The paper jam light is on. I have checked several times and there is no jam. I made sure no paper was in. Turned off the printer, checked the plugs and even re-installed it. It will not print. Is it probably dead? It is a Z22
    Scholar:
  • 72 Answers
Try taking out your ink cartridges. and reinstall them. Also check to see if your ink is low. If the printer has a rea cover remove it and see if the wheels the the paper is feed by is jammed or loose.
Posted on May 04, 2008
    Sergeant:
    Champion:
  • 256 Answers
Hi
remove cartridge an clean it ones.
Thanks
  • 1.remove cartridges an clean it
    2. replace cartridges.
    problem with cartridges....
Suddenly HPJ4580 has stopped printing - when pressing print the first sheet sails through the printer and out the back with no print and the second sheet jams - no matter what I do - changed paper - turned...
I have problems with paper jams all of the time and it won't print once it jams. I turned off the printer, unplugged it, plugged it back in and turned the printer back on and it worked. You could try that.
Jul 17, 2010 | HP OfficeJet J4580 All-In-One Laser...
Paper won't feed into printer & output slot jam error message
reboot your pc.unplug cables make sure you remove papers jams located at the back of your printer
Jun 24, 2010 | Canon PIXMA MP610 InkJet Printer
My dell v105 paper jam light keeps flashing even tho there is no paper jam. Have turned off and on again several times. Printer has just frozen and paper feed button does not do anythin.. HelP!!!
There might be either a small piece of paper or dust covering the sensor. Take out all of the paper from the printer. Using a can of compressed air blow out the entire paper path. Try the printer again. If it still doesn't work then you may have to get the printer serviced.
Sep 12, 2009 | Office Equipment & Supplies
Paper jam, need help urgently!
First check the Paper feed roller they maybe slick from paper dust, you need to clean them, then turn of the printer and remove the ink cartridges, turn macine over and check the under side of the machine for any sign of paper, remove any seen, then turn back over reinsert cartridges , turn machine on. paper dust sometimes covers the paper read sensor , causing a paper jam, and slick feed roller also contribute to frequent and pervasive paper jams.
Jul 12, 2009 | Brother MFC 240C All-In-One InkJet Printer
Paper jam
reset by unplugging and then plugging back in, also make sure no paper is stuck in the rollers on top or the back....make sure all rollers are free of dust and if they have dust wipe off.....make sure you using the right type of paper and the printer itself isn't dirty....hope this helps
Apr 06, 2009 | Brother HL-2070N Printer
Paper keeps jamming
try resetting by unplugging and then plugging back in, then make sure no paper is jammed in the rollers...make sure rollers are clean and they are not worn down, make sure your using the right type of paper.
Apr 05, 2009 | Canon imageCLASS MF5550 All-In-One Laser...
Top light with (x) blinking
Fixed this problem this morning by unplugging the printer from the computer, plugging it back in and changing out both cartridges (color and black) and replacing with new cartridges.
Don't know which helped. I had been unplugging the computer from the power source but not the printer from the computer.
My four year old printer is still cranking - good open forum you provide here. Thank you !
In that spirit, I decided to contribute my update ..... Judy
Sep 12, 2008 | HP DeskJet 5550 InkJet Printer
Out of paper..
ok check if the sensor is blocked make sure there isnt a jam in the printer.
make sure it is config right on the cmputer and on the printer itsself
generaly printers dont usualy last more than 5-6 months.
trying giving the makers a call and se what they think.
if all else fails i think it might be time to update
hope this helps
cheers
Jul 20, 2008 | HP LaserJet 1100 Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
jasbo
jasbo
