Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
I have a new GE side by side stainless I hear the fan running a lot in the freezer section it does go off but seems to be on a lot is this normal?
  • 101 Answers
How much is it stocked, is it freezing food,low food load could cause longer run times
Posted on Sep 12, 2010
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
Not cooling. i do not hear the compressor. fan is working. 3 yrs old
The condenser fan is very quiet so you may not hear it . remove the lower rear back panel and check whether the compressor and or fan is running . Also check if the back wall of the freezer has frost on it or if the evaporator fan in the freezer is running.
Nov 12, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Side by side GE PSW23PSTB SS. Freezer is 3 degrees in bottom and 33 degrees at the top.
Check to see if evap fan is running. you can hear it if it is when you open the door of the freezer. Also check and see if there is a lot of frost on the back wall of the lower section of the freezer. If fan is running you have defrost problem. If not running it is a board problem. part # wr55x10942. If you have frost then it will more than likely be the defrost heaters which both are easy to do if you take your time.
Jan 31, 2010 | GE GSS22JFMWW Side by Side Refrigerator
Ge eterna refrigerator loud humming
suspect you have a problem with the defrost system and hence the noise with the fan. take back panel off inside the freezer and if i'm right, melt ice off with a hairdryer. get back to me to say the results if you want
Aug 23, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrigerator Model GSS20IEDPD
check the back panel inside the freezer section near the lower shelf (not the bottom bim) for frost
Oct 14, 2007 | Refrigerators
GE side by side
Check to see if there is air flow coming from vent/damper into the fridge section. Also you should hear a fan running in the freezer. If the fan is running and no air flow then the problem is in the damper/vent. If the fan isn't running then it may be bad. Check to see if you have power to the fan motor if it is not running. Note: Fan will not run if unit is cycled off or in defrost which is normal.
Oct 04, 2007 | Whirlpool GS6NBEXR Side by Side...
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
62 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
