Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do I replace the ignition switch on a Craftsman Lawn Tractor?
    Problem Solver:
  • 5 Answers
There is a plug that plugs right into the ignition, just unplug it and unscrew the igniton.
Posted on Aug 25, 2010
Craftsman lawn tractor 917.273130 hit and miss starting then nothing. replaced ignition switch nothing any ideas?
it could be the the CuT out watched one is under the seat one is under the brake and some have one under the lever that engages the blades.
May 29, 2018 | Craftsman Garden
Have a craftsman gs6500 lawn tractor with kohler 26 hp eng. need to know what the wiring for the ignition units and the gap setting. getting no spark from either coil.
You have a bad switch, i just had the same problem. One of your safety switches is grounding the coils so it wont start. there are 4 of them. One is under the seat, one is on the break pedal, one is the pto switch and the final one is the ignition switch.
Aug 15, 2011 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Craftsman Lawn Tractor, 18 HP, 44" Cut; No SWtart!
Check the by pass switches on the seat, clutch pedal, and check the fuses.
May 15, 2010 | Craftsman Garden
My craftsman lt 1000 lawn tractor will not start. When I turn the key the starter motor spins but the gear will not raise up and engage the flywheel. Do I need a new starter? (18 hp b&s 42 Inch cut) If...
Starter motor spins, but does not engage
  1. Check the starter motor for a seized or binding pinion gear.
  2. Remove the flywheel inspection plate and check for a damaged ring gear.
  3. Engine stalls immediately when started
    1. Check the ignition switch condition and operation. The electrical contacts in the run position may be worn or damaged. Try restarting the engine with all electrical accessories in the off position. Sometimes turning the key on an off will help in emergency situations, however once the switch has shown signs of failure, it should be replaced as soon as possible.
    2. Check for loose, corroded, damaged or shorted wires for the ignition system and repair or replace.
    3. Check for manifold vacuum leaks or vacuum hose leakage and repair or replace parts as necessary.
    4. Measure the fuel pump delivery volume and pressure. Low fuel pump pressure can also be noticed as a lack of power when accelerating. Make sure the fuel pump lines are not restricted. The fuel pump output is not adjustable and requires fuel pump replacement to repair.
    5. Check the engine fuel and ignition management system. Inspect the sensor wiring and electrical connectors. A dirty, loose or damaged sensor or control module wire can simulate a failed component.
    6. Check the exhaust system for internal restrictions.
May 12, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Difficult to start -- bad kill switch?
You have 3 safety switches located on the tractor, any one of which can cause the tractor to not crank over.
I assume the deck lever is not engaged, you are sitting in the seat and you push the clutch down when trying to start?
Start by lifting the seat and disconnecting the seat switch, push the clutch in and try to start.
Start there and we'll go from there.
Regards,
Aug 21, 2009 | Craftsman Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
60 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
