Question about Garden
RE: PP 335 Poulan Pro Line Trimmer Pull Start Cord won't retract. Is there an easy fix without sending it out for repair?
    President:
  • 1,545 Answers
No easy fix here unless you are somewhat mechancally inclined and want to tackle it yourself. Ya could save a good chunk of money doing it yourself...learn about the machine first-hand and hey....there really is NOTHING that can prevent it from happpening again! You just fix it, run it until it happens again!
Posted on Aug 23, 2010
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
Poulan Pro PP5020AV pull cord won't retract
You need to wind the spring back in a coil at a time, it is not easy if you have never done one, order a new spring, this will come pre wound in a cassette and is an easy fit.
Nov 22, 2012 | Poulan Pro Chain Saw 46cc 20"
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I need to kno what the item number (so I can order) the line tensioner on my Poulan Pro Link line trimmer---PPB 335. It is a small plastic trimmer head cover. Do I have to order the whole trimmer head?
Your string head is part number 26 in the diagram. Home Depot's Garden department has a wide variety of parts including universal string heads and heads for Homelite, Ryobi, etc. and possibly one that will fit your machine. A lot of these trimmers have Poulan engine and trimmer head parts. See if you can get the complete assembly off the trimmer (if you haven't already) and take it with you to the HD and match it with a new one. The price of parts from an online supplier plus shipping will be almost as much as a complete replacement head. If you shop Ebay, there are literally hundreds and hundreds of weed trimmer parts on there and some good deals to boot.
http://www.mowerpartsweb.com/MANUALS/POULAN/PPB335.PDF
May 02, 2011 | Garden
I have a Poulan PRO LINK PP 335 and the pull rope is only coming out about 8 inches. It's stuck...what should I do?
Remove the starter and pull the cord, if the cord still only comes out so far it is either the cord is too short ( replace the cord ) or the rewind spring is coil bound ( release some of the tention )
Apr 23, 2011 | Poulan Garden
Husqvarna pull cord problem
I had this happen after about 15 uses. I just exchanged the unit. The pull start mechanism can be ordered and is easy to replace. There are parts inside that are nylon and break easily. Any local dealer can order the part for you.
Dan
May 03, 2010 | Husqvarna 28cc Gas Line Trimmer
The pull cord on my poulan pro weedeater will not
You have a broken recoil spring. Dis-assemble (pull-off) the recoil housing and check for proper dog alingnment, broken spring, or something jammed between recoil sprocket and engine block.
Apr 27, 2010 | Garden
I have a Poulan Pro link trimmer PPB225E. The rope starter pulled out and will not retrack back in. How do I fix it.
It sounds like when it was assymbled that the cord wasnt routed through the holes of the plastic disk right to avoid it being pulled out. If you attempt to fix it yourself its no easy task,the entire casing needs unbolted and seperated. You need to make sure you DONT pull the recoil bands out,and there is a proper procedure of the cord routing and tying.This is a pretty advance repaire for a novice.
Aug 08, 2009 | Poulan Garden
Starter cord not recoiling
To get to the starter rewind, you have to pull off the clutch hub and clutch. Without the proper tools, it would be best to take it to a shop. Dwain
May 26, 2009 | Poulan "Poulan" Pp325 17" Gas Brushcutter...
Pull-cord will not retract.
If you put a longer cord on it , then it will not retract as far and get stuck.
Jan 24, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
611 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
