Question about Toshiba 20VL14 20 in. EDTV-Ready LCD Television
Toshiba 20vl14 power loss
I have a Toshiba 20vl14 20" lcd T.V. and it works great......for about 50 minutes. Then the blue light flashes a few times and it shuts down. To get it back on, you have to unplug the power chord fot several minutes. Then it works fine the rest of the evening. Any help out there ?? We have had this tv for approx. 2 years.
This problem has always existed.
We called technical support their instructions was to reporgram the sleep timer we did this 3-5 times
did not work
Otherwise TV works find.
    Sergeant:
    Champion:
  • 256 Answers
Problem with power supply ask technician check it...
Posted on May 04, 2008
Toshiba television won't turn on after power flicker
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
? 2:20
https://www.youtube.com/watch?v=8-0nQ57Bvow
Mar 21, 2012 - Uploaded by rstarre ten g
My flat screen tv cuts off and on while the power but is on what should i try before i buy a new one .... I have a ...
Toshiba TV power outage - AllExperts
en.allexperts.com > ... > TV/VCR/Stereo Troubleshooting
Feb 3, 2011 - TV/VCR/Stereo Troubleshooting/Toshiba TV power outage - no power... we had a power outage (they're calling rolling blackouts due to power grid ... but I admit I'm now afraid to turn it off for fear it won't come back on again.
Toshiba 32c120u LCD TV won't turn on - Tom's Guide
www.tomsguide.com/answers/id.../toshiba-32c120u-lcd-turn.html
May 27, 2015 - My toshiba tv is flashing but won't turn on with remote or power botton on tv itself ... dang this worked for me but after a minute it stoped working.
Dec 28, 2015 | Toshiba 58L7350U 58" 3D 1080p LED-LCD TV -...
My Dynex 32" LCD tv seems to turn on and off
The blue light merely indicates that power is getting to your TV. It has internal power supply problems.
Nov 30, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Toshiba Picture Not On
what you suggesting is that the lcd has a good maintenance needs that have to have cold solder or connectors are sulfated
Aug 22, 2009 | Televison & Video
Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Mar 29, 2008 | Sony KDF-E55A20 55 in. LCD Television
No video on a 50H82 Toshiba Projection
If the screen is lit, then there is high voltage. If there is no video, and the screen is lit, then there is a loss of video. The fault can be anywhere along the main video path before it gets decoded in to the red, blue, and green compositions.
If the screen is not lit, most likely there is a high voltage failure, or there is a failure in the bias supply for the tubes.
When there is a loss of high voltage, this can be from any of the components in the high voltage area. Some of the main things that go defective are the flyback, high voltage multiplier, and various other small components.
Have you considered to replace the set with a good Plama or LCD set? This repair may end up being on the expensive side.
Jerry G.
Mar 10, 2008 | Toshiba 50H82 50" Rear Projection...
TV loses all power
I had same problem. Finally figured out the power supply was the problem. I ordered a generic replacement and it hasn't shut off again for over a year. The only thing I have notice is there are noise lines in the lower channels (1-6). This may be beause the Toshiba power supply may have a noise filter in the power supply. But the generic was $30 compared to $80 Toshiba
Dec 05, 2007 | Toshiba 20DL74 20 in. EDTV-Ready LCD...
Toshiba 20VL14 20 in. EDTV-Ready LCD Television Logo
109 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
