Hi, i am vivek & i want to know about the J & F key in my laptop as they have small dashed line at the bottom of them why is it so
    Problem Solver:
  • 9 Answers
Those are for knowing where to position your index fingers on both hands when you want to use 10 fingers typing on the keyboard. They help you to automatically place your fingers correctly without looking at the keys, just by feeling the bumps.
Posted on Aug 23, 2010
Tension settings
Some general suggestion - not familiar with White. If you know where the tensioner is, take a scrap of relatively stiff cloth in a constrasting color to the thread to make it easier to see. A good stitch tension will look like a line of adjacent dashed on top and dash-dot-dash on the bottom. If you are seeing dash-dot-dash on top and Dash-dash on the bottom, the tension is too tight. If - usual case - the bottom has dash-loopyloop-dash, or worse, snags, the tension is too loose. Remember tension may need to be adjusted for thicker or thinner work.
Jan 20, 2014 | White Sewing 1418 Mechanical Sewing...
Hi Expert, Whenever i am going to start my system, it will be hanging two to three time, each time i have to restart my system. Just would like to know what is the issue causing this...
Vivek, you may have a virus (there are many that causes this action) as a suggestion try these programs first:
1. Go to www.SuperAntispyware.com and download the free (yes I said free) program, after doing so run at least the quick scan to see if it finds anything. Do this even if you have a anti-virus program in place. If it's clean good if not then clean it.
2. Go to www.MalwarebytesAntimalware.com and download this program (also the free one) then run the quick scan on this program.
Usually these two programs will clean out the viruses that causes the problem you have. If this doesn't work then you need to Restore your computer to a time when your computer was working properly. I'm assuming you have some kind of Window's program. Go to start, click on Control Panel, click on Systems & Security, then click on back up and restore, follow instruction on restore to prior/previous date. Your computer will either automatically shut down & restart or it will ask you to shut down & restart. This should do it. If not I hope you have a back up DVD/CD that you can use to restore your system. If you have Windows 7 or Vista and you did what is suggested to do about saving a repair disc or a Mirror Image disc that I suggest doing either of those to restore you computer to when it was like when it was bought. I hope this helps. Be patient this all takes time.
Sep 17, 2011 | Sony VAIO VPCEA36FM/W Laptop
How do you put a key back on a laptop keyboard. It is a plastic key with a sissor latch and a small diameter metal rod bent into a wide square bottomed U. My daughter pulled it off can't get it to latch...
You have to get the sissor part back on first,
there are 4 small i-holes in a square on the keyboard,,
on the sissor part there is 4 small nubs on each corner, thay clip into the 4 i-holes,,
the key itself just clips down on the sissor part.<---Make sure its lined up b4 pushing
May 16, 2010 | Toshiba Satelite A135-S2286 Notebook
My laptops mouse is not working
IF you are referring to the external mouse attched to your laptop
then please check the same mouse with some other systm to verify if
the issue is with the mouse or with the laptop.
if the mouse is working fine with other system, then you need to
contact the service provider of your laptop.
Otherwise you have to buy a new mouse.
If you are referring to the touch pad of your laptop not functioning
properly, then please check the touch pad settings through control panel.
otherwise please shut down the laptop.
Take out the baterry out & wait for atleast 1-2 minutes.
Reinsert the Battery in the laptop & reboot the laptop.
Check if the mouse is working fine or not.
If the problem with the laptop still persist, please contact your
laptop service provider for further support.
Hope this will help you in resolving the issue.
Cheers!!!
Vivek
Dec 26, 2009 | Computers & Internet
My toshiba laptop works and i have a wired router which works. however i am not able to connect to the internet. it indicates that the network adapter is unplugged but it isnt
If you are not able to get the internet connection on your laptop, then please try to doa hard rebet on your Router.
IF that does not work get in touch with your ISP & let them do a soft reset from there end.
It should work for you.
Hope this will hep you in Resolving the issue.
Cheers!!!
Vivek
Where do I find the WEP key code on my modem model number 2247NWG
the network administrator (whoever configure your router) should have the wep key you're looking for, if you're that person and forgot your wepkey you need to reset your router so you can go back into the router configuration page and reset a new key (and hopefully you'll remember it next time).
here some instructions for your product:
check on page 14 (FAQ) of router's manual
resetting router to default configuration (router's manual)
good luck!
Dec 26, 2009 | Netopia 2247NWG-VGx Wireless Router...
Lenovo 3000 N200 Power Problem
It seems like the issue is with your Laptop Battery.
Please try to check the same battery with some other laptop & see if that works, other wise you have to go for a Battery Replacement.
Hope this resoultion will help you to get the battrey issue resolved for you.
Cheers!!!!
Vivek
Dec 25, 2009 | Lenovo 3000 N200 PC Notebook
Cd tray will not open
Hi friend,
You should mention your CD-ROM company name. second thing ...you CR ROOM try has been damage so you need to contact any hardware eng. they will fix it...
Dec 25, 2009 | Gateway GT5220 PC Desktop
My samsung r60 plus laptop, wont boost up, when i turn on the screen is saying,program system not found
This seems to be an issue with the battery of your Laptop.
This is a Reset process & does not mean that the Battery is gone wrong. Try to reinstall teh Battery of the laptop.
But if Reinstalling the battery does not work then battery must be defective.
Hope this will help you to resolve your issue...
Cheers!!!!!
Vivek
Dec 17, 2009 | Computers & Internet
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
