Question about Dell Inspiron 8500 Notebook
Hi there, i have a dell inspiron 8500 and i dont know how to connect to wifi. whenever i click wifi on the bottom right. it says no wifi connections in range. but im litterally sitting next to my wifi. so it says to make sure the wifi switch is on. where is it?
    Scholar:
  • 166 Answers
It can be either on the left hand side or on the right hand side. Make sure that its on the side that has a dot that indicates its on. You'll notice the Wi-Fi on the dashboard/panel its lit.
Please comment if the information has been useful to improve my support assistance. Thank you and regards.
Posted on Aug 23, 2010
My dell inspiron couldn't connect to wifi, because it doesn't turn wifi on when i press function key and f2 any solution?
no don't clickf1 or f2 , go to internet icon below on task bar , click right to that icon then click search for wifi , it will connect automatically and you can easily use the wifi , but sometimes it will ask for passwords .
Jul 08, 2011 | Dell Inspiron 6400 Notebook
I have a dell 8500 inspiron but cannot access the internet wirelessly
Hi
have you enabled the wifi switch i think it is FN+F2 but maybe FN+F8
hope this will sort it
could also plug in ethernet to get online then make sure you do all the windows updates
that may give you the update for it
good luck
Feb 19, 2011 | Dell Inspiron 8500 Notebook
I disabled the wireless (wi-fi) using the shortcut key.now i want to access wi-fi but unable to start using the shortcut key..wht exactly happened? did the driver had been uninstalled or wht? plz tell wht...
It should toggle. I don't think the driver would get uninstalled. Usually it's a switch (on Acer) or a Fn (Wifi icon Button) that turns Wifi on or off.
You may have to search for networks by clicking on the signal bars on the bottom right part of your screen, in order to connect to the Wifi network that is at your location.
Jan 21, 2011 | Dell Inspiron 710m Notebook
I HAVE A DELL INSPIRON 1525 & I DNT SEE ANYTHING WITH WIFI. HOW DO I CONNECT TO WIFI IF I DONT SEE THE ICON?
Click Start > on the Start Search type ncpa.cpl then press enter > right click on wireless connection > click connect/disconnect then there will be another window, click on connect to a network and then you will see there list of wifi networks, choose one the connect to it, if youre not able to see any network,that means that the wireless capability of you laptop is off, check the wireless switch or try to press Fn F5.
Hope this will help... Please rate YES...
Jan 20, 2011 | Computers & Internet
My laptop is del inspiron 6400,i have installed a new os ,windows xp. i have downloaded drivers but i have a problem in installing network drivers . iam given the information of uncompatability of hardware...
Connect your laptop to the internet using Wifi (obviously network connection not available due to your problem) and update the drivers for the network adaptor. Can you use a free Wifi point somewhere to connect via Wifi to help with the driver issue?
There will be a yellow exclamation mark next the network adaptor problem in the WINXP System Properties. To get here right click on My Computer, then select Properties, then Hardware, then Device Manager. Find the offending network card problem, double click the device, Select Driver, then Update Driver. Let WINXP find the driver from the internet.
Alternatively, check the driver you downloaded from the Dell support webpage. Are you sure it was the correct driver for WINXP for the same model of network card fitted to your Dell 6400? A message about incompatible hardware means you are trying to use drivers on hardware which is not compatible with that driver. That is a good sign that you dont have the right drivers.
Go to Dell here: http://support.dell.com/support/ and select Drivers and Downloads.
Try this link here:
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&catid=5&dateid=-1&impid=-1&osl=EN&typeid=DRVR&formatid=-1&servicetag=&SystemID=INSPIRONI6400%2FE1505&hidos=WW1&hidlang=en&TabIndex=&scanSupported=False&scanConsent=False
Ask me for more help.
Cheers,
Steve
May 03, 2010 | Dell Inspiron 6400 Notebook
I can't connect my dell inspiron laptop (only a few months old) to an orange livebox. there are three other users in the house, and it works for them (though they have different laptops. I have the...
Hello Mpquinn,
The first thing that I would advise you to do is,
Uninstall the WiFi Adapter totally from the System first,
(For WIndows XP)
Right-Click on my computer Icon, Properties-->Hardware-->Device Manager,
select the WiFi Adapter under network adapters, and right click on it, then select uninstall
Next, Click on Action on that Same page, and select "scan for hardware changes",
This will bring up a prompt to install the new hardware found (Which is your Wifi Adapter).
(For WIndows Vista)
Right-Click on my computer Icon, go to
Properties-->>Device Manager, select the WiFi Adapter under network adapters, and right click on it, then select uninstall
This will also bring up a prompt to install the new hardware found (Which is your Wifi Adapter).
After this, Press your Wifi button on the system and ensure that it is On, then Scan for wireless networks.
It should connect like that.
Try this out and kindly let me know how it goes,
Hope this helps.
Thank you for using Fixya.
Goodluck
Apr 25, 2010 | Dell Inspiron 2200 Notebook
Hi I have a Dell inspiron 5100 lap top. I have
  1. Right click my computer
  2. go to properties
  3. device manager
  4. you will see network adapter and under that will be wireless adapter
  5. click on wireless adapter
  6. go to properties
  7. See if device is working properl
Dec 02, 2009 | Dell Inspiron 5100 Wireless Mini-pci...
WiFi turns itself off
Hi Troy,
Don't know if this will work with your Dell, but on my Averatec, I had to do the following.
Go to Start>Right click on My Computer and select Properties. Click on the Hardware tab, and Device manger. Click on + by the Network Adapters. Right click on your wireless, Intel or Broadcom wireless adapter, and click on Advanced. Findd the Minimum Power Consumption and make sure it is disabled. If you have a Power Management tab, click on it, and uncheck both boxes.
Good Luck!
Jan 08, 2008 | Dell Inspiron 6400 Notebook
Open Questions:
Dell Inspiron 8500 Notebook Logo
Alun Cox
