Question about Kodak EasyShare One Digital Camera
Lens broken my camera fell off a table and now the lens is screwed up. when i turn it on it is just a black screen. but if i press firmly on the right side of the lens, the picture blurs, fuzzes, and then comes into focus, once i take my finger off it goes black. so i can take pictures, but only with my finger on the lens. it seems like this is fixable. what can i do?
  • rachel321 May 15, 2008
    i turn my camera on and nothing appear but the black blank screen - the zoom lens is stuck in place completely
    Scholar:
  • 75 Answers
Not easily fixed. Sounds like you stripped the feeds for the lense, and it messed up the contacts. Try sending it to Kodak for repair, or taking it to a camera repair place. These devices are sensitive electronics, so you won't be able to fix it at home. Sorry.
Posted on Jun 05, 2008
My camera fell while it was turned on and the lens is now stuck in the out position. It will turn on but immediately turns off again on its own.
Good day,
This tip will explain a few methods on how to try and fix your lens if it is stuck or you get a lens error on your screen.
Please note that all these methods are used at the users own risk and that I can not be held responsible for any damages or losses that occur while trying these methods.
1. If your camera is still under warranty, send your camera to the manufacturer to be replaced or fixed professionally.
2. If your camera is out of warranty try these methods.
  • Make sure your batteries are fully charged.
  • Remove the batteries for 10min. Replace the batteries and see if the problem persists.
  • Try compressed air. This method can be useful if there are any sand or any other object stuck in the lens motors. Use compressed air with a fine tip. Direct the air between the camera body and lens and move in a circular motion around the lens to complete a full rotation.
  • You can also try to tap the padded USB cover firmly on a flat surface like a table. This is sometimes a surprisingly effective method.
  • The last method is to try and force the lens. Turn of your camera and place it on its back on a flat surface. Look at the spacing between the lens and the body and see if the gap is consistent all the way around the lens. If the gap is not even it is likely that the camera fell while the lens was extended. Now VERY GENTLY push down on the lens were the gap is the biggest until you her a "click". This will indicate that the lens is back in place. Try powering back on.
  • If the lens does not extend or it extend and retracts turn of the camera. Hold the camera in your one hand and with the other hand turn the one part of the lens in a circular motion. Rotate both sections of the lens until you hear a "click". This will indicate that the lens popped back in place. Power the camera back on.
  • The last method you can use is to turn the lens while powering on the camera until you hear a "click". Power the camera of and back on to see if it works.
If any of the methods listed above failed to work for your lens problem it would be wise to take it on to a professional to get your camera repaired.
Thanks for taking the time to read my tip and feel free to let me know if it was of any help.
Regards
15073327
Apr 06, 2011 | Samsung DualView TL205 Digital Camera
P 7000 lens cover problem
Good day,
Regards
15073327
Feb 15, 2011 | Nikon Coolpix P7000 Black 101megapixel...
When turning on the camera the screen stays black with instructions saying to turn the camera off and on again
Good day,
Regards
15073327
Jan 25, 2011 | Sony Cyber-shot DSC-S600 Digital Camera
My camera is stuck with a black screen and the lense is half out, whenever I try pressing the on/off button the lense goes in then comes half out again from one press and it won't do anything else
Good day,
Regards
15073327
Jan 25, 2011 | Canon Cameras
I have an olympus digital camera fe-170. when i turn on my camera, the lense come out and the LCD screen is black, when i try to turn it off, it doesnt turn off, but after like 10 seconds it turns off by...
The lens is bad, needs to be replaced. Maybe purchase camera on ebay with broken LCD but good lens. Replacement can be time extensive. Will need #00 or #000 phillips screwdriver and solder iron. Remove 6 exterior screws+2 inside battery door. Take off front panel, remove top screw holding back panel; remove back panel. Remove 2 screws(left side top & bottom)from LCD, unplug LCD by flipping hinge up on plastic connector, pull ribbon. Remove 6 screws along outer edge of electronic board + 2 screws behind lens. Unsolder 2 battery connectors near top right side(do not melt or burn ribbon in between them). Disconnect ribbons at top right and on left edge of board. Flip board over to the left side carefully as it's still connected by 4 thin wires. Remove 3 outer screws holding lens, remove lens. Replace with good lens. Assemble camera in reverse order.
Good luck and be CAREFUL!
Loren
Jun 15, 2008 | Olympus FE-170 Digital Camera
Lens stuck on i830 polaroid digital camera
Gently pull on the lens when its trying to extend, you may be able to get it back on track. This is by far the weakest point on any camera that has a retractable lens. So much that Olympus sold a lens guard/adapter for their C5050 that was basically a screw on tube that was the length of the extended lens and people bought it just to protect their extended lens.
Jan 18, 2008 | Polaroid i733LP Digital Camera
Camera fell on floor and lens popped out
http://www.lensbabies.com/index.php?r=GSLBGeneral&gclid=CJSbjPWUrI0CFQqgYgodlz7D1Q chek site you will find diagram
Jul 16, 2007 | Olympus C-3000 Zoom Digital Camera
Kodak EasyShare One Digital Camera Logo
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
