Question about GE Profile Spectra JGBP90 Gas Kitchen Range
F2 Code Problem
Greeting,
My name is Sam, I am having the same problem with my GE XL44 gas stove with the F2 code showing on the LED. It happend's when I set my oven and the preheat beeps in. After about 5 minutes the F2 beeps in. I turn the stove off for about 2 minutes, set the oven temperture. some time it will beep F2 again. I seen online with other GE XL44 customers having the same problem. Is there any quick fix without spending high amount of money to fix this problem. Please reply back: samlcartersr@comcast.net
  • Anonymous May 19, 2008
    Have codes d 7 and f 7 flashing along with prolonged beeping when cooking
    on burners. When cleared the codes and beeping repeat.
  • Anonymous Aug 27, 2008
    For last 2 weeks when oven has not been in use in last case for 1 week, came home w/ F2 cose beeping & flashing?? I saw that someone replaced the computer chip but no clue of the expense or where to inquire??
I agree with ttpercoli. I had run across the same resolution about a yr ago and I replaced sensor and its been fine since. No more F2 errors
Posted on Sep 03, 2008
I can't take credit except searching and found this info.. I will order to see if it fixes my error messages..Tom
All, I hope that this helps everyone having this annoying problem. The problem is the F2 error that seems to come on everytime you use the oven. Well, it was driving my wife crazy, so I finally gave in, and had a GE technician come over to fix it. :) It cost me $190, with $80 for the part and $110 for the labor. Had I known what the problem was, I could have fixed it myself in 10 minutes, and only would have had to buy the part. My loss is your gain. The technician replaced the sensor, part #WB21X5301 (can find at (www.geappliances.com (http://www.geappliances.com)); cost is $76. If you open the oven door, the sensor is on the top left-hand side and is long and skinny. Instructions come with the part to replace it. Basically, you unplug the oven, take out two screws, and cut the two wires to the sensor. You then use wire nuts to connect the new sensor wires, and push the :) wires out of the oven area into the back panel. That's it. Problem fixed. Glad I could help out others!! Merry Christmas! JakeDecember 11th, 2005, 02:25 PMThanks for the information and update back on this problem you had.:)
You can also buy that same part#WB21X5301 from here, abit cheaper:
Oven sensor assembly (http://www.repairclinic.com/referral.asp?R=1265&N=252618)
Posted on Aug 27, 2008
Hi there - My GE Profile spectra XL44 Gas Stove shows code F1 with none-stop beeps, I only sgut the power off... - what should i do to kill that noise now ?
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced
Sep 27, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
My ge xl44 gas range, installed in 2000, turns off and flashes an f2 code occasionally. Can you give me the reason?
F2 means: For an unknown reason, the oven temperature has exceeded a preset threshold.
G.E. recommends you try this:
Sometimes shutting off the circuit breaker that the range or oven is connected to for 30 seconds will clear the fault, error or function code, however there are some cases when further service may be required. If you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737
Here is the fault code guide link:
http://www.geappliances.com/search/fast/infobase/10009792.htm
May 20, 2010 | GE Kitchen Ranges
Need replacement drip pans for ge xl44 gas stove
u can find the parts only in the service center of GE appliance center.but if ur unit is more than 10 years,im sure no parts available.
Jun 30, 2009 | GE Profile JGP636 Gas Cooktop
How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Feb 19, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Ge oven codes
F2 means your oven temp got too high. At least, that's what the control boards thinks. More than likely you have a bad oven sensor or bad wire to it or a bad connection somewhere between the board and sensor.
Dec 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE spectra xl44 not work
I have the Ge Xl44 stove the burners and broiler work fine but the over will not heat up. How can I resolve this problem?
Jan 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Top works bottom doesn't
I have XL44 oven JGBP26. I replaced the glow ignitore on the oven but still will not glow. I carfully tested the current to the ignitore and showed 125 volts, I also tested the resistance on the control valve lead and to ignitore and showed 1100.
Dec 15, 2007 | GE JGBP28 Gas Kitchen Range
Control panel shows F7 and contantly alarming or beebing
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Oct 20, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
510 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
