Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
MODLE NUMBER WTW6400SW HAS CODE DU AND DI COMING UP WHAT IS IT
  • 15,935 Answers
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 16, 2010
Machine won't complete spin/rinse cycle - begins but error codes due to unstability
Would love to help first need entire model number second did he give you the error code pertaining to this model
Sep 04, 2014 | Whirlpool WTW6400SW Cabrio Washer
My sim is block he ask me the puk code du sim card
Puk code can be got from the network operator.Call to the customer care of the network operator and by providing simcard number and mobile number they will provide puk code.It is free of charge
Oct 05, 2010 | Samsung SGH-D500 Cellular Phone
Du error code on a kenmore elite oasis he what does it mean and what can i di to fix the problem
Door unlock failure
retracting.
unlocked state. See TEST #8, page 14
Jun 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Have a Disney modle tv and need the code for a remote the remote is not working now modle # P1300NTV
Try setting it to cable remote--see manual or check back label for manufacturer's parts and accessories phone number.
May 19, 2010 | Disney 13" TV
Minolta dialta Di 470 donne code c 0210 puis
C210,transfer/separation corona malfunction.Change or clean the corona wire and the corona holders(white Assembly).
Jan 10, 2010 | Minolta Office Equipment & Supplies
Lg tv modle DU-37LZ30 on off indicator light is
Most likely a power supply problem. I recommend taking this to a certified technician and having them look at it.
Nov 04, 2009 | LG DU-37LZ30 37 in. LCD HDTV
Hei har d-link 524 sikkert nettverk.I kveld kommer det opp med usikret nettverk og eg fr ikke logget megp?¥
bør du sette inn WEP eller WPA til å sikre nettverket. Det er ikke vanskelig bare huske å skrive det ned et sted, slik at en ikke skal glemme det.
Jeg håper dette er det du ville vite. Lykke til min venn lar vurdering, takk vennlig.
Apr 30, 2009 | D-Link AirPlus DI-524 Wireless Router
Hidden code?
You mean under "here" and "D-link", it's so easy, use the icons above the solutions box, highlight the selected word then click insert link, many other good options.
But I want to ask you , are you going on-line with fix-ya, because I couldn't, it says due to technical errors we can't sign you in right now, I don't know what the problem is I gave more than 50 sol, and still not going on-line...if this still exists I'll never came back to this site.
Dec 15, 2008 | Computers & Internet
Dirty first copy of each batch run.
YOU ARE RIGHT .
BUT YOU CAN ORDER IT BY GIVING THE MODLE NUMBER.
hope that help
Dec 02, 2008 | Konica Minolta DiALTA Di200 Copier
Minolta Di 150f printer/scanner/fax
If it is a Di modle it is most likely a curent model, but why did you inherited it??? Did your pal get a new one???? Do you have a boat???
May 13, 2008 | Minolta DI-2010F Copier
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
366 people viewed this question
Dan Webster
Dan Webster
Sal De
