Question about GE Nautilus 24" Built-in Dishwasher
Our GE Dishwasher (GSD3400G00BB) has sat for several years prior to just installing it. We have the water hooked up and turned on! But when try and run it no water makes it inside to clean the dishes. Any Thoughts on what is preventing the water from making it to the cleaning area? Thanks Brian
  • 58 Answers
SOURCE: dishes are molding that are left in dishwasher before cleaning
thats sounds normal except the molding i never herd of b4
Posted on Oct 31, 2007
SOURCE: GE Monogram Won't Drain completely
the drain was clogged. A handyman used a snake to clean it out.
Posted on Apr 19, 2008
SFroese
  • 141 Answers
SOURCE: GE dishwasher GSD2200G00WW dishes not clean
Make sure the spray arm is actually rotating and the jets aren't clogged. You should be able to hear the arm rotating when the dishwasher is operating.
Otherwise, perhaps the pump is plugged or not working and the water isn't "jetting"
Posted on Sep 06, 2008
  • 111 Answers
SOURCE: GE Profile PDW9200J dishwasher leaves a film and dirty dishes
Sounds like you have an excessive build up of hard water (mainly calcium) in it. Clean it like this: Close the detergent cup cover. Run hot water at the sink to clear cold out of the pipes. Start the machine on pots and pans/added heat. Wait about 10 minutes and open the door. If the detergent cup cover flops open, it is in the main wash. If it is still closed, let it run a few more minutes, check cup cover again, keep dong this until the cover is open. Once it is open it will be in the main wash (the longest cycle) and at that time put in about 2 cupfulls of Tang orange drink in the bottom of the tub. Tang is very high in citric acid and will clean the calcium and other hard water deposits from the tub, pump, spray arms, ect... Make sure your hot water is HOT (130 is great) and use Cascade Complete powdered detergent from now on. Should take care of it... Repeat every 6 months to keep it clean.
Posted on Dec 20, 2008
  • 677 Answers
SOURCE: GE Profile Dishwasher (5 years old); Leaving residue on dishes
There is a new product out that actually filters the water going into your dishwasher. My dishes came out amazing after the first load. No more cloudy glasses. I was very impressed. Who knows whats in the water cleaning your dishes so i thought this filter was great. It is very affordable and you can get it at www.dishwasherfilter.com. Hope this helps some people.
Posted on Jan 06, 2009
The water will not drain out of the bottom of the dishwasher Model Number - GSD3400G00BB
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Mar 13, 2011 | Amana 24 in. ADB2200AW Built-In Dishwasher
Why won't my GE dishwasher get my dishes clean?
IF all appears to be working just leacing film on dishes or if not actually cleaning dishes there could be several things it could be... the basics to start with are first make sure the entering water temperature to dishwasher is a t least 120-140 degrees ... run water at sink prior to starting dishwasher.. next remove drain line from under sink and check for any obstruction where it connects. check the area under lower spray arm for trash/food build up and if you can remove spray arm and clean port out of any calcium build up... make sure the water is filling unit properly run a cycle and when you start unit listen when it stops filling open door and make sure it has enough water in it.
Jan 27, 2011 | GE Dishwashers
Do these 'portable' dishwashers 'heat' water prior to washing? i have customer complaining bout the dishes not coming clean..yet the water entering the dishwasher is cold, does not appear to heat water...
Most dishwashers require a minimum 120 degree inlet water temp. The heating element will boost this up during the main wash cycle to aprox 140. Do not hook a dishwasher up to inlet water temps above 150.
Feb 06, 2010 | GE Hotpoint HDA3500N Dishwasher
Water leaks when black valve hooked up to water tap
Hello Wes. Begin by installing a new o ring. Take off the old one and take it to a hardware store to get the correct replacement. Also pick up a little tube of O ring lube.
Jun 08, 2009 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Dishwasher SSD3900J00ww wash water cool heating element hot on
Crew that installed new cabinets and sink hooked dishwasher to cold water line I switch it works fine now. Thanks Don
Mar 20, 2009 | GE Dishwashers
GE Nautilus GSD3400G00BB
The easy way to fix it would be to empty it and run a quick wash. hopefully the latch is just stuck and it will open up.
Please remember to rate me.
Feb 02, 2009 | GE 24 in. GSD3400G Built-in Dishwasher
Ge dishwasher hums but will not work. is a 1999 model,,seldom use
When you use your dishwasher so infrequently the water inside evaporates and allows the pump seal to dry out, so there is no longer the lubricating water there. You may be able to solve this by pouring a couple cups of hot (not bioling) water directly into the center of the lower wash arm (center spray tower) and letting it sit for several minutes.
If that does not work, you can take the bottom panel off and turn the fan blade on the motor by hand until if turns freely. (don't do this with power to the motor or you may have some nasty banged up fingers !)
To prevent this from happening in the future, keep some water in the dishwasher by poring a bit in every now and then, or by running a fill and pump cycle at least once a week or so. If you are away for extended periods, you can try adding RV antifreeze to the dishwasher while away.
Nov 16, 2008 | GE Dishwashers
GE roll around dishwasher
check to see if water is in basin. If so remove with dry rag until dry. Then run. If water is in basin, float will trip to stop inflow (flood precaution)
Jan 04, 2008 | Zanussi ZT485 Built-in Dishwasher
GE Nautilus Dishwasher Problem
check water level is ok. check its heating. open door when in operation and check if spray arms are rotating. if not, take them out, run water into centre hole and check water comes out of jets. note the spray arms only rotate with water coming out of angled jets at end
Apr 19, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus 24" Built-in Dishwasher Logo
90 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
