Question about Husqvarna Garden
Loud grinding sound on mower deck - Husqvarna Garden
3 Suggested Answers
  • 62 Answers
SOURCE: grinding when mower is engaged but no apparent damagewas found
You may have a bearing gone on one of the quills (blade shafts).
Remove the mower deck from your tractor,and check each quill for play in all directions. If there is any movement other than spinning, you will need to replace.
Posted on May 06, 2009
wadembly
  • 489 Answers
SOURCE: i have a john deere 111 when mower deck is engaged
the blades could be out of balance or the bearings could be going bad or the pulley's could be touching something
Posted on Jun 08, 2009
The clutch on my lawn tractor is moaning really loud when running but stops when the peddle is pressed, however the mower runs and cuts grass just fine. any solutions?
One or more of the pulleys are worn and need to be replaced. The method I use is to pull the belt away and hand-spin each pulley to see which one has a grinding sound or loose feel. (A new pulley will feel rock solid and have no sound when you spin it.)
May 24, 2014 | Husqvarna 23 Hp 48" Deck Yard Tractor
I have a Toro Timecutter Z4200, The lawn mower turns on fine, but when I go to engage the blades, it makes this terrible grinding screeching noise. I checked to see if the blades were hitting the deck and...
Hi Josh, It sounds like you have a bearing going out on your deck. The best way to check is to remove your deck from your mower, and remove belt. Then spin one blade at a time, they should spin freely and fairly quietly. You will be able to verify the bad bearing quickly by isolating and checking one at a time. The noisy one that grinding will probably need to be replace, although you could try greasing it first. They are fairly simple to replace and not too expensive. It should consist of three or four bolts. FYI, you may want to take a picture of how your belt is routed before removal, this will help you when reinstalling it. Good luck and I hope this helped.
Aug 14, 2013 | Garden
Treadmill makes loud grinding sound when I run in the middle of the tread. it doesn't make the noise if I run on the left side.
1)you must LUBE the DECK BELT, inmediately, for to avoid the friction
2)LUBE the rollers bearing.too
3) See the main motor for bearing and repair the motor for bearint too.
4) If the problem persist you have worn deck belt, and replace.
God bless you
Nov 07, 2012 | Exercise & Fitness
Poulan riding mower grinding noise
Sounds like bad gears in transmission.
Sep 07, 2017 | Garden
I have a John Deere LA145 lawn tractor. When I engage the mower, a loud noise (grinding) comes from the mower. What could be the problem? The tractor is 2 yrs old.
check and make sure all of your drive pulleys are spinning freely a bearing may be bad in one of the pulleys cause it grind metal on metal but the most common problem is a bent or warped mowing blade cause it wobble and shake and contact the underside of the deck.
Aug 26, 2011 | Garden
Grinding loud noise in the transaxle
sounds like the bypass lever might not be re-engaging, push it in firmly. OR, the brake is sticking. this, of course, is if the noise is a growl or a groan. if it IS a grinding noise, look for something stuck in the trans cooling fan or between the axles and wheels, otherwise it's inside the trans and that's not good [re: replacement]
Jul 10, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Grinding when mower is engaged but no apparent damagewas found
May 06, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Noisey Cub Cadet mower
If the noise is coming from the deck, locate the idle pulley on the deck. there should be 1 or 2 rubber "bumpers" at the opposite end of the pulley arm where it meets the "j" pin. If they are missing, it will make a loud metal to metal sound.
Apr 22, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Grinding Noise Under the Cover
have you checked electric motor bearings?
May 11, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
