My problem p0440 and p0172 - Computers & Internet
  • 6,784 Answers
HI. You have placed the Auto DTC codes in the wrong position under PC Desktops. With that said; I will provide the definitions to the DTC codes you have posted above and their respective causes and solutions.
P0440- Evaporative Emission System
This indicates that a part of the EVAP control system is no longer functioning correctly. The EVAP system consists of many parts, including the gas cap, fuel lines, carbon canister, purge valve, and other hoses. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine. EVAP emission canister purge is controlled by a valve which allows engine vacuum to pull stored fuel vapors from fuel tank into the engine to be burned, rather than be vented into the environment. A vacuum switch is used to detect when flow exists. If the PCM/ECM commands purge and detects that the switch is closed, The code P0440 is set.
The most likely causes for this code will be a bad vacuum switch, broken EVAP line or canister, Restricted EVAP solenoid or canister, failed purge vale(likely culprit) or a failed PCM. A bad purge vale connector could also cause a misreading, as well. I would advise to reset the code and see if it returns. if so, check all the points above to correct. Replace any failed component that makes up the EVAP assembly.
P0172 - System Too Rich Bank 1
Basically this means that an oxygen sensor in bank 1 detected a rich condition(not enough O2 in the exhaust mix). This code will concern cylinder #1. The necessary actions are to:
  • Inspect all vacuum and PCV hoses, replace if necessary
  • Clean the MAF sensor. Consult your repair manual for it's location if you need help. We find it's best to take it off and spray it with electronics cleaner or carburetor cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
  • Inspect fuel lines for cracks, leaks, or pinches
  • Check the fuel pressure at the fuel rail
  • Check the fuel injectors, they may be dirty. Use fuel injector cleaner or get them professionally cleaned/replaced.
  • Check for an exhaust leak before the first oxygen sensor (this is unlikely to cause the problem, but it is possible)
  • NOTE_ Additionally; Concerning the P0440 code above, I would first remove and reinstall the gas cap, clear the code, and drive for a day and see if the codes come back. If it does, inspect all the points that I stated above in the P0440 code section. It would be a great idea to have a professional emissions tech to use a smoke machine to detect any leaks before you start your inspection.
Posted on Aug 23, 2010
Starts fine, however if you turn it off, and start it again, wont start, wait a bit then will start.
p0120 throttle position sensor/switch
p0172 system to rich bank 1
p0440 Evaporative Emissions failure
Apr 10, 2016 | 1997 Volvo 850
1996 Volvo GLT 2.0 valve, got two codes need to know what to do to fix them P0440, P0172.
http://www.datsc.com/tabid/122/OBD-Error-Code/P0440/Diagnostics/volvo/Default.aspx
And
http://volvospeed.com/vs_forum/topic/9451-ecu-fault-code-p0172/
Dec 25, 2015 | Volvo Cars & Trucks
P0172 2003 trailblazer
P0172 states that the "bank 1" side of the engine is running too rich.
Here is a link explaining it in more detail and giving possible causes and solutions.
http://www.obd-codes.com/p0172
Apr 14, 2015 | 2003 Chevrolet TrailBlazer
P0171 p0172
Here's code PO171.Here's code P0172.
May 08, 2013 | Ford Explorer Cars & Trucks
It is my husbands 1996 850 turbo SW, I had bought a Grupon oil change and maintenance inspection. He tested it and two codes p0172 and p0440, whatever that means. I don't drive the car, but I know it...
This is a combination of safety and environmental issues.
Driving with a damaged axle rubber boot will cause excessive wear on the CV axle. I will not recommend drive the car for extend period of time.
The axle grease will splatter on the inner wheel well and the ground your car travel to.
P0172 is a lean fuel mixture code
P0440 is a code that set by vapor leak from the fuel tank.
In some case it's just a loose fuel cap.
If this code res-surface after reset the it will require a vapor smoke test.to detect the location of the leakage.
Valve cover gasket leak is common on older car.
It's not expensive to replace the gasket.
Axle $400+
Valve cover gasket replacement $125
Vapor leak repair $100 to $200+ (depend on where and what part(s) us leaky).
Find a good local independently own shop,the owner may able to combine all these job and give you a better price.
Sep 06, 2011 | Volvo 850 Cars & Trucks
I have a '96 Jetta, and i got P0440, P0302, P0172 and P1613 codes. How can I fix this? I have to go to emissions test this month, but my check endine light comes on because of these problems.
P0440- EVAP Emission Control Sys Malfunction
Something unspecified is wrong with the evaporative emission system. Check vac lines. Could be a loose electrical connection. This code has a very vague description.
P0302- Cyl 2 misfire
Has the car had a tune up in the past few years? Check plugs and wires, test for spark. Maybe a compression test. This issue may cause the next code.
P0172- Fuel trim Bank 1 , too rich
I would clear up the misfire first, then this code might go away.
P1613- MIL Call-up circuit open/Short to B+
Check the wiring under & behind the dash and instrument cluster. There apparently is a wiring issue, or the dash itself is shorted
Jan 09, 2010 | 1996 Volkswagen Jetta
1996 chevy truck 5.7L has codes P0172, P0172 were
p0172 is--system to rich ( bank 1). an oxygen sensor on bank 1, detected a rich condition ( to little oxygen in exhaust ) v6-v8 - v10 engines, bank 1 is the side of the engine that has # 1 cylinder. causes could be a vacuum leak in a hose, a dirty or bad maf sensor, or fuel pressure or delivery problems.
Oct 29, 2009 | 1996 Chevrolet K1500
Check engine light obd2 code reads P0172
have you tried to goggle this?
Description of vehicle trouble code P0172. ... A code P0172 may mean that one or more of the following has happened: The MAF (Mass Air Flow) Sensor is dirty ...
Oct 13, 2009 | 2005 Volvo S40
I have a 2004 dodge caravan i get p0172 fault code
p0172 fuel system to rich , p2097 fuel mixture high downstream , p0480 cooling fan relay, hope this helps
Aug 27, 2009 | 2004 Dodge Caravan
Computers & Internet Logo
190 people viewed this question
David Payne
David Payne
