Question about Delphi XM SKYFi2 1016211B1 Satellite Radio Receiver
No power. Is there a reset, or a fuse inside the unit?
  • Delphi Master
  • 6,993 Answers
there is no reset button of fuse in your radio receiver. instead, the radio has a power board. The power board must have been defective, that's why it not powering on.
A capacitor, diode or other components on the power board may be bad. This can cause the radio not to power up.
Get a meter, open the radio and read the power board in order to detect the bad component and make necessary replacement. This is the only way by which your radio receiver can power on again.
I hope this makes sense to you.
Good luck.
Posted on Aug 23, 2010
  • mhartwick88 Sep 19, 2010
    How would you find component and where can I buy a new one
C-3725 trouble code
The fusing unit in side machine has reached a very high temp. This is the unit which fuses the toner to the paper the hot part upper right hand side of the machine. to reset follow:
Utility
1.Power off the machine using the main power switch inside front door leave sub power switch on that's the one on the op panel side.
2. Hold down the Utility/counter button.
3. Power on using main power switch and close the door.
4. wait for screen to show trouble reset touch trouble reset chk for OK
5. turn off main power switch, wait 10 seconds then power it up again. it should restart and go ready to copy. if the code comes back do not reset the machine again. It is informing you there is a problem get it looked at.
Jun 01, 2014 | Konica Minolta KONICA BR BIZHUB C451...
Code c-3B04
Fusing unit issue! Have to reset with PWR off the machine using both the main pwr inside front cover and sub pwr on the side of the op panel then turn on the machine holding down the Utiliy/counter button. unit the Trouble reset show on the screen then press trouble reset until says OK the Power off the machine with Main power switch inside the front cover, Wait ten seconds before doing that. If it comes back do not re do its broke and telling you so get a certified tech to look at it.
Oct 03, 2013 | Konica Minolta KONICA BR BIZHUB C451...
No power to unit suddenly
1) put some lamp desk in the outlet wall, if turn ON the circuit is o.k if NOT reset the c. breaker or replace the blown fuse.
2) if everything is o.k test the power cord, for open or break. DO not use extension cord.
3) test the main button for open or defective. Reset the button to the side of the main switch. Replace the fuse inside, tight any connector wires inside of the machine and clean with contacts cleaner, Disconnect the power cord.
see the block diagram attached.
God bless you
Sep 06, 2012 | Horizon Exercise & Fitness
Hi, I have a Konica Bizhub C451. There is a trouble code C-3824.Any advice to resolve the issue? Thanks Chris
Chris,
Turn off main power inside front cover insure that the sub power switch is pushed in on right side of the control panel. Hold down the Utility/counter button and turn on the machine hold down until screen shows trouble reset touch trouble reset go OK. Power off then wait 10 seconds power on. If the code comes back do not attempt another reset you are resetting the code for the fusing unit (The hot Part) It can catch on fire and that would ruin a perfectly good day! Have a technician look at it Good chance fusing unit needs replacing
Nov 03, 2010 | Konica Office Equipment & Supplies
Doesn't want to stay on
If your GPS unit powers down before it can fully boot up, use the steps below to charge the GPS unit and test the vehicle power cable:
  1. Connect device to a computer that is powered on
    • The unit should power On when you plug it in showing a computer plugged into the GPS unit on the screen (Mass Storage Mode)
  2. Press Reset button on the bottom of device if it does not power On*
  3. Allow the unit to set and charge for 3-4 hours
Once the device is charged please take it to the vehicle and test it on the vehicle power cable.
  1. Connect the device to the vehicle power cable
  2. Connect the vehicle power cable to outlet on vehicle
  3. Power the vehicle On
  4. Device should automatically power on
    • If a battery icon appears directly to the left of the time then it is not receiving a charge from the vehicle
    • Please check the fuse in the vehicle power cable
      • The end of the cable unscrews to reveal this fuse
      • Check to make sure the wire element inside the fuse is in contact and that there is no discoloration.
      • If you see either of these the fuse needs to be replaced with the replacement fuse specifications listed on the sticker attached to the cable.
      • If the fuse looks good and there is still no light, the vehicle power outlet may need to be checked to see if it has power.
*Note - The reset button may be found on either the left or right side. In some cases if the device does not have a reset button slide the power key to the left or On position for about 10 - 15 seconds.
Oct 23, 2010 | Garmin nuvi 200W GPS Receiver
Error message 3725 on Bizhub C451, how do i reset so I can print
Sir/Mam,
Turn off the main power switch located inside front door. Then holding down the utility/counter button turn the main power switch on. Close front door you must keep the utility button down also make sure that the sub power switch is on. This is the switch on the side of the control panel. The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit High Current Device for the fusing unit. Which will be expensive!!! Sorry:( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!!
Sep 24, 2010 | Konica Minolta KONICA BR BIZHUB C451...
Kenmore micrwave overheated. now won't work. is
There is a fuse inside the chassis that can be accessed by removing the 4 side screws and the 6 back screws on the chassis cover. First unplug the unit then remove the 6 screws securing the cover to the shassis. Once the screws are removed lift the rear of the cover about 10 to 15 degrees and pull to the rear. The chassis cover will then come off. NOTE: There is a large capacitor inside the chassis that will stil have a charge. Make sure to avoid it when reaching inside the unit. Follow the power cord from where it enters the chassis to the end terminals. One of them will terminate at the fuse holder. Remove the fuse, obtain a new fuse of equal value amd intall same. Plug the unit in to see if you get some from of power be it a light inside or the contral panel lighting up. If it is just the fuse and you see signs of the unit having power once again unplug the unit and re-install the chassis cover.. Make sure that the cover interlocks on the front of the chassis properly. All mating surfaces should appear flush. Re-install the 6 screws and retun the unit to service. If nothing happens please reply to this post.
Jan 05, 2010 | Kenmore Microwave Ovens
I have a Sharp portable room air conditioner model CV-P10NC. The power plug RESET button and TEST button will not click in order to check out the power plug as the unit will not turn on. They did test O.K....
the fused9G.F.C.I.) cord you speak of is probably the G.F.C.I. built onto these units by design, can you or someone you know get access inside the unit and :Hot-Wire" the units cord and,bypass the power cord ( Just To Test the Unit)and see if it stays operational then replace bad unit cord if this is it.
Sep 12, 2009 | Heating & Cooling
Oven has been working fine. Heating a cup of coffee it just stopped dead. No display. Nothing. Power to outlet working fine. Is there a reset somewhere?
Mine did this when my wife had it on full power for over 10 minutes. We left it set for 15 or so minutes and it came back on. It did the same thing when my niece was heating a liquid with some metal in it. It eventually came back on. There must be a thermal circuit breaker inside the unit. Yours may have a fuse or some sort of circuit breaker inside it, that needs replacing or resetting. Then again some units have a fuse that goes out when the Magnetron shorts out, or goes bad. This would require replacing the Magnetron as well as the fuse.
Sep 12, 2009 | Sharp R-326FS 1100 Watts Microwave Oven
No cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Aug 31, 2007 | Mitsubishi MSH09TW Air Conditioner
Delphi XM SKYFi2 1016211B1 Satellite Radio Receiver Logo
215 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
