Question about GE Dryers
GE Dryer model # DWSR483EGOWW The insulation around the inside of door the started coming out we put it back in and when the door is closed it sounds like coin are in the dryer leave door open no noise
  • 1462 Answers
SOURCE: GE Dryer DWSR473GV0WW periodically just hums when turning on switch
if it hums when you start it means switch is ok. problem may be the motor capacitor. to check, take off the top and give the drum a push in the normal direction of rotation. if it goes then motor capacitor is faulty - cheap part
Posted on Mar 28, 2007
  • 213 Answers
SOURCE: Groaning sounds when dryer spins
yes it is, its the rear tub bearing. pain in the butt to change but that will solve it
Posted on Nov 20, 2007
  • 38 Answers
SOURCE: coins stuck in tumblers on my Nebtune Dryer
Try calling a local repair man they could probably take it apart and take it out.
Posted on Dec 22, 2007
  • 1314 Answers
might have a dead spot on the armuture or lint in the motor and or the centrifcal switch try taking it apart and cleaning the motor if that doesnt work replace the motor
Posted on Feb 15, 2008
Master_Tech
  • 770 Answers
SOURCE: SOMETHING stuck inside the dryer body - something like a coin... let me knwo
ok here is the best way to describe it you will need to get around the back there are two torks screws remove them and slide the top panel back to you ..OH I FORGOT unplug the machine first !!!....Ok now with the top off you will see the drum.. slowly hand rotate it until you see some screws that are lined up with the baffles inside the drum You will need to remove just a few screws on one side (the baffle that has the coins) dont take them all out or the baffle will fall inside the drum and it will be a pain to get back on9u will need 2 people) and that should do it you will need to rotate the drum around until the correct baffle ...ie ..the one with the coins in on top at the 12 o'clock position.. let me know if this works our for you
Posted on Feb 16, 2008
When I push the start itll start but then right away it stops
If your dryer only runs when you hold the start button in, you probably have a broken dryer belt or it came off inside. There is a belt safety switch near the motor that if the belt comes off or breaks, it won't let the dryer run. There are 2 screws in the top lip of the door area that the door would close against facing up into the dryer top. Remove the screws and lift the top up. If you don't see a skinny black belt around the drum, it broke and fell down inside.
Apr 06, 2015 | GE DVL223GB Gas Dryer
How do I replace the plastic trim around the dryer door
You have to first remove the door assembly. Then the screws that hold that whole panel in should be obvious. I do not think you can replace just the seal, the whole panel has to be replaced. I included a link so you can see that assembly.
Parts for GE DWSR483EG0WW Front Panel Door Parts
Dec 13, 2014 | GE Dryers
How do I replace the plastic seal around the dryer door
Call dealer, they may give you a lot of help.
I have a side by side refridgerator , Lately after we open the frezzer side door and close it , After a couple of minutes water runs down from the bottom of the door
Ice inside freezer door is warming and melting. Some doors have fiberglass insulation and can be re-insulated (per a service bulletin from GE) but others have foamed in insulation which would require complete door replacement to correct that condition. I suggest contacting GE consumer relations with your model and serial number to see if they will help you.
Aug 09, 2011 | GE Refrigerators
GE electric dryer heats well, spins, but does not appear to be venting.
If it is not venting out the back of the dryer open the door and reach up inside the bottom area that closes over the filter when door is closed. Card board lining may have come loose restricting the air flow from being pulled thru the door into the filter area to the out side. Common problem with some GE's.
Mar 09, 2010 | GE DWXR483EBCC Electric Dryer
GE model DQSR483EE1WW. This is what I know so far: the switch on the door works so it shouldnt be that safety, it is getting power because the light work and the timer at least buzzes like its working,...
Try looking for a broken belt. (electrical interlock prevents starting with broken belt) Disconnect power, open door, remove two phillips screws which go from top of door opening into dryer top. Swing top up and back. If belt not present going around drum, that's your problem. Remove one screw from side panel to front panel on each side (near top) and lift front panel forward and off the bottom pegs. Set the front panel to the side (leaving door switch wires attached) so you can slip new belt around drum. Reach under drum to put belt WE12M29 around drive pulley and around tensioning pulley. (grooved side of belt touches drum) Put front back on dryer and manually rotate drum a couple revolutions to make sure belt does not come off before closing up top and reconnecting power.
Dec 24, 2009 | Dryers
New whirlpool dryer duet steam wont work
Sound like the unit doen't know the door is closed the door switch is not working. does the light inside the drum come on when the door is open and off when the door is closed
Mar 29, 2009 | Whirlpool WED9500T Electric Dryer
Dryer want start
You need to provide model details to get step by step instruction to remove the back cover off.
Jan 08, 2009 | Dryers
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemake not making water
At bottom hinge of freezer is the water line to door. Undo connection in line. It may be a quick connect. To undo push in on one end flange to release, and pull out line. Put bowl under end from under refrigerator and make sure doors are closed. Now push water dispenser and see if water comes out line. If it does, the line is frozen in the door. They had some models that had air leaks in freezer door. This causes insulation to freeze and water line freezes. Push in on inside of freezer door and see if it sounds like snow crunching. If it does it's probably frozen. Also peel door seal back a bit and see if is held on by numerous screws. If it is, it may be one of them that freezes. Call GE. They may still have the program going where you get 2 new doors free. Give them your model and serial numbers.
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Dryers Logo
187 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
