Question about Garden
I WENT TO PUT FLUID IN MY BOTTLE JACK AND TOOK THE SCREW ALL THE WAY OUT. NOW I CANT GET IT TO WORK. HOW DO I FIX IT? ITS NOT A AIR ONE JUST A MANUAL
  • tim clark Aug 24, 2010
    Thanks a ton!! 2tons
Power steering fluid gushes out when I turn my steering wheel to the left
Where you put the fluid is the pump. The pump will do this if the cap isn't screwed back on. If you were checking fluid level you do this with engine off to give the fluid a chance to settle for a good reading. If I have misunderstood your question please get back to me. GOOD LUCK FRIEND.
Nov 29, 2014 | Cars & Trucks
Lift will not work
There is either air in the system, not enough fluid in it, the valve that lowers it is not closed or the orings are bad.
Dec 06, 2013 | Torin Jack Jacks Big Red Motorcycle Jack...
How do i bleed my thermostat on a 2002 buick century custom
RUN ENGINE FILL WITH ANTIFREEZE AND THERE IS A BLEEDER SCREW ON BYPASS LINE/HOSE ON TOP OF ENGINE NEAR BELT. THERE MAY ALSO BE A BLEEDER ON THE THERMOSTATE HOUSING. CRACK OPEN BLEEDERS UNTIL ALL AIR COMES OUT.
Dec 19, 2010 | 2002 Buick Century
Took my 93' Toyota, has 193,000 miles replaced the
THE MASTER CYLINDER NEED TO BE BLED FIRST.BEFORE PUTTING ON THE CAR.TO MANUAL BLEED BRAKE SYSTEM.YOU NEED 2 PEOPLE TO DO A BETTER JOB.YOU FIRST BLEED THE LEFT REAR RIGHT REAR LEFT FRONT AND RIGHT FRONT. WHEN YOU BLEED THE BRAKES.HAVE THE HELPER PUMP BRAKES 3 PUMPS.AND HOLD BRAKE PEDAL IN.YOU NEED A CLEAR BLEEDER HOSE IN A CLEAR BOTTLE HALF WITH CLEAN BRAKE FLUID. WITH BLEEDER HOSE ON BLEEDER SCREW AND OTHER END BLEEDER HOSE IN BOTTLE OF BRAKE FLUID.WHILE HELPER PUMP BRAKE PEDAL HOLD IT IN OPEN BLEEDER SCREW 1/4 TURN ALLOWING AIR BUBBLES LEAVE THE BRAKE SYSTEM.CLOSE THE BLEEDER SCREW BEFORE BRAKE PEDAL RELEASE.HAVE HELPER PUMP BRAKE PEDAL 3 TIMES. WITH PEDAL HELD DOWN OPEN BLEEDER SCREW GETTING AIR OUT OF THE SYSTEM.WHEN YOU SEE SOLID FLUID COMING OUT OF BLEEDER HOSE THE AIR IS OUT THE BRAKE SYSTEM.DONT DRIVE CAR ON HIGHWAY IF YOU STILL CANT GET SOLID BRAKES. HAVE CAR TOWED IN TO BE PRESSURE BLEED.
Jun 19, 2010 | 1993 Toyota Corolla
Exact procedure for bleeding brakes on 1989 Toyota tacoma
Two people are best to do this job. Make sure the car is in gear or park with the wheels chocked and the handbrake down. You work from the wheel furthest from the master cylinder. If you lie under the car and look at the back of the wheel cylinder you will see a bleed nipple. You can probably do this job without removing the wheel. If you do need to make sure the car is jacked up properly and don't lie under it. The nipple is covered with a rubber dust protector. You need a length of plactic tubing that will fit tightly over the end of it, about 2 ft long. Then put the other end into a bottle with a little brake fluid in it making sure the end stays in the bottle. Open the filler cap on the master cylinder. Have somebody sit in the driver's seat. Tell them to push the brake pedal. As they do this loosen off the bleed nipple making sure the pipe does not come off. The pedal will fall to the floor and you will notice fluid coming into the pipe. Lock the nipple up again and tell them to lift the pedal. Do the same again and keep doing it until no more bubbles go into the bottle. After every few pushes of the pedal, check the master cylinder and top it up. You do not want any air to get in there. When there are no more bubbles, tighten the nipple, replace the dust cap and move on to the next wheel furthest from the master cylinder and then the next until the last one is closest. Make sure you use clean brake fluid and don't shake the bottle or air will become trapped in the fluid. Brake fluid will ruin paint so be careful not to spill it on the bodywork.
Mar 13, 2010 | Toyota Tacoma Cars & Trucks
I have just recently replaced two front brake lines on my 93 ford taurus. yesturday, i was driving home from work and all of a sudden its like i had no brakes. i can put the brake peddle to the floor, and...
