Question about Lexmark X342n All-In-One Laser Printer
902.33 service engine software - Lexmark X342n All-In-One Laser Printer
Lephone reset code
Secret Codes To Reset Your Chinese Mobile Phones
Chinese Mobile phones are flooding in the market. You get the same exact mobile phones as the branded ones like iPhone clone, HTC Touch clone, Nokia N97 clone, Palm Pre clone. Chinese mobile manufacturers have all the clone mobile phones, you name it and they have it. If you are one of those users who likes to use Chinese mobile phones, you might some day want to reset your Chinese mobile phones.
So here are the list of secret codes to reset your chinese mobile phones.
*#66*# Set Factory Mode CONFIRMED
*#8375# Show Software Version CONFIRMED
*#1234# A2DP ACP Mode CONFIRMED
*#1234# A2DP INT Mode CONFIRMED
*#0000# + Send : Set Default Language CONFIRMED
*#0007# + Send : Set Language to Russian CONFIRMED
*#0033# + Send : Set Language to French CONFIRMED
*#0034# + Send : Set Language to Spanish CONFIRMED
*#0039# + Send : Set Language to Italian CONFIRMED
*#0044# + Send : Set Language to English CONFIRMED
*#0049# + Send : Set Language to German CONFIRMED
*#0066# + Send : Set Language to Thai CONFIRMED
*#0084# + Send : Set Language to Vietnamese CONFIRMED
*#0966# + Send : Set Language to Arabic CONFIRMED
*#800# make Etel E10 model displaying message BT power on. But on display it dont resemble the blutooth power on icon.(actually t makes BT stuck, but after restarting t becomes normal <tested by me>)
More codes to reset chinese mobile phone
*#77218114#
*#881188#
*#94267357#
*#9426*357#
*#19912006#
*#118811#
*#3646633#
also found these
Service codes Konka:
C926 software version: *320# Send
C926 set default language: *#0000# Send
C926 set English language: *#0044# Send
Service codes GStar:
GM208 (Chinese Nokea 6230+) engineering menu: *#66*#
Set language to English: *#0044#
Set language to Russian: *#0007#
ZTE Mobile:>1- *938*737381#
2- PHONE WILL DIPLAYED DONE
3- POWER OFF YOUR PHONE AND POWER ON AGAIN
alcatel:>E205
unlocking phone code,only press***847# without simcard
E900 software version: *#5002*8376263#
E900 full reset: *2767*3855#
Service codes Spice:
S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200
S410 engineer mode: *#3646633#
S900 software version: *#8375#
S900 serial no: *#33778#
Service codes Philips:
S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200
Service codes "Chinese" models:
default user code: 1122, 3344, 1234, 5678
Engineer mode: *#110*01#
Factory mode: *#987#
Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
Restore factory settings: *#987*99#
LCD contrast: *#369#
software version: *#800#
software version: *#900#
Service codes BenQ:
software version: *#300#
test mode: *#302*20040615#
Service codes Pantech:
software version: *01763*79837#
service menu: *01763*476#
reset defaults (phone/user code reset to default): *01763*737381#
Service codes VK-Mobile **x, 5xx:
software version: *#79#
software version: *#837#
service menu: *#85*364# (hold #)
Service codes VK200, VK2000, VK2010, VK2020, VK4000:
service menu: *#9998*8336# (hold #)
reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
Service codes LG:
software version: 2945#*#
KG300 NVRAM format: 2945#*# -> menu 15
Service codes Sony-Ericsson:
J100 software version: #82#
Service codes Fly:
M100 software version: ####0000#
2040(i) reset defaults: *#987*99# Send
MX200 reset defaults: *#987*99# Send
MX200 software version: *#900# Send
SL300m reset defaults: *#987*99# Send
SL300m software version: *#900# Send
SL500m reset defaults: *#987*99# Send
SL500m software version: *#900# Send
MP500 reset defaults: *#987*99# Send
MP500 software version: *#900# Send
Service codes Motofone-F3:
Motofone F3 software version: **9999* Send
***300* Set SIM Pin
***310* / ***311* SIM Pin ON ' OFF
***000* Reset Factory settings
***644* Set Voicemail number
***260* / ***261* Auto keypad lock ON ' OFF
***510* / ***511* Voice Prompts ON ' OFF
***160* / ***161* Restricted Calling (Phonebook only) ON ' OFF
***200608* Send: software version
***200606* Send: software version
***200806* Send: flex version
***250* / ***251* Keypad tones ON ' OFF
***470* Select time format
***500* /***501* Prepaid Balance Display ON ' OFF
***520* Change language
Service codes Motorola:
C113, C114, C115, C115i, C116, C117, C118 software version: #02#*
C138, C139, C140 software version: #02#*
C155, C156, C157 software version: #02#*
C257, C261 software version: #02#*
