc.io/
Chris..
Nov 04, 2007 | Televison & Video
Samsung rear projection sp42w5hfx convergence problem
Compare IC connections with meter = check solder joints to
see if some are touching one another. Tell me exactly what
brand & part number was installed...........T.
PS. The red,green,blue plugs may be mixed up because the green should stay and red & blue move !
Nov 03, 2007 | JVC AV-48WP74 48" Rear Projection...
Panasonic PT-65WX51 65" Rear Projection Television Logo
146 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