You will need to buy a few bottles of brake fluid to accomplish this:Try bleeding all the air out of the brake lines starting from the farthest wheel from the resevoir. This can be done alone but is easier with two people. You will need a 10mm or 3/8"(varies depending on Model) wrench to loosen the bleeder screws on one wheel at a time. The bleeder screw looks like a babies bottle nipple only steel with a hex on the lower portion. They are sometimes tight and awkward to loosen. If you can , pre loosen the bleeders before you begin.(make sure that they can be easily opened and shut, and keep closed until you are at that particular wheel) When you begin pump the pedal about 5 -8 times to build up pressure and hold. Now the person at the bleeder can open up the screw until a steady stream of brake fluid comes out with no air. When the pedal goes to the floor close the bleeder(without lifting foot of brake pedal) and try process again if there is still air in oil. If you lift your foot off the brake pedal when bleeder is open, this will draw air into the brakes causing more air to enter. If you are by yourself simply use a small container with clean fluid in it and put a small hose from the bleeder into the container with fluid in it.( I used a half full brake fluid bottle and a small rubber hose) Make sure that the hose is immersed in the brake fluid. Open the bleeder and push the pedal slowly down and up a few times to expel the air. You dont need to worry about air getting in unless the hose is not in the oil. You can buy a one man bleeder kit from Princess Auto or any other automotive dealer(Canadian Tire)to do it yourself. Hope that this helps you out.
Feb 21, 2010 | 1993 Ford Taurus
Changed front brake pads on 99 daewoo matiz but they still feel soft also how do i bleed the brakes on it
Anything to do with brakes requires expertise. You don't want to mess this up because the end result is an accident, injury and/or death.
It is easier to do if you can get the car up in the air a bit and with the wheel removed. It can be done without raising the vehicle and removing the wheel but you'll have less room to work in. If ou do raise the car and remove the wheel be sure to use jack stands not just a jack (Never get under a car that is beng held up with just a jack) The basics are you always have to make sure you brake fluid reservor is filled. Start with the brake farthest from the brake fluid reservor. Have someone pump the brakes and then hold the brake pedal while you open the bleed screw on the brake. FYI: You should put a thin clear plastic tube over the bleed screw and the other end into a bottle with some brake fluid in the bottom (lkeep the tube under the fluid so you don't accidentially let air enter the system). The pedal will sink to the floor as you open trhe bleed screw and your friend HAS to hold it there until you get the bleed screw re-tightened. Then you tell you friend he can let the pedal up and repeat the process. Note: If the brakes do not feel stiffer from you just pumping them you may have a more serious problem than just air in the system. Remember to keep checking the brake fluid reservor and refilling it or you will end up adding more air to the system and have to repeat the whole thing. Also be sure to use the correct type of brake fluid. Also the brake bleed screws can be broken off or rounded off if you don't use the proper sized wrench as they usually are very tight. DON'T EVEN THINK ABOUT USING PLIERS OR VICE GRIPS. If you are unsure of what you are doing get a friend who has some experience or take it to a shop.
Feb 10, 2010 | 1999 Daewoo Lanos
Just replaced clutch spring on '01 vulcan 1500 classic fi and used mean streak spring per instructions on gadgets help page, put it all back together. Now the clutch won't engage even after bleeding, what...
assuming it was reinstalled properly....try the following. while bleeding the system, squeeze the clutch lever several times to pump up the system as normal; open the bleed screw while holding the clutch lever in and air or fluid comes out. instead of closing the bleed screw hold your finger over the bleed screw and pump up the clutch lever in the normal fashon and bleed by releasing your finger to let the air escape try this several times to see if your clutch comes back. I don't know why but this technique works sometimes...Mike...Make sure you always have plenty of fluid in the resivoir at all times
Mar 30, 2009 | 2000 kawasaki VN 1500 Vulcan Classic...
My windshield wiper fluid container has busted for the second time on my 2007 Avalon. Is there a recall on this part? It's location makes it too difficult for the average Joe to replace, so I took it...
Did the container actually break? I had a fluid loss problem with my 07 Avalon. It's wasn't the bottle causing the loss of fluid. It's was the clip that holds the hose to the bottom of the bottle. I fixed mine by using a 1/4 inch worm clamp (the type that has a screw that continually tightens the clamp) Available at any hardware or autoparts store.
It's an easy fix. Simply raise the front of the car a little to get underneath and remove the screws holding the splash shield in place. The bottom of the pump is readily accessible. Put the new clamp on and snug it down good. I haven't had the problem since.
Jul 04, 2008 | 2007 Toyota Avalon
My headphone jack messed up and so did menu button
chances are that you screwed something up when you took it apart prolly dust or a wire or somthin got hit ~Grim
May 09, 2007 | SanDisk Sansa m230 MP3 Player
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