V171, V172, V173 software version: #02#*
V175, V176, V176 software version: #02#*
C168, W220 software version: *#**837#
W208, W375 software version: #02#*
and "yes"''
I-mobile Inno30, 55, 89, 90, 99, 100, A10, A20, P10, Vk200
- Set full factory *741*737381#
- Set full factory *741*7373868#
- Set full factory *741*2878#
- Set Engineer Mode *888*888#
- Check software version *888*837#
I-mobile 100 ,200 , 313
- Check software version #*888#
I-mobile 309, 310
- Check software version *0*4636#
- Test Mode *0*6268#
I-mobile 311
- Check software version #*878#
I-mobile 511
- Check software version *1222*1#
I-mobile 301, 302,308, 508, 601, 602, 603, 604, 606, 611, 901, 902
- Check software version *#159#
- Set Factory Mode *#32787#
- Set Engineer Mode *#3646633#
I-mobile 503, 506, 605, 600, 607, 608
- Set Engineer Mode ***503#
- Set Factory Mode ***504#
- Set Auto Test ***505#
I-mobile 509, 612
- Set Factory Mode *#66*#
I-mobile 504, 505, 803
- Check software version *68*48#
- Set full factory *789#
- Test Mode *#789#
I-mobile 305, 306, 315, 510, 609, 609i,516
- Check software version *#8375#
- Set Factory Mode 878
I-mobile 610
- Check software version *#22#
I-mobile J101, J102
- Test Mode *23638777*783781#
I-mobile 502, 502i, 505, k9, 802
- Check software version *201206*4636#
Jun 25, 2014 | Cell Phones
Tip
Service codes Chinese models
  1. Service codes "Chinese" models:
  2. default user code: 1122, 3344, 1234, 5678
  3. Engineer mode: *#110*01#
  4. Factory mode: *#987#
  5. Enable test mode COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
  6. Restore factory settings: *#987*99#
  7. LCD contrast: *#369#
  8. software version: *#800#
  9. software version: *#900#
  10. Service codes BenQ:
  11. software version: *#300#
  12. test mode: *#302*20040615#
  13. Service codes Pantech:
  14. software version: *01763*79837#
  15. service menu: *01763*476#
  16. reset defaults (phone/user code reset to default): *01763*737381#
  17. Service codes VK-Mobile 3xx, 5xx:
  18. software version: *#79#
  19. software version: *#837#
  20. service menu: *#85*364# (hold #)
  21. Service codes VK200, VK2000, VK2010, VK2020, VK4000:
  22. software version: *#79#
  23. service menu: *#9998*8336# (hold #)
  24. reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
  25. Service codes LG:
  26. software version: 2945#*#
  27. Service codes Sony-Ericsson:
  28. J100 software version: #82#
  29. Service codes Fly:
  30. M100 software version: ####0000#
  31. 2040(i) reset defaults: *#987*99# Send
  32. MX200 reset defaults: *#987*99# Send
  33. MX200 software version: *#900# Send
  34. SL300m reset defaults: *#987*99# Send
  35. SL300m software version: *#900# Send
  36. SL500m reset defaults: *#987*99# Send
  37. SL500m software version: *#900# Send
  38. MP500 reset defaults: *#987*99# Send
  39. MP500 software version: *#900# Send
  40. Set language to English: *#0044#
  41. Set language to Russian: *#0007#
  42. Service codes Konka:
  43. C926 software version: *320# Send
  44. C926 set default language: *#0000# Send
  45. C926 set English language: *#0044# Send
  46. Service codes GStar:
  47. GM208 (Chinese Nokea 6230+) engineering menu: *#66*#
  48. Set language to English: *#0044#
  49. Set language to Russian: *#0007#
  50. Service codes Motorola:
  51. Motofone F3 software version: **9999* Send
  52. C113, C114, C115, C115i, C116, C117, C118 software version: #02#*
  53. C138, C139, C140 software version: #02#*
  54. C155, C156, C157 software version: #02#*
  55. C257, C261 software version: #02#*
  56. V171, V172, V173 software version: #02#*
  57. V175, V176, V176 software version: #02#*
  58. C168, W220 software version: *#**837#
  59. W208, W375 software version: #02#*
on Mar 07, 2010 | Cell Phones
Tip
CHINA PHONES CODES
More some codes for reset mobile
china
*#77218114#
*#881188#
*#94267357#
*#9426*357#
*#19912006#
*#118811#
*#3646633#
CHINESE MODELS:
set English language (new firmware): *#001# Send
also
Service codes BenQ:
Service codes 3xx, 5xx:
Service codes LG:
Service codes Fly:
ZTE Mobileyahoo15.gif1- *938*737381#
alcatelyahoo15.gifE205
Service codes BenQ:
Service codes LG:
Service codes Fly:
***300* Set SIM Pin
***310* / ***311* SIM Pin ON | OFF
***260* / ***261* Auto keypad lock ON | OFF
***510* / ***511* Voice Prompts ON | OFF
***160* / ***161* Restricted Calling (Phonebook only) ON | OFF
***250* / ***251* Keypad tones ON | OFF
***500* /***501* Prepaid Balance Display ON | OFF
and "yes"''
