try to remove the dimm. try to switch on without dimm. it not successfully than try to check the cables from the power board to the formatter. try to push them in thir place. If this is not successfull too than it is a formatter problem. try to change the formatter
Are you usingoriginal HP Dimm chip?, does machine turn on and come to ready when it is standing on it own (not hooked to p.c.) if not can you tell me exact light patten displayed
The error message hp laserjet P3005n error 57.03 is due to sub cooling fan (FM2) error has occurred. Fan operation is verified
during device power up. Fan operation occurs only during power up or
during a print job.Turn the device off and then on. Verify that nothing is hindering or blocking the fan.
Verify that the fan is connected to connector J512 on the ECU PCA. You
might have to remove the main cooling fan to see this connection. If the message persists, replace the fan.
I don't know what printer you are using because a P3005N is a monochrome printer and doesn't use a cyan cartridge.
For a lot of colorlaserjets you can try the following steps. Remove all the cartridges, close all doors and power on the printer and then power it off. Insert the cartridges one by one and power the machine on and down each time you inserted a cartridge.
Printout a configuration page from the printer display, look wath it says according to the intern jetdirect.
Does the green led blinks on the back of the printer if not try another line or you NIC on the formatter board is defective.
Buy Q7848-60002 formatterboard P3005N/DN/X (incl NIC)
What is the error number that comes up there should be a code that is displayed. Once I have this number I will be able to tell you why you are getting the error and how to fix it.
