Question about Philips Senseo Single-Serve Coffee Machine Gift Pack, Raven Black
My senseo doesn't make foam any more. there is little bit of it and dissapears quickly and coffee doesnt taste as good
  • 24 Answers
If you didn't change the brand of coffe pads, my first educated guess would be that the machine needs to be decalcified. For that purpose, little sachets of citric acid are available in most stores. The rinsing procedure is mentioned in the manual, but basically consists of filling the reservoir to the max, placing a large bowl under the outlet, keep pressing the single- and double cup button simultaneously while also briefly pressing the power button. To stop rinsing, press the power button again.
Posted on Oct 28, 2010
Senseo coffee maker
http://www.eserviceinfo.com/downloadsm/19109/Philips_Senseo%20HD7810/10.html
OK above is a service manual, this is what the techs use to fix, it. Use the exploded diagram,and troubleshooting guide, and you will no doubt sort it very quickly.
http://www.devicemanuals.com/guide/Home%20Appliance/Philips/Philips-SENSEO-Coffee-Maker-HD7810-75-54-User's-TXpBNE1qTT.html
Download the user manual above.
Apr 03, 2010 | Philips Senseo HD-7810 Coffee Maker
Philips senseo coffee is watery
It may be the pod holder,there is a seal under the black disc at the bottom of the holder,the water will bypass the coffee under pressure,travel to the outside of the pod holder and exit the centre where the filter mesh is,if there is no foam also this is a sure sign,fill the empty pod holder with water and see how quick the water drips,I had this same issue and bought a new pod holder and compared,should be no more than 1 drop a second,you can knock the plastic out and re seat the O ring or buy a new holder,hope this is of use to you
Dec 27, 2009 | Philips Senseo HD-7810 Coffee Maker
Coffee tastes stale even after cleaning
A few things you can do. Buy less pods at a time and store them in a jar. Shake or aerate the water when you put it in the unit. Don't put it in, the night before.
Jul 26, 2009 | Philips Senseo HD-7810 Coffee Maker
Coffee comes out as weak as coloured water! far too weak.
you probably are not putting enough coffee in to strengthen the coffee
Apr 25, 2009 | Philips Senseo HD-7810 Coffee Maker
Senseo machine has started producing very weak coffee
I don't know if you've tried this, but it works like gangbusters for me. I use non-senseo pods with the 2-pod holder, and they're too big for the 1-pod holder but not quite big enough for the 2-pod one.
I would frequently end up with a lousy, weak cup of coffee, and after a little investigation I deduced that water was flowing into the pod holder and AROUND the pod, without going THROUGH the pod directly. The name-brand senseo pods fit perfectly, and always produce a strong cup, even if I don't like their coffee, and it's because there's such a tight seal between where water flows in and where it flows out.
Simple solution: Put your pod in with the flat part facing up, and the bulgy part facing down. Press it down hard into the 2-cup holder. Run a little HOT tap water, and lightly wet the surface of the pod--not so much water that the pod starts floating in the holder, but enough to get it soggy. Then make your cup of coffee. The water will flow through the pod first, and kind of like siphoning gas through a hose, once it's started going through the pod it won't stop. Instant awesome cup.
Oct 24, 2008 | Philips Senseo HD-7810 Coffee Maker
Cm24p-1
every coffee maker i've ever used like the meile, senseo or espresso machines do that. even my starbucks coffee looks like that at first. it should go away after just a little while, especially when stirred.
Feb 09, 2008 | Dacor CM24P-1 Coffee Maker
Coffee not hot enough
I had the same problem with my machine so use coffeemate instead of milk now seems to have done the trick
Jan 11, 2008 | Philips Senseo HD7832 Coffee Maker
Senseo coffee problem
The pod holder has an O ring to seal the black plastic disc in,if it is not sealed you will end up with more volume and a weaker coffee without the foam,either knock the disc out and try and seat the O ring and then knock it back in or buy a new pod holder,I had this same problem
Nov 30, 2007 | Philips Senseo HD-7810 Coffee Maker
Philips Senseo Single-Serve Coffee Machine Gift Pack, Raven Black Logo
219 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
just-ice
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
