If a boy has to reach his school in 15 min.and his school is 800m far .At what speed should he walk?describe with statements and show the correct process
    Scholar:
  • 122 Answers
  • d = 800 meters
  • t = 15 minutes
  • r = rate
  • d = r x t
  • d / t = r
  • 800 /15 = 53.3m/min
Posted on Aug 23, 2010
What is a simple predicate
The boy walks to school.
subject = the boy
predicate = walks to school
simple predicate = walks
simple predicate is always the verb (in the predicate).
Jan 22, 2015 | Cell Phones
How to test a Lawn Boy ignition coil
you will need a spark test about 10 to 15 dollars hook the tester to it on the plug try to start it watch to see if it sparks the other way is to do without spark tester is to pull the plug out and lay it on engine block try to start it and watch to see if plug sparks
Aug 07, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
My lawnmower takes 15 -20 mins to warm up.
Check oil may have low oil shutoff and drain gas and start with new
Feb 25, 2014 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Victa ultima 207cc eng mod ult50 tecumseh starts runs for 15 sec then stops
it's in the carburetor. If it runs while being forced fuel then it means that the carb isn't supplying enough if any fuel for it to run on it's own. Take the carb apart as far as you can and make sure all the little orifices are clean
Dec 27, 2012 | Tecumseh Lawn Boy Push Mowers Insight...
After about 15 to 30 minutes, engine starts pinging (for a few seconds) then dies
Not familiar with tecumseh lawn boy. Lawn boys I worked on were 2 stroke, if this is the case the crank seal is sucking air after engine warms up. New seal would fix. If you can't do it you're self may not be economically worth it.
Sep 28, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
There are exactly twelve children in Ryan’s class. Only four of the children are boys. The following questions refer to a time when all the children are present in the class. There are no visitors in the...
Here is your problem pasted again ingluding some of my thoughts. These thoughts and the answers to your questions are in CAPITAL.
There are exactly twelve children in Ryan's class. Only four of the children are boys. THAT MEANS THERE ARE 8 GIRLS. The following questions refer to a time when all the children are present in the class. THAT MEANS THE TOTAL PERSONS IN THE CLASS ARE 12 SINCE THERE IS NO MENTION ABOUT TEACHER. There are no visitors in the class. There might be more than one correct anwer to a question.
1. Which of the lettered statements must be true?
2. Which of the lettered statements cannot be true?
3. Which of the lettered statements could be true or not true?
a. There are twice as many girls as boys in Ryan's class. IS TRUE
b. There are eight more girls than boys in Ryan's class. IS FALSE
c. There are four more girls than boys in Ryan's class. IS TRUE
d. If Ryan is sitting at a table with all the girls, there are exactly nine children at that table. IS TRUE
e. If only three of the boys are standing on their heads, one of the boys is not standing on his head. IS TRUE.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 17, 2010 | Acer Aspire 5500 5570-2609 Laptop
Tecumseh power sport 5hp how to find top dead center. dont see anything on the flywheel.
put a screwdriver in the cylinder and slowly turn the motor until the screwdriver reaches its upmost position. be extremely careful not to damage the cylinder
Apr 18, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Have a small Kenmore freezer (31" high x 24" deep by 21" wide). It works fine as far as freezing, but it never cycles off. Just keeps on going and going, driving me crazy. I also continually hear a subdued...
the wooshing maybe the oil/freon migrating thru out the internal system...
The cycle depends on 2 things... t'stat operation and timer. The timer usually shuts off freezer every 6 or 8 hrs for 20 to 30 mins. But the t'stat (once it reaches desired temp. should shut off freezer every 15- 20 mins. for an average 10 -15. So 15 mins off min 15 mins on (that is if the doors is not open) you get my point something like that...
but the way you describe to me it sounds like the t'stat. set it at 1 if it dont shut off and you are absoultely sure you got zero degrees (use a temp. reader) then replace the t'stat
hope this was helpful
let me know if this didnt work then plan B
Mar 09, 2010 | Freezers
After approx. 30 min. of walking on full speed it
I had this happen on our machine after about 5 years of use. I just recalibrated it and it appears to be working fine now. See the manual for information on the steps needed to take in order to do this.
Jul 11, 2009 | Bowflex Treadclimber
Stalling
I have same mower and just fixed what seems like a similar problem description. I had gone down the fuel system route and the symptoms just didn't add up. Stopped abruptly w/o sputtering once I reached warm-up temp. Replaced the solid state ignition (34443C now part number 3444D). Problem corrected and just mowed my 1/3rd acre w/ no issues.
May 11, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
