Question about Dell W3706MH 37 in. LCD HDTV
Have two gray spot's on sceen - Dell W3706MH 37 in. LCD HDTV
  • Dell Master
  • 5,138 Answers
Look on power supply board for Bad capacitors they will be vented,swollen ,or puffed up on Top 1000uf 16v 220uf 10v 3300uf 10v 330uf 10v also Google to Encompass Parts and type in your model number to see if they are listing Parts and service manual for this model and another Place to Look for Parts is EBay look under Electronics TV/Parts
Posted on Aug 24, 2010
Gray spots on screen
Could be mainboard or more likely it is the display in either case you will need to contact acer tech support.
Jul 21, 2014 | Acer Iconia Tab A50110S16u 101Inch HD...
White spots on sceen
It sounds like a DMD apart of the light engine also, called the optical block.
The dots will increase day by day. part.
You can have the DMD replaced or the whole optical block. Unfortunately this is not a cheap repair. TVs are so cheap these days.
www.aaatvservice.com
Sep 02, 2012 | Mitsubishi Televison & Video
Bright Spot
A fixed blue area on screen may be a display panel (main screen unit)
Here is a link for the boards etc this set uses--take your pick:
http://www.shopjimmy.com/sceptre-x460bv-f120
May 17, 2012 | Sceptre 46 X460BVF120 LCD TV
Big gray spot on screen
Unfortunately, It's likely that your screen has been irreparably damaged. Probably, pressure was applied to the screen and ruined that part of it.
If you like to fix electronics, it may be possible to buy a non-working Sansa on eBay, open the case and replace the screen.
You can probably continue to use the player without fixing the gray spot. If it bothers you, the easiest solution would be to get another player....
Dec 03, 2011 | SanDisk Sansa Audio Players & Recorders
Why is my screen gray
Intermittedly LCD fault is caused by the faulty connnection within the cam.
Try and see if there is a pattern. It could be caused by temperature, particular mode or others
If in warranty I recommend repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Aug 11, 2009 | Kodak EasyShare V1003 Digital Camera
LG RU-44SZ51D 44 in - Gray Spots being projected
First trying cleaning off dirt /dust if after you do this and you still see spots then you could have a bad color wheel or bad light engine.
Jan 11, 2009 | LG RU-52SZ51D 52" Rear Projection...
Touch Screen bad on a XL1000
I have posted the answer to this problem if the sceen is misaligned just turn off the machine and hold down the frist to buttons turn the machine back on the singer sceen shows up touch ithe sceen it should freeze and then a small black box should show up touch the box and it should move to a differant spot touch it four times and then rub you finger accross the stright stiche white button at the bottum of the sceen this saves the changes.
Nov 08, 2008 | Singer Quantum XL-1000 Computerized Sewing...
I have a HT3061P Prima TV. The screen is gray color with horizontal lines,the audo is very good.
check the RGB supply it is 180volts or the capacitor value 10/250volts (4.7/250v, 2.2/250v)
Oct 16, 2008 | Prima CV2011 TV
Dell W3706MH 37 in. LCD HDTV Logo
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
