Question about Ovens
We had 2 power outages within a 30 minute period. Now I cannot reset the clock. The clock works, but the reset does not work! What can I do?
  • Ovens Master
  • 11,800 Answers
Unplug it from the wall, open the oven and check for the parts the power surges has fried - replace if necessary. If you can't find any then use a thick piece of insulated wire and discharge all the capacitors. If even after that the oven doesn't work as it should be then the control processor has been fried. Since they aren't sold as parts the entire oven is defective- either use it as is or junk it and buy a new one.
Posted on Aug 23, 2010
My clock is just blinking and my oven won't work wat would the problem be
many clocks blink when there has been a power outage . try resetting the clock . if that does not work it will require a repairman
Nov 10, 2016 | Ovens
Ovens work fine . .ONCE ! Then buttons do nothing until you turn off the wall breaker for an hour. Then the oven works ONE time again.
Tom Sh, you own every kind of appliance, or you are attempting to be a repairman with free advice from Fixya?
Replace the touchpad. Help Me Find My Model Number RepairClinic com
Aug 30, 2016 | Ovens Ovens
When we reset the clock after a power outage, the clock runs fast now almost a minute in 30 seconds. Bosch HBL5750
Advise manufacturer; may give you a warranty on this part even after it has expired because of nature of the problem.
Mar 08, 2015 | Bosch HBL5750UC Electric Oven
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
Due to a power outage i am now not able to set the
Yes you must unplug this stove wait for 5 minutes and the plug it back up, push the off button and this should reset the oven, if that does not work the circuit breaker has been tripped, it may look to be in the on postition, but you will need to move to the off postion and back to the on postion this should correct the problem
Oct 18, 2009 | Kenmore 33169 Gas Single Oven
Oven has power but will not turn on. Cannot set
try to cut the power to the oven for about 30 minutes and see if it will reset the clock. if this doesn't work you may need to replace the ERC (clock). sometimes you can get a rebuilt, check around.
Oct 11, 2009 | Ovens
Cant reset clock on westinghouse 476 underbench gas oven
When I turn on my westinghouse gas oven (GOL476), it appears to ignite immediately but after 3 or 4 minutes there is a strong gas smell which lasts for sometime before it gradually disappears.
Sep 17, 2009 | Kenmore 33169 Gas Single Oven
We had a power outage and the oven will not work, after shutting off the power the panel lit up with all 8888s and will not work
Forgive me for saying this, turn the unit off wait 30seconds, then turn on again (this sometimes works)
There is a very good possibility you have suffered a power surge which has damaged your electronics unit. Please check your manual to see if there is a reset button on the display (this sometimes reolves it).
If there is no way to reset, then you will need to replace the displat/circuit board, this is quite fiddly and i would recommend you call in an appliance expert.
I hope this helps.
Jul 08, 2009 | GE PT956CMCC Profile 30" Built-In Double...
Put in new wall oven , turned on power and set
my kenmore double oven model 41165 has no power....its hardwired 40 amp....it stopped working when it was cooling down after the slf cleaning cycle..we had a storm and had a minute power outage. Finakky got the door open but it wont turn on at all. Tried the breakers but i stll get no power....no even the bulb.......thanks....
Jun 07, 2009 | Ovens
After a power outage oven will no longer work
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Ovens Logo
18 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
