Question about Baby Gear
Help how do i change spark plugs on a 96 2L ford galaxy?
YOur a ****
Posted on May 04, 2008
2003 ford crown victoria shuts off when driving i try to start it up it just cranks but wont start. Already changed the fuel pump and spark plugs and that dont seem to work. Any one please Help??
You'll first need to find out if you are lacking fuel or spark to know where to go next. Do a basic test for fuel pressure with a gauge and spark at the plugs when it fails to start.
Feb 16, 2015 | 2003 Ford Crown Victoria
How to change spark plugs and wires on a 1998 Ford F150
Change the coils and the plugs. If you feel any hesitation or skipping its going to be one of the other causing it. Best change them all
Oct 25, 2014 | Ford F-150 Cars & Trucks
1965 ford galaxy 500 352 v8 wont stay running
Are you sure you have the plug wires on right, and the point gap is right ? I am assuming you have checked the carb and ruled out a fuel problem.
May 29, 2013 | Ford Cars & Trucks
No spark to engine 1991 ford pickup
It can be faulty or dirty spark plug itselfd.Also for reference get the fuel level checked.Is the fuel tank is empty or near to empty.
Try cleaning the spark plugs and then see if that is helpin.On some cases the black carbon layer gets collected on the spark plugs and that causes the problem,so cleaning the plugs help.But if its not helping,then spark plug has to be replaced.Spark plugs get power from ignition coil to ignite sparks.If ignitioncoils are faulty then also there will no spark.--------------
To troubleshot and confirm the issue,i suggest you to go through the help links provided below,check the procedure and it will help you to confirm the issue in your case.
Click the link below:------
Car cranks, has spark but will not ?
http://howtobyme.blogspot.com/2011/12/car-crankshas-spark-but-will-not-start.html
The spark plug firing order for car?
http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
How to Replace Spark Plugs?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
How to Perform a Basic Engine Tune Up-Spark Plug and Wire Change
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up_01.html
Car has no spark?
http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
How does the spark plug wire go on the distributor cap in 1991 Mitsubishi Mighty?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
No spark on 2008 Chevy Avalanche?
http://schematicsdiagram.blogspot.in/2012/04/no-spark-on-2008-chevy-avalanche.html
How does the spark plug wire go on the distributor cap in 1985 Pontiac sunbird?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wire-go-on.html
Ford Plug Wires Not Coming out?
http://whoisbyme.blogspot.in/2012/06/ford-plug-wires-not-coming-out.html
Ford explorer has no spark?
http://schematicsdiagram.blogspot.com/2011/12/ford-explorer-has-no-spark.html
Chevy impala spark plug firing order diagrams?
http://technoanswers.blogspot.in/2012/02/chevy-impala-spark-plug-firing-order.html
How to gap spark plug on Chevy Impala?
http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html
Spark plug Replacing for chevy impala?
http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
Chevy s-10 blazer 4.3l Spark Plug Firing Order?
http://howtobyme.blogspot.com/2011/12/chevy-s-10-blazer-43l-spark-plug-firing.html
1982 dodge rampage Spark plugs Firing Order Diagram?
http://schematicsdiagram.blogspot.com/2011/12/1982-dodge-rampage-spark-plug-firing.html
2006 Suzuki Forenza Spark plug Firing Order Diagram?
http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
1983 Ford Ranger Spark plug firing order?
http://schematicsdiagram.blogspot.com/2011/12/1983-ford-ranger-spark-plug-firing.html
Firing Order for 1991 Lexus ES 250?
http://schematicsdiagram.blogspot.com/2011/12/firing-order-for-1991-lexus-es-250.html
Firing order for 1992 Chevrolet 5.0 engine?
http://schematicsdiagram.blogspot.com/2011/12/firing-order-for-1992-chevrolet-50.html
How to identify number one spark plug on the distributor cap?
http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
How to remove rear spark plugs on 1991 Buick Regal?
http://howtobyme.blogspot.in/2012/02/how-to-remove-rear-spark-plugs-on-1991.html
These details will help.
Thanks.
Nov 26, 2012 | Cars & Trucks
IT WILL CRANK BUT WONT START,,,, 98 FORD ESCORT,,,REPLACED FULE PUMT,,,HAS A LITE SPARK FROM QUOIL
check your spark plugs, usually you need change it every 30,000 miles...
How to change?
http://www.ehow.com/video_110_replace-spark-plugs.html
Hope this helps
Sep 20, 2011 | 1998 Ford Escort
How to change spark plugs in 2002 ford f150 with a 5.4ltr
Hello my name is Israel and I will be glad to help you. On this vehicle it is fairly easy. This vehicle has a coil to plug assembly, meaning that each spark plug has its own coil. All you have to do is carefully pull the spark plug wire off the spark plug with a little "tough love". Using a 5/8 socket remove spark plug and replace with new one, connect spark plug wire until you feel it "snap" back onto the spark plug. Repeat with the other 7 spark plugs. Good Luck.
Jun 28, 2010 | 2002 Ford F150 Regular Cab
Firing Order diagram for 2006 Ford Explorer
Hope this helps. The ignition coil:
  • changes low-voltage pulses from the PCM to high-voltage pulses.
  • fires 2 spark plugs simultaneously.
  • has 3 transformers.
    • One transformer fires the spark plugs for cylinders 1 and 5
    • One transformer fires the spark plugs for cylinders 2 and 6
    • One transformer fires the spark plugs for cylinders 3 and 4
Spark plug wires:
  • carry high-voltage pulses from the ignition coil to the spark plugs.
The spark plugs:
  • change high-voltage pulses to spark at the gap, which ignites the fuel and air mixture.
The firing order is 1-4-2-5-3-6.
Jun 06, 2010 | 2006 Ford Explorer
I have a ford galaxy 2l s reg trouble starting
its your anti theft unit, relay 30 needs checking. www.fgoc.co.uk
Mar 30, 2010 | 2000 Ford Expedition
I would like to know how to change the spark
FIRST OF ALL YOU HAVE CHANGE SPARK PLUGS WHEN ENGINE IS COOL.IF YOU CHANGE THEM WHILE ENGINE IS HOT YOU COULD DAMAGE THE ALUMINUM HEADS OR CAUSE DISTORTION.TO CHANGE SPARK PLUGS YOU NEED A SPARK PLUG SOCKET.A TORQUE WRENCH.ITS NOT MANDATORY.BUT IT WILL KEEP YOU FROM OVER TIGHTEN SPARK PLUGS.YOU NEED A 3/8 RATCHET AND EXTENSION.YOU ALSO NEED A SPARK PLUG GAP GAUGE.AND SPARK PLUG BOOT PULLER.YOU ALSO NEED SOME ANTI SEIZE COMPOUND.TO PREVENT DAMAGE THREADS WHEN INSTALLING THE SPARK PLUGS.
Oct 13, 2009 | 1999 Ford Expedition
Need help with my T reg ford galaxy
I have heard that the gas situation has caused some "bad" gas to show up? Possible, but most likely a coincidence-something else wrong.Have spark at spark plugs/ Fat blue spark.Any difference cold or hot? Any "popping back" or "backfire" on the way to work? What year Galaxy?
Oct 12, 2008 | 1998 Ford Explorer
Baby Gear Logo
52 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
