Question about Nortel T7316E 2-Line Corded Phone
How can I retrieve the calls after I have scrolled through.. if I need to go back to or three calls to see the number
  • doncad Aug 31, 2010
    I had already read the guide; the answer to my question is not there.
    I would like to be able to look back at the caller ID list after I have looked once. There doesn't seem to be a way to do that except for starting over with 50 calls.
    President:
  • Nortel Master
  • 860 Answers
To view your previous calls enter feature 812 (call log). If you want to program a button for call log press feature *3, press the button you wish to be a call log button, then press feature 812.
Posted on Aug 31, 2010
    President:
  • 1,070 Answers
Welcome to FixYa
Dear User
This Guide can Help you to Program and all about your Product.Download it From here[Read it Carefully to Solve your any question about this Programming-You should Need Acrobat Reader to View this Guide].Or From here...
Thanks for Connecting FixYa
Posted on Aug 30, 2010
How do I retrieve message when away from my home
Simply call home using a touch-tone phone:
While listening to the answering machine greeting,
key in your chosen Remote Code using the keypad
on your calling phone and your new messages will
be played for you.
The Remote Code was chosen via a handset at home:
press [menu]
scroll to "Ans. Setup"
press [select]
scroll to "Security Code"
press [select]
enter the two-digit code of your choice,
press [select] ( chirps ) press [END]
Remote *management* of the answering machine is
further described in the owners' manual. To obtain
a replacement manual, you'll need the precise model
number of your phone: this is found on a small sticker
underneath the battery inside the handset. Take this
model number (eg, D1680) to www.manualslib.com
and you can download a free copy of the manual.
Feb 21, 2016 | Uniden Cordless Phone
Tip
How to Retrieve Deleted Contacts from a BlackBerry?
To retrieve deleted contacts from the call log is a simple task that can be achieved by accessing the call log on the BlackBerry handset. However, if the deleted entry wasn't listed on your call log, BlackBerry Desktop software is the only solution for you. It's a tool for backing up and restoring phone data to your computer. According to BlackBerry, you must regularly back up files to your computer so you can recover device data if it ever gets lost, stolen or corrupted. To recover the deleted contacts using the latter method, you must already have the backup file saved on your PC. <br /> <i><b>Instructions</b></i> <br /> <b>Retrieving an Unsaved Contact</b> <br /> 1. Hold down the "ALT" key on your BlackBerry. 2. Type "LGLG." 3. Press "Menu" &gt; "Options." 4. Scroll down into the events list, and press "Menu." 5. Select "Hide All Types." 6. Scroll down the list, and highlight the "PhoneApp" option. 7. Press "Menu." 8. Select "Toggle Filter." 9. Select "Menu" and choose "Save." Now all calls and numbers dialed from your phone will be shown to you. You will have to do a lot of digging to find the particular deleted number you're looking for. When you find it, select the particular entry to see the full number. <br /> <b>Retrieving Contacts through Backup</b> <br /> 1. Connect your BlackBerry to the computer through its USB data cable. 2. Launch BlackBerry Desktop software with which you had backed up your data earlier. Go to "Start" and search for the "BlackBerry Desktop" program. 3. Click the "Device" tab on the application window. 4. Click "Restore." Select a backup file that contains the contacts that are to be restored. You will find contacts under the "Organizer" tab. Simply check the box next to "Contacts." 5. Click "Restore." The deleted contacts will then be restored, after which you can disconnect the USB cable. <br />
on Jun 06, 2011 | Cell Phones
How do you retrieve the last number called to this phone?
If you have a CiX system with Caller-ID, a Caller-ID "review" or "log" key must be assigned on the set. Also, a CID buffer of (x) calls must be assigned in system programming. Once done, to review calls, press the CID Log key, scroll up and down using the NEXT/PREV soft key. This does not work on the older DK systems.
Dec 16, 2015 | Toshiba DKT2020SD Phone
I mistaken enter code to my sun sim three times so my sun sim is puk block and i lost my puk code what i well do to recover it
You have to bring the sim at a nearest SUN store for the puk. Or call their customer service at 200 and provide the serial number written at the back of the sim.
May 25, 2015 | Samsung Cell Phones
"Error retrieving information from server"[RPC:S-3]
It's a windows 7 server error and thus most likely the fault of the web site in question. It's failing to verify your log-in. You may have to remove your gmail account log-in from the tablet.
Try going Settings>Accounts>Google>Tap your account> tap three dots in the upper right (or press menu button) "Remove Account".
Go to "Settings"->"Applications"->"Manage Applications"
Select "All"
Scroll to and tap "Google Play Store"
Tap "Force Stop", tap "OK", tap "Clear data", and tap "OK".
