Air throw is not proper - Heating & Cooling
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Aug 23, 2010
My Car is a Toyota Mark X 3.0 G premium warning Lights: Handbrake ABS Airbag VSC/Trac P/S even after replacing all the broken parts
those fault codes require the proper toyota spec air bag diagnostic reader to clear any air bag fault codes
maybe some other sensor is throwing a new code
air bag code readers can say what else is throwing a code
Mar 08, 2017 | Toyota Cars & Trucks
I have a gmh8 goodman furnace,its only 2 years old and it will not work. I just replace the control module. the first time i turn on this year it worked, i turned it down while it was still blowing and now...
what do you mean when you say it is pumping in the propane? What type of ignition is it? Have you checked your supply pressure to make sure it is 11.5-13.0"WC?
Jul 21, 2017 | Heating & Cooling
MY AIR CONDITIONER IS NO LONGER PRODUCING WATER FROM THE BACK
Check to make sure the filter is clean. If not, remove it, wash it and start it back up.
The water that you have seen comes from the machine cooling the air, the air conditioner literally squeezes the water out of the air. If it's not blowing cold ... no water.
If cleaning the filter doesn't work, you will probably have to have the unit looked at by a professional.
Jul 22, 2010 | Daewoo DWC-084R Air Conditioner
UNIT FROZE UP BEHIND FRONT GRILL. AFTER DEFROSTING, HAS NOT BEEN COOLING PROPERLY.
Service your unit. it may need to be clean. You may need the expert to help unless your a handy person. Air conditioning blows air but some units will **** the air back and throws it back this will create a brown film in your cooling grill that prevents from the air to pass thru.
SERVICE TIME!!
Jun 30, 2010 | Haier Mechanical Air Conditioner HWF05XC7
Cold Freezer and warm fridge
possible thermostat problem in the fridge section
call a technician for a proper diagnosis and quote
make sure that the door seal is in top condition and the door closes properly
Oct 17, 2017 | Refrigerators
My 1992 chevy astro heater does not work properly
Make sure it is full of coolant, and the heater valve is functioning, it is locate in your heater hose line somewhere between the core and the engine. If these all check out make sure the damper that control air flow over the heater is working properly. I hope this helps.
Dec 26, 2008 | 1992 Chevrolet Astro Extended
No cool air
Good chance , just double check you have proper voltage going to it first.
Jul 26, 2008 | Coleman Mach III Air Conditioner
Cutting of thermistor wire by rat
If you have enough loose end on the wire you can make a splice and solder the point. Insulated it well with electrical tape. The alternate is to replace the thermistor which and more than likely be ordered by model number and serial number of your unit.
May 27, 2008 | LG Electronic Window Air Conditioner
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
