Question about NEC Lands Phones
Two of our outgoing/incoming lines are "Camped". We are unable to access either line to disconnect.
  • NEC Master
  • 2,460 Answers
When you tie two lines together like that, the quickest way to make it go away is to physically power down the phone system.
Wait about 20 seconds and plug it back in and the lines will clear.
Posted on Aug 24, 2010
Line not assigned
make sure that your service provider has installed 3 individual lines into the building
check that the 3 incoming lines are not all together in the plug at the wall
you may need a telephone technician to check it out
Feb 17, 2016 | Panasonic Kx-tda100 Kx-tda100 Digital...
How To wire a cutler-hammer A/C Disconnect Box 60amp-240V Non- Fusible
"LINE" is typically the incoming power.
"LOAD" is typically the outgoing wires to the machine.
Sep 19, 2014 | Cutler Hammer DPU222RGF 60 Amp Out A/C...
Micromax a60 for Relaince gsm internet setting
Hello ,
Actually i am developing an application which needs to access INTERNET in mobile to do some task,i tried to access through email with incoming server and outgoing server configuration details to send an email, but it gives me an alert like " unable to open connection from server" . even i got success in emulator for incoming server but unable to do with outgoing server,
And mobile shows me as Wifi is connected but not able to access INTERNET in mobile...please help me ...how to do? ....my mobile is micromax andro A60...
thanks in advance for your valuable response .
Dec 24, 2010 | Health & Beauty
Get hot water only....when rotated to cold get nothing....replaced cartridge but still the same.....shower has been unused since house was built
If you don't have easy access to hot and cold line, where you can disconnect and check for flow to faucet, You can try turning off incoming water supply, remove cartridge, and shut off hot outgoing at water heater, then slowly open incoming (cold) water supply only and see if cold flows from faucet with cartridge removed. At least that will confirm flow faucet, then go from there.
Sep 19, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Is there any particular position to hook up the
NO you cannot.
. Artical 240.40of the NEC2008 code states Disconnecting Means for fuses. Cartridge fuses in circuits of any voltage where accessible to other than qualified persons, and all fuses in circuits over 150 volts to ground, shall be provided iwth a disconnectiongs means on their supply side so that each circuit containing fuses can be independently disconnected from the source of power.The top is marked line. This is where you connect the incoming power source. Then the switch then the fuses then the outgoing or load connections. thats why there is enough space in the disconnect to allow the wires to loop in from the bottom of the disconnect to the top line side lugs.
Jul 09, 2010 | Cutler Hammer Type Ch 30 Amp Indoor...
I am using Nokia N97, and want to configure Yahoo Mail, however I am unable to get the yahoo mails on my phone. can you plz suggest me the correct incoming and outgoing settings for my yahoo account for...
Incoming e-mail:
  • username: your email address
  • password: your password
  • Incoming mail server: pop.mail.yahoo.fr
  • access point used: sl2sfr
  • Account type: POP3
  • Security: SSL / TLS
  • Port: 995
  • APOP secure login: Enabled
Outgoing e-mail:
  • username: my email address
  • password: my password
  • Outgoing mail server: smtp.mail.yahoo.fr
  • Port: 465
Mar 06, 2010 | Nokia N97 Cell Phone
Meridian M7310; just installed replacement phone (used); line 3 disconnects when answered. Lines 1 and 2 work fine. They are in the loop. Line 3 is dedicated fax incoming but can be used as outgoing phone.
Normal 0 Hello, Gary.
Disconnect power and cables from all phones and faxes on the line 3. Wait 15 minutes and reconnect the line again, one at a time. See if the Meridian works. If not, it could be faulty.
Hope this helps.
Feb 01, 2010 | NorStar M7310 Corded Phone
Nokia n73
Please make sure your outgoing and incoming calls are not barred.
go to settings
go to call settings
go to call barring
and check the status of your outgoing and incoming calls.
There is also a line 1 and line 2 facility. Make sure you are using Line 1
Hope the above is helpful.
Thanks,
Kanu
Aug 04, 2009 | Nokia N73 Cellular Phone
Call forwarding for NorStar m7310
You have to know how to get into programming, and it depends on the type of telephone lines you have... if you have regular analog lines, on a out bound call transfer there is going to be line degragation. Meaning that the outgoing call is not going to be of the best quality.
Secondly, you have to see how many telephone lines you have, if you have 3 analog trunks, with a call forwarding to a cell phone, you will be using up 2 lines... 1 incoming and 1 outgoing to your cell. This leaves 1 trunk for incoming or outgoing callers.
Jan 22, 2009 | NorStar M7310 Phone
Lands Phones Logo
284 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
