Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
I have a kitchenaid fridge model ksr251lsso2 serial sp1152492 lots of ice under the freezer aliment and the right temp for freezer and fridge thanks
  • 4,070 Answers
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good.It's part 6 in this diagram. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5141669&diagram_id=951779#d951779
Posted on Aug 23, 2010
Kenmore side by side refrigerator model 596.50009100 not cooling.
I would make sure they fan on the bottom that cools the condenser is turning easy way to test is. Put a fan in front of the fridge blowing under it if it starts cooling that is now working right
Nov 12, 2013 | Refrigerators
What is freezer and refrigerator temperature suppose to be set on
If you want to set the temperature your Fridge/Freezer should maintain, you need to set the Freezer to between -19c and -23c, however if you will be keeping Ice-cream in this freezer then it's best to set the base temp @ -21c minimum, -23 preferable, or the ice cream may begin to break down (very slowly I might add). The Fridge needs to be set to a maximum Highest temp) of 5c, any higher and the food will not stay as fresh and bugs will be able to breed, preferable temp is approximately 3-4c.
Jun 20, 2012 | Jenn-Air JSD2789GES Side by Side...
Over temp light on and refrigerator/freezer not staying cold.
Extended warranties usually are not worth the cost. My guess is that KitchenAid wants you to pay $73 out of pocket even though it should be absorbed as part of the warranty replacement of the refrigeration system.
Mar 08, 2017 | KitchenAid KBRC36FMS Bottom Freezer...
My kitchenaid fridge does not get ask cold as it has in the pass The freezer is cold but will not make ice cubes and i have it the highest setting.The fridge is cold but not as cold as before.I have clean...
Is the condenser fan and evaporator fan working? Is there frost build up on inside back wall of freezer? Either fan nor working would affect the cooling capacity. If there is frost in freezer, you have one or more defrost components (timer, heater, thermostat) bad.
Sep 02, 2017 | KitchenAid Refrigerators
Freezer is ice cold, but bottom isn't cold at all.
your fan motor that transfers cooling from the freezer to the fridge has gone out. What this fan does is maintain the temp of the fridge that you have set by pulling air from the freezer to meet the temp. To find this fan you need to look at the temp adjustment switch on the inside of your fridge. This will be located in a plastic tray assembly with vent slots cut into it. Right behind those vent slots lays the motor. Easy to remove take model and serial # to an appliance parts house for replacement.
Good luck hoped I helped you some
Dave
Jan 23, 2010 | Whirlpool ER6AHKXPQ Top Freezer...
Ice building up in the bottom of the freezer
The water supply line is leaking.Put some paper towels down after you clean up and check real often to back track where leak is coming from,maybe your ice maker is over flowing with water.When was the last time you replaced your water filter?Could be backing up,just replaced mine,it was leaking under the fridge,mine is a Sear's Kenmore,ordered a filter from Sear's,Cost me 50 buck's,My filter is at the bottom front,your's may be inside the freezer.
Apr 13, 2017 | KitchenAid KBLC36FKS Bottom Freezer...
Fridge not cooling
your defroster seems to be out. This is located in the space between your freezer and fridge where your temp. control is. This defroster can be purchased at an appliance parts supply take model number and serial number with you in order to get the correct part. Once part is obtained follow instructions and unplugg unit before servicingf
Jul 13, 2009 | KitchenAid KSCS25FKSS Side by Side...
KitchenAid fridge model KSRA22KNSS overfreezing
Yes it sounds like the thermostat, depending onmodel you can change yourself. Here is a video that shows how to check your compressor is working correctly.
https://www.youtube.com/watch?v=5LvTdvyIFyg
Nov 30, 2017 | KitchenAid KSRA22KNSS
Freezer not getting cold
Call local Repair shop, No Fix possible, leak in the coils, can't repair.
buying new fridge.
Mar 22, 2009 | KitchenAid Architect® Series II KBRS22KT...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
73 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