I-mobile 309, 310
I-mobile 311
I-mobile 511
I-mobile 509, 612
- Test Mode *#789#
I-mobile 610
I-mobile J101, J102
on Mar 11, 2008 | Nokia N95 Cellular Phone
Downloadable service manual for 1998 cavalier 2.4
1998 Chevrolet Cavalier Service & Repair Manual Software
1998 Chevrolet Cavalier Service Repair Manual Software Download Manuals...
LICENSED OEM SERVICE AND REPAIR MANUAL SOFTWARE FOR THE 1998 CHEVROLET CAVALIER!
If you need a repair manual for your Chevrolet, you've come to the right place. Now you can get your repair manual online in convenient digital format. Old paper repair manuals just don't compare! This online repair manual software covers the Chevrolet Cavalier and is perfect for any do-it-yourselfer.
In the dark old days of auto repair, you had to buy a traditional service manual in book format which would retail at a higher cost. Getting the same information in digital format is so much less expensive and more convenient!
Maybe you need the manual to fix the brakes on your Cavalier, or possibly replace some worn out suspension components. Or you might need to get your engine running, or just do the required standard maintenance. Whatever the case may be, this repair manual software for the Chevrolet Cavalier is just what you need.
You will have all the service information you could ever need for your vehicle. It will help you fix the brakes, engine, suspension, steering, drivetrain, electrical problems, heat, air conditioning, etc. Anything can be fixed!
You can save a lot of money by working on your own vehicle. You probably already know this, but mechanics charge a lot. Do it yourself and use this 1998 Chevrolet Cavalier repair manual software to guide the way.
It gives you the manual for your Cavalier and it's very easy to use. It is compatible with any Windows computer including desktop PCs, laptops, smartphones and tablets.
License includes 1-year access to OEM service and repair procedures and unlimited access to supplemental data.
Sep 05, 2011 | 1998 Chevrolet Cavalier
900 service rip software error on our Lexmark Optra S1855 what does it mean? How do I fix it?
These errors indicate an unrecoverable engine software
error. Replace the engine board is the only solution
Apr 07, 2010 | Lexmark Optra S 1855 Laser Printer
Tip
Samsung rest code Service codes Samsung: E900...
samsung rest code Service codes Samsung:
Service codes BenQ:
on Feb 09, 2008 | Samsung SGH-E900 Cellular Phone
Lexmark T520 I get an error code 900 service RIP software. further 44 p4 notify 001c-0300 page4/bios/fountain/notify.c-223:Inv eot:0 what does that mean, do I need a new engine board, or can I clear this...
Typically the engine controller circuit cards go bad. the firmware (software) get corrupted. you can try upgrading the firmware but ordinarly you cant clear the 900 service fault to try that. So your only solution is the replace the engine circuit card.
Dec 22, 2009 | Lexmark Office Equipment & Supplies
My phone is not boot, i confirmed engineers they told motherboard software required, is it true mobile phone : k550i sony if it is true motherboard software problem from where can i get this software
Dear Sir,
Your phone software is available only at Sony ericson manufacturer and service provider.so visit nearer Ericson Service centre,otherwise call sony customer support,they will give you the nearer service centre address.
If you have any query post a feed back,we were happy to assist you.
Have a nice day
good luck
Sep 17, 2009 | Sony Ericsson K550i Cyber-shot Smartphone
900 Service RIP software error
a 900 rip error is the engine card. located behind the system board (formatter) if you can get the printer to a ready state you can phone 1800lexmark and get a pin code from them costs about 15 bucks. if this flash does not work you will likley need a new engine card.
May 04, 2009 | Dell Office Equipment & Supplies
Lexmark X342n All-In-One Laser Printer Logo
124 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
