Question about GE WWSE5200B Top Load Washer
My washing machine does everything but the spin cycle. It sounds as if the motor is running, however. Any suggestions?
Belt slipping or broken? Does the spin motor spin up and sound like its going fast?....Most of them you can see the pulley from the top or bottom if you remove the top cover via small philips screws. Turn it OFF before removal please....
Posted on Aug 23, 2010
Does everything else except the tub does not spin in spin cycle
needs new bushes for motor they are maybe at there limit when the bushes get to a certain lenght the motor will not pick up in spin cycle this stops the motor from being damaged.
suggest you try this first..
Jul 07, 2009 | Washing Machines
Kenmore 110 Heavy Duty 70 Series Washing Machine won't spin
Can you move the basket by hand...if so you need a basket drive. If not you have a bad clutch or gear case
Jun 07, 2017 | Kenmore 24032\24036 Top Load Washer
I HAVE ROPER WASHING MACHINE THAT WILL DO EVERYTHING BUT SPIN
Check the coupling between the motor and gearcase. It is likely worn out. Hope this helps!
Feb 16, 2009 | Roper RTW4100SQ Top Load Washer
Washer making noise during the spin cycle
Hi!!! it looks like your motor coupler is failing..Good luck..
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
coupling between motor and drive assy broken. take motor loose and you can get it out. Visual check first to see if motor is running when in agitate cycle.
Dec 03, 2008 | GE WBSE2090A Top Load Washer
Hot point Washing Machine
LOTS OF VARIATIONS.  SOME W/MACHINES HAVE A SOAK BUTTON WHICH HAS TO BE DEACTIVATED TO ALLOW WASH CYCLE.   possibly wash winding defective.  could be loose connection at motor terminal as there are connections for spin and forward/reverse(wash cycle).if unit has element, select low temp and see if it washes.  need techi otherwise.
Oct 24, 2007 | Washing Machines
Washing machine wont spin
Try and help it to spin in the spin mode.. if it moves.. sounds like a clutch problem ..IF NOT... you may have something like nail, screw ect... binding the spin tub from moving.. get a flash lite do some close checking inside the spin tub
Aug 28, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Wash machine will not spin
sounds like a problem with the coupling between to motor and the gearbox!
Jul 15, 2007 | Kenmore 24032\24036 Top Load Washer
Spin cycle trouble
possibly a segment has raised on the motor armature or a faulty motor brush. pop off the belt and put it into a spin cycle to see if you still hear the noise- if so the fault is with the motor as the drum will be still. any scraping sounds in the drum may be a lost bra wire.
Jun 03, 2007 | Asko W640
GE WWSE5200B Top Load Washer Logo
83 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
