Question about Amana ARB2557CW / ARB2557CB / ARB2557CC Bottom Freezer Refrigerator
I have an Amana BRF20TW. Anything I put in the crisper drawers and the bottom shelf of the refrigerator gets frozen. I have adjusted the temp settings and it still does it. Please help.
watugot
  • 290 Answers
SOURCE: Humidity-Controlled Crisper Drawers
If you will post the complete model number including the string of digits starting with P, (if it has these) I will look it up and see what I can find.
You can usually go to sears.com, click on parts, enter the model number from the fridge decal, and pull up a parts diagram of the fridge.
Thanks/mike
Posted on Nov 11, 2007
rpbuice
  • 161 Answers
SOURCE: Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Posted on Jan 21, 2009
SOURCE: Amana Bx22s5W freezes food in the crispers
I've had the same issue with an Amana BX21TL. In my case, the problem was that the various air flow adjustments were all directing the cold air to the bottom of the fridge, underneath the vegetable crispers.
What I've done to fix this was:
1- Made sure there was a tight seal between the vent opening at the back of the fridge (at about mid-height) and the rubber/plastic duct that directs air to the meat/cheese drawer.
2- Made sure that the adjustable opening at the back of the meat/cheese drawer was fully open.
3- Made sure that the adjustable opening at the back of both vegetable crispers were fully open.
Hope this helps.
Posted on Aug 10, 2009
  • 1218 Answers
SOURCE: Salad in drawer is freezing
Good day,
One user claims that the return air vents or vent located at the bottom rear of the fresh food compartment, have collected enough junk to block the cold air from returning to the freezer compartment. You can clean them out but I cannot verify that solution.
The crispers are located in the coldest part of the fresh food compartment.
This problem can occur when the machine gets light usage especially in colder weather, when the machine running time drops and the air in the fresh food stratifies, causing to cold air to pool in the bottom.
Normal may no longer be normal. Controls by their design will tend to run colder as they age. You might try tweaking the control warmer.
Patience and time are the most important tool you have to work with in dealing with this issue.
Posted on Dec 04, 2009
  • 185 Answers
SOURCE: Everything in the freezer has defrosted
Is there frost on the freezer panel? are the two motor and compressor running (freezer motor and condenser motor)? find this out 1st. this is nothing you did but if you are not mechanically incline at this point only a frig tech can properly check and tell you exactly what is it. theres are the things it might be...
compressor not working
condenser not running
freezer fan not running
thermostat not sensing temp.
stuck in defrost
heaters on too long
bi-metal shorted
timer not working
now if you paid alot for this frig at least get someone to look at it for a service call ($40-60) if it too high to repair then its time to get a new one
Posted on Mar 27, 2010
Bottom refrigerator crisper drawer slide fell off
draw slide is mounted to the shelf bracket --either order new bracket or remove bracket [look how slide positioned on other side ] and try drilling and putting in small screw and nuts till you can order a replacement bracket
Sep 09, 2016 | Refrigerators
Amana fridge model number Arb1914cw is not cooling. Freezer is working fine
Bottom freezer fridges are especially susceptible to
  1. Dust build up on the condenser coil that impedes heat transfer to the outside from inside the box
    • Remove the (bottom) footplate by grasping outside edges and pulling/levering out and popping it free.
    • Use vac crevice attachment and coil brush to clean away all dust from the coil and foot plate.
    • Replace plate and allow 24 hours for inside temp to stabilize.
    • Adjust top temp setting if needed to maintain safe temp level.
    • Repeat semianually or annually as scheduled maintenance--depending on the dustiness is fridge's location.
  2. Airflow blockage through the crispers and meat keepers.
    • Remove crispers and meat keeper as well as glass cover shelf.
    • Find cooling passages between crispers and at midline of meat keeper.
    • Remove any buildup of air blocking debris.
    • Wipe up fridge box floor beneath meat keeper.
    • Reinstall glass shelf, meat keeper, and crispers.
    • Check perodically for poor temperature/moisture keeping in crispers and for water pooling on fridge box floor as signs of blocked air flow through criispers and meat keepers.
Mar 16, 2015 | Amana Refrigerators
The bottom crisper drawer area freezes and anything along the back of the fridge. I have taken the drawer out to help increase air flow that doesn't work. I have also tried adjusting the temperature i
is the fridge going into defrost mode or is freezer building up with ice? may also want to check the cold control thermostat knob and the defrost timer and also check door seals
Feb 14, 2015 | Amana Refrigerators
Water leaking
If there is water under your crisper drawers your drain line under your freezer panel is clogged up or frozen over.
Jul 28, 2012 | Amana ARB2257CSL Bottom Freezer...
Freezing in the bottom draw of my LG Refrigerator
YES!!!!!!
Remove the bottom drawer.
In the back you will see a small dime sized hole.
The hole allows cold air to circulate around the crisper.
Plug the hole with tape or anything that will fit the hole.
Set temps back to say 36 in the ref. and 0 for the freezer.
This should help.
Jan 09, 2010 | LG Refrigerators
Good day,
Dec 04, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Vegetables freezing
Most side by side refrigerators use the freezer to supply cold air to the refrigerator side. They use a duct through the wall between the two sides to let COLD air come into the refrigerator. That cold air will be blown upon the drawers at the bottom, where you are storing your vegetables.
There are two adjustments - or three, depending that will change how the air comes through. The freezer control will set the base temp for the freezer, and thus the temp of the air coming into the reefer to cool it down. The reefer can have a movable vane that increases or decreases the amount of air flowing in from the freezer, the vane being operated at the command of the refrigerator temperature control. Some have a movable plate that limits the flow of air on a fixed basis.
Set the freezer for 0F. Adjust the refrigerator setting, starting in the middle of the range, until a thermometer on a middle shelf, will read at 40F. Take your time, and check once an hour or so, to let it stabilize.
Make sure that you are not blocking airflow in the refrigerator, as the air must circulate to avoid too low a temperature in spots, such as you are experiencing.
May 21, 2009 | Whirlpool ES5FHAXS Side by Side...
Fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Mar 24, 2009 | Refrigerators
    Hope this helps.
    Jan 25, 2009 | Amana Refrigerators
    Water on the bottom shelf of the Refridgerator
    Has the refrigerator got a wet inner back?
    Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
    The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
    However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
    Also, whether the refridgerator is either empty of full willaffe the day to day operation.
    Hope this helps.
    Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
    Amana ARB2557CW / ARB2557CB / ARB2557CC Bottom Freezer Refrigerator Logo
    107 people viewed this question
    Top Amana Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
