Question about Hotpoint Freezers
Red flashing light on ,green liht also on - Hotpoint Freezers
  • 21 Answers
Green is power on.
Red is below cut out temp check for air restrictions and fan.
Posted on Sep 02, 2010
Power is on but don't run
Is the red light flashing if so count the #of flashes it shows consecutively.then Google that #of flashes on that model you will get your answers. If just solid red you may have an issue in the board or compressor
Aug 11, 2014 | Haier Freezers
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
Red light on bosh classixx fridge freezer
sounds like compressor has failed to start and overload is triggered(red light) it could be start capacitor fault or overload itself faulty .
If both of these items ok and compressor has power to it then compressor will require replacing.when you switch of refrigeration equipement the oil in the system will drain down to the lowest point and thats normally compressor and if its filled up the suction side of compressor it will cause compressor to lock up (hydraulic)
Mar 14, 2012 | Bosch Freezers
Red light on, tripping the fuse box
Need to know if it's tripping a breaker or an RCD.
sound like an earth fault and tripping the protection.
you need a qualified professional.
Mar 27, 2010 | Freezers
I have a GE chest freezer and the exterior green light has started flashing. The freezer is less than a year old.
Is this just a "Power-on" light to let you know it's plugged in and has power? This is probably just a "neon" (although the actual gas inside is hydrogen for the green color) bulb and sometimes they will do the flickering thing literally forever. In a way it's a good thing as it makes you look at it. If it really concerns you, or if it is actually a warning that something is going wrong (it should say in the manual, you DO have the manual don't you?) have it fixed under the warranty.
Jul 07, 2009 | Haier 5 cu. ft. / 142 liter Chest Freezer...
New fan light running continuosly
lets see if i can help you out here, okay . Red is your hot power wire, Green is the ground which is screwed to mounting plate, black is negative, meaning no power.... connect your wires by color Red to Red , Black to Black , And if there is a green coming from the ceiling connect to mounting plate of fixture or vise versa. Remember to use eletrical scew caps, on all connections and do not leave any wires uncovered. Basically all your doing is a seperation of a wire from wires as you seperate a wire cap it off. then move to the next set and do the same. red to red black to black green to mounting plate . YOU WIL NOT BLOW ANYTHING UP IF THERE IS A WRONG CONNECTION, if all wires are of color follow these steps, if no color switch one wire try switch and vise versa YOU can do it
Jun 02, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
Flashing red light
red light flashing on servis fridge freezer
Mar 19, 2009 | Freezers
Servis frostfree fridge freezer
Hi, I had that last year - It was the control board!
Oct 24, 2008 | Freezers
Freezers Logo
82 people viewed this question
Top Hotpoint Freezers Experts
AJMAL KHAN
Victor Nwachukwu
Victor Nwachukwu
Gerard Curran
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
