Question about Toshiba 36A40 36" TV
Cable tv issue
TV turns on. Cable is on. TV will display guide but nothing else. No sound, just black screen when channel is selected. DVD player works and has sound on same TV.
  • 1 more comment
  • junejordan79 Mar 22, 2009
    i have the same problem and yes it only shoes channel 2-13
    i have this problem and it only shows channels 2-13
  • evil_dimples May 11, 2010
    Will it display a picture on channels 2 through 13?
  • 40 Answers
First ,replace the tv-dvd cable,then ask me again.
Posted on Aug 01, 2008
Hi I have a l32wd12 r a TV and it will not turn on
If the clock is on then the unit is receiving power; maybe the external input feature (which tells the TV which outside source to display on the screen, e.g. cable TV, DVD player, VCR player, etc.) is not set to display the TV channels. On my Sony TV there is a button that displays TV setting options (e.g., Favorites, TV List, External inputs and settings). The external inputs function displays the options as video 1, video 2, etc., right up to video 6. My video 3 is for the VCR, video 4 is for the DVD, and video 5 is for the cable TV channels. If the TV is set for say video 3 and nothing is playing on the VCR, the screen will be dark (almost as though the TV is off). Your solution might be as simple as choosing the right external (video) input for the TV to receive the channel signals.
Sep 19, 2014 | Televison & Video
Hook up and programming
have you try to check the the video cable connections from the dvd to the tv..?
Jun 19, 2008 | Sanyo DVW-5000 DVD Player/VCR
I was hooking up my sisters surround reciever for her and used an optical cable to the reciever from the TV. Her TV gets signal from the cable box via coax and uses HDMI from DVD player. I am stumped that...
srry but the tv is not capable of sending hdmi audio through its outputs the dvd player audio must be run through rca red and white or black if you have digital audio out to the back of the receiver on its own channel
Jan 11, 2011 | Audio Players & Recorders
It says "play" and my tv is on Ch.3 but there is nothing playing. I tried turning my direct tv off but it made no difference.
do you want to record programs on your vcr? connect the out to tv cable from your dir/tv box to antenna or cable in on the vcr, then connect the cable from out to tv on the vcr to antenna or cable in on the tv, you'll have to select channel 3 on the tv to get the vcr to show a picture and you will need to select channel 3 on your vcr to record the channel selected on your dir/tv box. confusing?thanks and good luck.
Jan 02, 2010 | GoVideo Go Video DVD/VCR Combo
How do you hook up the dvd player to the tv with a vcr hooked up to the tv
Leave the cable box powered on but disconnected from the TV or VCR. All other components should be disconnected and unplugged, giving clear and easy access to all connections. If components sit in an entertainment unit, make sure all A/V cables can reach the RF modulator and the cable from the modulator can easily reach the television.
  • Step 2 Hookup the first coaxial cable from cable box output, usually labeled "TV," "TV out" or "Out to TV" to the cable "In" on the VCR. Connect the second coaxial cable from the VCR's out to "TV" to the coaxial input on the RF Modulator.
  • Step 3 Connect the third coax cable from the coaxial cable "Out" jack on the RF Modulator to the coax cable "Input" on the television.
  • Step 4 Take one A/V cable, connect the red (right audio channel,) white (left audio channel) and yellow (video) from DVD player's "Output," to the corresponding DVD "inputs" on the RF Modulator. Place components as desired but still disconnected from power. Plug in all power cables including the RF Modulator's into the surge protected outlet strip.
  • Step 5 Make sure the Channel select switch usually found on the back of the VCR and the Channel select switch on the RF Modulator are both set to Channel 3. This channel is used on the television to view your components.
  • Step 6 Turn on the power strip and turn on the TV. Cable reception should come on as usual. Set the TV to Channel 3 and turn on the VCR. With VCR on test it by playing a video tape. The RF Modulator should sense the signal and automatically switch to "VCR."
  • Step 7 Switch off the VCR and with the television still on channel 3, turn on the DVD player. As the RF Modulator senses the DVD player signal and switches to DVD, its welcome screen should be seen on the television. Play a DVD to test and once you're done with the DVD turn it off and the cable should come back on.
  • Jul 15, 2009 | Televison & Video
    Sony 60in Grand Wega Channel Guide comes up/Screen goes Blank
    u may have a bad cable box ( drectv) try a dvd player on the tv if it work fine that means u have a bad cable box ( drectv)
    May 08, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
    Bought a proscanlcd hdtv 32lb30Q unable to get cable signal
    Hi and welcome to FixYa,
    Initially, pls confirm if below is how it is wired using a coaxial cable and not 3cable RCA to RCA:
    • Charter Digital Cable > DVD/VCR > TV
    If yes and your concern is snowy or no signal on the TV screen, might it be that you have to power OFF the DVD/VCR when selecting channels on the TV itself (including when channel setup is being done).
    Alternately, you can tune the TV to channel 3 and let the DVD/VCR do the channel selections.
    Pls post back results. Good luck and thank you for using FixYa.
    Jan 26, 2009 | Televison & Video
    VCR/DVD player DVP3340V/17
    Are you using the cable connectors to go into the VCR, and then from the VCR to the TV?
    If so, turn the VCR on. Put the TV on channel 3 or 4 (depending on which one you have it set to. If you are unsure, try both channels one at a time) Press the VCR/DVD button so the display on the VCR says VCR (not DVD). Now, you should be able to change the channel with your VCR remote control. If not, you have a problem with your cables. Make sure your cable from the wall goes to RF IN on your VCR. The RF Out on the VCR should go to your TV ANT In or TV RF In.
    If you have successfully gotten your TV to display the TV station shown on the front of your VCR, then all you have to do is put in a tape, select the channel you want to record and press the record button.
    If you want to watch another channel while you're recording, press the TV/VCR button on the VCR remote, then use your TV remote to change channels.
    When you want to stop recording, press the stop button, put the TV back onto channel 3 or 4 (depending on what you have it set to) and press the TV/VCR button on your VCR again. From here you can rewind and view your recording.
    Jan 18, 2008 | Toshiba SD-V394 DVD Player/VCR
    NO MENU SCREEN ON TV
    You MUST connect the recorder to the Tv with a SCART cable that is why you are not seeing anything.
    I suspect you are using only the RF or Ariel Cables
    If you have it connected with the scart cable you must choose the AV channel on your TV remote.
    Nov 13, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
    Channel jumping
    Sounds like the PIP feature is causing the problem with the TV if you are connected directly to cable TV without a box inline and getting these issues.
    Apr 10, 2007 | Sony KV-36XBR450 36" TV
    Toshiba 36A40 36" TV Logo
    57 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
