Question about Gateway MX3414 Notebook
I have a MX3414 notebook. I plug in the power adapter but no lights come on on the front of the computer indicating that it is charging. The green light on the adapter is on and cycles through bright and dim similar to a flashing effect. It tried to boot with what little battery power it had left. So I'm trying to determine if the power adapter is bad or the if the system board has a problem. Is this a common problem?
    Genius:
  • 1,478 Answers
I will advice you remove the battery from the system and try charge with the adapter, see if it will power on, it did not, the problem is with the power adapter, try get a similar power adapter to charge the laptop, id charges the laptop, it means you will need to get a new power adapter.
But from all indication, the power adapter is most likely the cause of the problem.
Take care.
Posted on Aug 23, 2010
OW TO GET MY ACET ASPRE ONE IT STOP BLACK SCHREEN NO POWER
Step by step troubleshooting.
Verify power outlet is good
Verify power adapter is good
verify connection to computer is good
fully charge battery
test
=======do this
Check power source, plug known good light into AC receptical.
If AC cord has connector to power block verify it is properly seated.
plug adapter into AC outlet
Verify Power is present at power connector with another similar computer or voltmeter. (12V to 20V)
When plugged into computer, charge (not power) indicator MUST light either red, amber, or green. If not, connector on computer may be broken.
leave overnight or until charge light is green
turn on normally.
most likely causes:
- loose connector
- broken wire from power adapter
- broken power plug on computer.
- anything else is probably beyond ur capabilities to fix.
Aug 10, 2014 | Acer Aspire One PC Notebook
Dell inspiron 1525 - plugged in not charging shown on battery icon. Battery power light blinks 4 times amber then once blue.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. Call Dell for a replacement. (See
Chapter 5, "Getting Help," for
instructions.)
No. Call Dell for technical assistance. (See Chapter 5, "Getting Help," for
instructions.)
Feb 13, 2011 | Dell Inspiron 1525 Notebook
Orange battery light is doing a double blink right now... Does that mean the battery is being charged??
I had the same problem, I removed the bettery while it was still plugged in, tested it, then plugged it back and and now all is fine.
or you may try If an AC adapter is not connected to your computer, the computer's power source
procedure.
for signs of power.
No. Go to step 7.
Yes. Go to step 9.
No. Go to step 7.
flashing amber?
computer.
Yes. Your original battery is defective - please look for a replacement. Hope it helps.
Jun 25, 2010 | Sony VAIO PCG-K35 Notebook
I have an m5310 and i have troubles with the battery charge i bought a new battery but is still the same , i plug the notebook to the ac power and batery start to load (the front green light is on ) after...
Try to perform power drain on the motherboard.
heres the steps:
take out the battery
unplug the power adapter
press and hold power button for 30secs
put the battery back in
power on the computer
if same issue will happen then you need a battery replacement.
May 21, 2010 | E-Machines M5310 PC Notebook
Dell latitude 100L power light flashes green as if
It sounds like you have a bad AC adapter . When you plug it in to the outlet in the wall and into your computer , do you see a charge indicator light on the computer? I'm asking you this because even with a bad battery your computer should operate without any problems with the AC adapter plugged in.
May 13, 2010 | Dell Latitude 100L Notebook
Won't start - battery critically low
You should have a light on the notebook indicating that the power supply is plugged in (this should come on with or without the laptop being turned on). My acer has a green light for power, and the battery indicator shows amber for charging and green for full. If you are not seeing the power or charging indicators, you either have a damaged power jack, or a damaged power supply. Power supplies can be purchased usually for fairly cheap online, but if your power jack is damaged, the laptop will have to be serviced by a service center, or by someone who is skilled with a soldering iron and the disassembly and reassembly of laptops.
Feb 28, 2010 | Acer TravelMate 2413LCi Notebook
My Acer Aspire 5100 just went blank. There is a
Generally, an indication that the battery is critically low. It appears that the AC adapter is not powering the system and not charging the battery.
Jan 09, 2010 | Acer Aspire 5100 Notebook
Battery indicator?
Hi there.
Sounds like the battery could be faulty.
procedure.
for signs of power.
No. Go to step 7.
Yes. Go to step 9.
No. Go to step 7.
flashing amber?
computer.
Good luck
Jun 01, 2009 | Dell Latitude D600 Notebook
Shut off and won't come back. It's like it is dead.
follow this procedure:
1. unplug the ac adapter and keep it unplugged.
2. Remove the battery and keep the battery unplugged.
3. Hold the power button down for 15-20 seconds(Nothing will appear on the display and none of the lights will light up)
4. Release the power button and plug in the ac adapter ONLY. (A power indicator light should be lit on the ac adapter when it is plugged in)
5. Normally power on the notebook.
6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
7. Plug the ac adapter back into the system, the battery charging indicator light will light up. If the battery indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
Char S.
May 27, 2009 | Acer Extensa 5420-5687 Notebook
When I plug in my ac adapter into my computer to charge it the green light turns off and won't charge my computer
procedure.
for signs of power.
No. Go to step 7.
Yes. Go to step 9.
No. Go to step 7.
flashing amber?
computer.
good luck
Apr 05, 2009 | Dell Inspiron 6000 Notebook
Gateway MX3414 Notebook Logo
46 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
