Question about HP 610 Color Copier
Paper jam my machine says there is paper jam but I took the paper out and it is still saying that. I have checked thoroughly there is no paper in it. It shows a carriage jam and I cannot get it to come off
  • 1 more comment
  • glsable Jan 03, 2009
    same problem! If anyone knows where the paper jam sensor is located maybe it can be disconnected?
  • Anonymous Mar 16, 2009
    Keeps saying I have a paper jam and I've checked the entire machine, no paper jammed anywhere. It won't run, keeps saying "clear paper jam".
  • rvm6 Mar 20, 2009
    No physical jam, but still say's Paper Jam. Won't clear.
  • HP Master
  • 13,433 Answers
Try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 03, 2009
Epson NX415 Paper jam. I took paper out but it's
Check for other bits of ripped off paper stuck in your machine.
Try turning off your printer for 30 secs and turn it back on.
Mar 11, 2010 | Epson NX415 All-In-One Printer
My printer states that it has a paper jam but I took the paper out and there were no bits of paper in the printer or any missing from the piece of paper. It will not reset. It just says ''paper jam''.
What model is it? If it is a newer model it has a multiple paper feed sensor. This multiple paper feed sensor shines a light through the paper on the first pass, calculates the density of light emitted through the paper.. then subsequent sheets it looks for approximately the same density. If it drags two sheets through the light is different.. it shuts down and gives you a paper jam. I currently have 2 RP 3700's.. One of them has this problem and it is sidelined until I get a new sensor or light. I have the same problem. I've cleaned the machine thoroughly too. Really make shure that this is not the problem. I have a flexible plastic ruler I slide through my machine to make shure there's no bits of paper stuck anywhere.. Even some ink could cause the problem. blocking out the sensor. It could be the little light is burnt out and no light is making it to the sensor, or the sensor is burnt and won't read. What kind of machine do you have?
Aug 15, 2009 | Office Equipment & Supplies
Kyocera 3900dn says paper jam in rear but no jam evident
Usually a printer doesn't lie when it indicates a paper jam, if you have checked as thoroughly as possible and no paper can be found. It is possible that the paper just isn't feeding and a printer will sometimes indicate a paper jam when paper doesn't feed. But if this isn't the case and a jam is indicated as soon as you turn the printer on, one of the plastic jam sensing actuators may be broken or hung up.
Aug 05, 2009 | Kyocera FS-3900DN Laser Printer
Screen says paper jam, can't find anything
close properly your paper jam cover at the back of your printer down side. if not clean and check the sensor for paper jam.
May 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
The machine says "paper jammed, open the front cover and remove jam papers" I have done this and turned it on and off, but couldn't find the jammed paper. what do i do? please help!!!!!!!!
there mat be a small scrap/piece of paper stuck in the bottom of your drum unit. pull out drum and look at the bottom right in the middle. if not there, open rear door and inspect thoroughly.
hth,
razors
Apr 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Phaser 860 screen says "paper jam - open front cover to clear"
I posted a problem with the phaser 860 paper jam. I found 2 broken sensor flags and am ordering the parts.
Mar 19, 2009 | Xerox Phaser 8400 Laser Printer
Brother MFC 3240C Paper Jam Error Message
If it is not resetting then either there is still something on a sensor or you did something to a sensor by accident.
here is the manual
http://www.retrevo.com/s/brother+2820+fax++manual
Nov 21, 2007 | Brother IntelliFax-2820 Laser Fax
Paper Jam 2
Most probably you took a paper sensor out of position when removing the first jams. In your unit, the paper sensors are connected to the main board or power supply board. If the equipment is under warranty, any authorized service center will gladly replace it for free.
Oct 03, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Paper jam
Turn printer on,
Disconnected power cord on the back...
Press & hold #, 6 keys while connecting power cord, Keep holding till screen shows reset or shuts down..
Make sure the cartridge access door is closed tightly.
Nisar
Sep 24, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Paper jam
push menu then start mono (b/W) then 4x arrow-up button. maintenance should be displayed. What error code does the machine give to you?
Sep 11, 2007 | Brother MFC-410CN All-In-One InkJet...
HP 610 Color Copier Logo
316 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