Tap the Back button to get back to the applications list.
Scroll to and tap "Google Service Framework" (or Google Play Services)
Mar 13, 2014 | Samsung Galaxy Tab 2 7.0 4G LTE Verizon
Retrieve incoming phone number
Not on a Mitel SS4025, but if it's absolutely mission-critical, your PBX support person should be able to retrieve the call record from the system logs provided you get to them before the buffer overflows. Hope this helps.
Jan 07, 2014 | Mitel Superset 4025 Corded Phone...
I have accidently deleted my call history and i need to retrieve a number, is there a code to help me get my call history back for samsung c3050
Amanda, There is no way that you can retrieve the deleted data in the mobile phones.
Hwever, you can make a request to the service provider for your call records between the dates that you remember when that call came. They can give your call record for that period.
Jun 30, 2011 | Samsung Cell Phones
Pin number
If you have lost your pin number, the only way to rest the PIN is either using a different SIM card, or entering wrong PIN three times, triggering in PUK code, and then calling SIM card phone company to unlock the PUK.
A lost PIN cannot be retrieved, only the PUK can be discoverd, but you will have to call the phone company.
PUK means "personal unlocking key" .
The PUK code is asked if you enter a wrong pin 3 times.
You need to call the phone company that released the SIM card, they can retrieve the PUK code from a database for free.
In your case you need to contact your SIM card provider technical support to unlock the SIM.
The SIM card provider is the brand on the SIM card. For example if you have a Vodafone card, you will need to call Vodafone to get the PUK.
The PIN and PUK are related to the SIM card, not to the phone.
If you replace the SIM card with a different one, then the phone will not ask for the PUK anymore.
Mar 23, 2009 | Motorola Mobility RAZR V3
How to set up voicemail on i phone
<<This is straight from TracFone support for setting up voicemail on the Motorola C139....enjoy>>
Thank you for your interest in TracFone Wireless. We are responding to
your recent inquiry.
TracFone Wireless would like to take this opportunity to apologize for
any inconvenience this issue may have caused you.
Your voicemail box has been reset. To set up and retrieve voicemail from
your TracFone:
Press the MENU key,
Scroll to MESSAGE and press SELECT,
Then scroll to VOICEMAIL and press the MENU key,
Next scroll to VOICEMAIL SETUP and press SELECT,
The VOICEMAIL Access Number should be: +17044089979 and press the OK
key (if there is no + sign, please press and hold the 0 key until it
comes up).
If the numbers there are different, press and hold the key below the
word CLEAR or DELETE until all the numbers disappear from the screen.
Then enter the number 17044089979 and press OK.
After programming the Voicemail Access Number on handset, please turn
the phone off and back on.
Then, press and hold the 1 key to auto-dial the VOICEMAIL box to record
greeting and complete setup.
Your temporary password can be 0000, 1111, 9999, the last 4 digits of
your wireless number, or another 4-digit number easy to remember.
All calls made to your voicemail from your TracFone will deduct airtime
units. To avoid being deducted airtime, it is recommended that you
contact your voicemail from a land line phone, by dialing your ten-digit
mobile number. To retrieve voicemail messages from a landline phone,
please follow the instructions below:
1. From your landline phone, dial your TracFone Number.
2. When you hear the greeting, press the star (*) key. If the star key
does not interrupt the greeting, press the (#) key.
3. Enter your password and follow the retrieval instructions.
Please note, if this procedure does not resolve this issue, we would
need to talk with you directly for further assistance.
Should you have any further questions or concerns, please contact one of
our customer care representatives at 1-800-867-7183. For your
convenience, our representatives are available Monday-Saturday from 8:00
AM to 9:45 PM EST, and on Sunday from 8:00 AM to 6:45 PM EST.
Thank you for being a TracFone Wireless customer. We appreciate your
business.
Sincerely,
TracFone Wireless
Sep 16, 2008 | Cell Phones
Motorola L6: how to change the # VM dials
Motorola L6 Keypad Layout
  1. From the stand by screen, press the Menu key.
  2. Scroll to and select Messages.
  3. Scroll to "Voicemail" and press the Menu key.
  4. Scroll to and select Voicemail setup.
  5. Select Voicemail No.
  6. View or edit the Mailbox Retrieval number, then select OK.
    Note: If the Voice Mail Retrieval number is unknown, contact Customer Care for the users local number or to have programming sent to the device.
Dec 13, 2007 | Motorola Mobility L6 Cellular Phone
Nortel T7316E 2-Line Corded Phone Logo
37 people viewed this question
Top Nortel Lands Phones Experts
David Burbee
David Burbee
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
